Question about Brookstone Handle-Mount Grill Light
How do you remove the battery cover
I can't seem to remove the cover and I feel like it will break if I try harder
When I' stepping on the gas it's feels like I'm pushing harder on the peddle'...but when I take my foot off it slows down..enough that I notice it..ON the highway I notice it more.And
You could try unpluging your battery posts and leaving for about 10 minutes and hooking up again to reset your computer.........
Nov 09, 2012 | Cars & Trucks
Problem chain / break cover chainsaw
Hi, hold the cover in a vice where the bar nuts normally tighten up to, then pull the chainbrake lever back in the direction the handle bar would be. You will feel a click and the lever will stay back and the brake band will be released. Then refitted cover to the saw. Regards Phil.
Aug 20, 2012 | Garden
Scotts 2046h rear tire removal
many wheels get stuck on the axle so if you remove the clip that holds the wheel to the axle and it does't come off just change the tire on the mower sounds harder to do but you don't break stuff trying
Apr 26, 2012 | Garden
How do I remove the spool from a Singer Model 2112 sewing machine?
Did you remove the small spool cap holding the larger piece on?
Jimmy
Mar 31, 2012 | Sewing Machines
When I was attaching the screen to a VESA arm, one of the nuts inside the unit came off and is floating in the unit. I need to get the back cover off to get the nut and re-attach it. How do I get the...
As it appears it seems that the back of the unit is held together by clamps. I wouldn't advise you to go ahead with the dis-assembly because you risk breaking the clamps. But if you must do it proceed with caution. Start prying open from the bottom screws toward the top of the unit. Use a plastic wedge to help the prying. It really comes down to finesse and experience. If you don't feel confident doing it don't do it as you might break it irreparable. The mount should be usable even mounted in 3 points.On the other hand the loose nut could cause some damage short circuiting the board. \
Good luckVlad
Feb 27, 2012 | Samsung B2230 LCD Monitor
How to install starter on 1985 saab 900 tubo
The procedure for removal and installation of a starter depends on whether your Saab is a manual or automatic. If you need a more detailed explanation let me know and I will either post it or can email it to you. It seems the Saab engineers couldn't of made it harder for a DIYer. Good luck!
Remove the Black clutch cover on the manual & half cover on the auto
Remove the Red battery cable on the Battery
Remove the Red battery cable on the Starter
Remove the yellow wire from the starter solenoid
Loosen the brace to the bottom of the intake manifold
Remove the bolts or nuts from the starter through the front timing cover
Feb 24, 2010 | 1985 Saab 900 Hatchback
Cannot remove cover to install more RAM
There are tools that help you pry into a laptop. It looks like a pencil a flat edge on it. Usually you just need to pop it out. But there is no problems with being cautious. There are also manuals to look at also.
Mar 12, 2009 | Acer Aspire 5315 Notebook
The keyed lock on my 98 passport on the tail gate has been punched in, I can't figure out even how to get the tail gate open, because the handle on the out side seems to be un atatched, I feel that if I...
I believe you have to open the rear window to open the tailgate??
Tailgate opens right to left [ passenger to driver ] side?
Tailgate handle will not work if window not open - feels like it is disconnected. The "button" releases the window only.
If you open the rear window and the tailgate still will not open. You need to remove the inside tailgate cover to get access to the handle and release switch. You can access the the window release the same way [ just a little harder to do]. You will probably end up breaking the vinyl panel to do this but so will the auto body shop and they will charge you $$$$$ to replace it.
Jul 24, 2008 | 1997 Honda Passport
Brookstone Handle-Mount Grill Light Logo
80 people viewed this question
Top Brookstone Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Brookstone Grilling Expert? Answer questions, earn points and help others
