Question about Polaroid TLA-04011C 40 in. LCD TV
Hooking up VGA to my Polaroid TV to stream movies, doesn't recongnize it
    Genius:
  • 1,669 Answers
You need to download the appropriate HDMI drivers for your VGA to get it to output to the TV HDMI input.
Posted on Jan 13, 2013
How do you connect roku to a tv without an hdmi plug
component adapter? If your TV has a connection for DVI or VGA, you can purchase adapters that will change the HDMI to DVI/VGA if needed. Check online or go to radio shack
Jul 25, 2014 | Roku Streaming Stick
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
I HAVE A VIZIO TV #VA26LHDTVIOT AND I WANT TO GET BLOCKBUSTER STREAMING. I WAS TOLD TO USE MENU SCREEN TO GET CONFIGURE AND OR SETTINGS. NEITHER OF THESE ARE THERE. CAN YOU HELP?
This is the official technical specifications of your tv
http://www.vizio.com/va26lhdtv10t.html#techspecs
As you can see there is no mention of a network capability , let alone streaming. Actually this tv doesn't have even USB ports so you can't even connect an memory stick and play a movie on it. So streaming is out of a question with this tv.
Sorry, you can't do it. Either get a better tv or use a pc connected to the internet for which the tv will be the monitor.
Sep 08, 2011 | Vizio VA26L 26 in. LCD HDTV
I have a Gateway T-6330u and want to connect it to the TV to watch a movie, but I don't know how to do this. I searched the web and found I may need a HDMI cable, but I don't know if there are...
If your TV has a VGA input or the laptop and TV have HDMI run the cable over choose the correct input on the TV "pc or hdmi" my asus auto detects the hdmi stream you may have to right click on the desktop go into video setting and choose the TV.
Aug 22, 2011 | Gateway T-6330U Notebook
1. My 2008 MacBook Pro rejects most cd's and dvd's, has a Intel 2.5 GHz Intel core 2 processor. 2. When I downloading or streaming movies they keep re-buffering
Solving Problems with Streaming Services
If the Server Does Not Start Up or Quits Unexpectedly:
  • Check the error log.
  • Make sure the QuickTimeStreamingServer file is in the /usr/sbin/ folder.
    You must be logged in to the server computer as Administrator (root) to see the QuickTimeStreamingServer file in the Workspace Manager.
  • Use the Mac OS X Server Setup Assistant to reconfigure the Ethernet ports.
If Media Files Do Not Stream Properly:
  • Make sure the movie file is supported by the QuickTime Streaming Server. Check the list of compatible file formats.
  • Try streaming a sample movie to see if the server can stream it. You can download a sample prehinted movie from the Apple Software Updates Web site: http://www.apple.com/swupdates
    If the server streams the sample movie, the problem you're having may be with the way your movie file is prepared. Recreate the movie.
    If the sample movie doesn't stream, the problem you're having may be with the server computer or the network.
  • Try hinting the movie again with the Optimize Hints For Server option selected.
  • Check streaming server activity and if necessary, reduce the number of connections or throughput.
  • If the problem occurs on a Mac OS client computer, open the TCP/IP control panel on the client computer and make sure MacIP is not selected.
  • If the problem occurs on a client computer, make sure the user has the appropriate settings in the Streaming Proxy and Streaming Transport panels of the QuickTime Settings control panel. The administrator for the client computer's network should be able to provide the correct settings.
  • If the problem occurs for media streamed using PlaylistBroadcaster, try hinting the movies again with the RTP Payload Encoding set to QuickTime and Smooth Data Rate enabled.
  • If you are reflecting more than one live stream, make sure each stream uses a separate UDP port. Otherwise client computers will show a message with error 500. You set up ports in the relay configuration file.
If Streaming Service is Slow:
  • If you are streaming QuickTime movies, make the movies self-contained using your authoring application, and make sure hinting is optimized for streaming services.
  • Reduce the maximum number of connections or the throughput.
  • Turn off other services.
  • Place media files on other hard disks to improve server performance.
    Because QuickTime Streaming Server can use only one media folder, you need to create links from the folder you have selected in QuickTime Streaming Admin to the media files on other hard disks. To do so:
    In the Workspace Manager, press the Control key and drag the folders that contain the media from the other disks to the folder you have selected as the media folder.
Aug 04, 2011 | Computers & Internet
Panasonic hdtv 1080i CT-36HX41E..Can you hook up a PC to the tv for the monitor?
You can connect this to your computer if you have an S-Video output on your computer. This is the only supported connection on your TV. This model doesn't have a VGA, DVI, or HDMI port.
Hope that helps!
Jul 19, 2011 | Panasonic CT-32HX40 32" TV
Hooking computer up to tv to watch movie
Purchase a vga cable and hook it up to the computer and then to the tv
Jul 18, 2008 | Vizio L32 32 in. LCD HDTV
Polaroid TLA-04011C 40 in. LCD TV Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
