Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Panasonic PT50LC14 Rear projection LCD - too much green
Hi! There is too much green on the screen of my Panasonic PT50LC14 LCD TV. I replaced the lamp with new Phillips lamp w Housing but that did not help. I could not find the RGB adjustments on the menu. Is there a way to adjust individual colors? How can I access the service menu?
Many thanks in advance,
--Michael
Had the same problem today. Thought is was my bulb. Replaced it but still had the color problem. Replaced the cables between cable box and TV and no more problem!
Posted on Feb 21, 2009
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Where dpo I get part LSEP3126A for Panasonic
The part is available through Partstore.com at this link. It is worth it if you are 100% sure this is the problem with the TV.
http://www.partstore.com/Part/Matsushita/Panasonic/LSEP3126A/New.aspx?SearchTerm=True
Nov 03, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Blue & green star like spots on Panasonic rear projection LCD TV
The EEPROM needs to be reprogrammed. You should contact Panasonic customer care as they may fix this at no charge to you.
Jul 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reset hour meter for replaced lamp
push and hold the PIP (same as play) button in the remote control
push and hold the menu button on the front panel of the tv.
Do both actions simultaneously. Of course you have to be close to the tv to do this: pointing with the remote at the sensor AND holding the menu button of the tv panel.
Do this for some seconds and the screen is going to tell you the timer was reset sucesfull and ask you to push exit in the remote control to finish
Apr 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Where do iget a ballast for a panasonic pt50lc14? already replaced bulb, looking for a ballast. is there a spacific ballast i need?
my recomendation would be save your money, and spend it on a new tv. by the time you pay for it you could of bought yourself a new tv...even though it wouldn't be a 50" you'll be much happier in the long run.........
Mar 02, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Vertical green lines
Call where you bought the TV. This is not normal for an LCD TV. They should exchange it only being a week old.
Jan 20, 2008 | Televison & Video
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
374 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
