Question about Car Audio & Video
My kenwood kfc ws252 moves but does not make sound. what's the issue?
    New Friend:
    Problem Solver:
  • 10 Answers
Many different problems could be occuring. if the sub is not in a box, it will not produce any bass, get in a box and problem solved.
if you have more than one sub you could have them out of phase, reverse the positive and negative on ONLY ONE SPEAKER and it should fix this problem.
if its amped you could have the crossover set improperly, set to LPF or low pass and set frequency to about 90 to 120 and you should be good with that.
other than that it could just be under powered, a good 200 watt amp should be enough to push it and get good sound, it can handle more but thats up to you. hope the info helps.
Posted on Jan 16, 2013
4 Suggested Answers
  • 6 Answers
SOURCE: sounds staticy
unfortunately not.. once a subwoofer is blown its for lack of other words.. dead.
Posted on Sep 15, 2009
perryhawk
  • 13 Answers
SOURCE: Kenwood KAC-X1R and one 12"
You may have a high resistance in your positive or negative power supply. with your amp you need to use at least a 2 gauge power cable. Is your fuse blowing? if so then a short circuit to ground may be causing that.
Good luck
Posted on Aug 05, 2008
budice7h20
  • 93 Answers
SOURCE: Will 2 KENWOOD KFC-6982iE fit in 1999 mazda protege
If they fit then put them in. The only thing is, if your not using a amp they may not sound good.
Posted on Jul 02, 2009
How to repair kenwood KFC-ws253 subs
This usually means the voice coils have burnt out also.
When I was with Kenwood, it wasn't worth spending the time to repair units that had been overdriven (i.e. burnt out).
Mar 02, 2013 | Kenwood KFC-WS253 Car Speaker
The led on my kenwood KFC-W3534A won't come on
It can be the issue with connections or power issue or also the board issue.In some cases all checked out ok,but the actual problem comes out to be the short is display panel,which power the led.------Also how old is unit and what exactly caused this problem,is there any kind of other indication showing up like,loose wire or erratic noise coming up,with no power .Etc etc,,-------Click this link below :----
http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
Thanks.
Jan 26, 2012 | Kenwood Car Audio & Video
Wiring Kenwood KFC-W3003
If it's a single voice coil, it's probably 4 ohms. the sub only handles about 175w RMS, so don't expect earth shattering bass to come out of it. A single voice coil is easy. Positive from the amp to the positive post of the sub, negative from the amp to negative post of the sub. This sub sounds lots better if it's in a sealed enclosure. A ported enclosure allows too much cone movement, heating up the coils, and the sub fails prematurely. Hope this helps.
Aug 25, 2011 | Kenwood KFC-W3003 Car Subwoofer
The foam on my kfc w3000 is destroyed
There are kits available to repair speaker surrounds (aka foam). Here's a link to one of them:
http://www.speakerworks.com/speaker_repair_kits_s/65.htm
Just a side note: repaired speakers will never sound the same. I repaired my subs a few years ago and was unhappy with the resultant sound so I purchased new ones. Personal experience.
Aug 30, 2010 | Kenwood KFC-W3009 Car Subwoofer
WHAT DO THE KENWOOD KFC W3009 GO FOR????
Are you buying or looking to sell them and are they used or are they new? They are discontinued and from the looks of it were about a 60 dollar sub new.
May 28, 2010 | Kenwood KFC-W3009 Car Subwoofer
Can i run a 4 channel 400watt amp to 4 6x9 speakers?
yes i dont see why not
they should work perfectly
is the question how to wire it?
if so then reply to this message
LOL
kenwood KFC
May 12, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
What amplifier do i have to used for the kfc-w3009
I run my Kenwood KFC-W3009 from a Tornado 5 channel amp via a cross over . Amp is 2000w 4 channels are for the 6X9's & the 5th channel is only for sub. I will never sell that amp as i kicks. I use it in my 15 seater bus & people can hear me coming down the road
May 11, 2010 | Kenwood KFC-W3009 Car Subwoofer
My kenwood kfc-w300s sounds like its clicking but it sounds like its the magnet, when i hold the magnet it doesnt click but wen i let go it carrys on, Any suggestions?
THE COIL IS BLOWN, THAT HAPPENS WHEN YOU OPEN THE TRUNK WHILE BLASTING YOUR MUSIC, IT'S USED TO A CLOSED INVIROMENT THEN BLASTS OPEN, NO GOOD FOR THE SPEAKER.
Sep 23, 2009 | Kenwood KFC-W300S Car Subwoofer
Jul 01, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
I NEED USER MANUAL OR SPECS. TO BUILD PROPERLY SIZED CABINETS
Can't help you on the manual, but basic specs for both drivers are listed on crutchfield.com web site.
Easy way to do it is ; type in KFC-W2505 and the KFC-W2509 in your search engine and click on the Crutchfield web site. This will give the overall cubic dimensions of the cabinet, plus other info. Hope this helps...
May 02, 2009 | Kenwood KFC-W2505 Car Subwoofer
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
