Question about Sony Walkman NWZ-A828 Digital Media Player
Sony Walkman NWZ-A828 Connection Problems.
The device only switches on when it is plugged into a computer. And then all it does is says "connecting USB (MTP)" constantly when plugged in. You can't even access a menu. As soon as you take it out of the USB port, it just switches off and won't switch on again unless re-plugged pack into the USB. Thanks.
  • Anonymous Apr 30, 2009
    same as the guy
    Problem Solver:
I have a problem with my player which could well be related, the unit appears to power off but in reality is still draining the battery (I never see the "every moment has it's music" thing)
I've replaced the battery and upgraded the firmware to no effect , so I think the hardwares at fault, all I can do for the moment is leave the player plugged into USB until I need to use it.
Sorry I can't be of more help.
Posted on Jan 10, 2010
    Problem Solver:
  • 9 Answers
I had the same problem, thought mine was broke! Went on the sony webside where I found this -
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
  1. Battery must not be discharged 100%
  2. If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
Plugged mine into a mains charger with the usb adapter and it is back in working order!
Posted on Aug 19, 2010
4 Suggested Answers
SOURCE: I installed my sony NWZ as MTP device, but now i want to go back
Since there's no easy option in the Walkman's settings to switch back and forth between MTP and UMS, there's a little trick to un-do the MTP drivers so that the unit becomes a straight USB Mass Storage drag/drop unit. You have to go into Device Manager (Windows XP), find the Walkman in the Portable Devices group, right click, then select Update Driver. Then select "No, not this time", then Next. Select "Install from a list or specific location (Advanced) then Next. Select "Don't Search, I will choose the driver to install", then Next. (Be sure to check the box beside Show Compatible Hardware) Highlight USB Mass Storage Device, then Next. (To revert back to MTP, just do the same thing but choose MTP instead of USB Mass Storage Device.) Personally, I'd never go back to the MTP mode. Having the Walkman seen by the computer as just another USB mass storage device allows the drag/drop transfers to go much faster
Posted on May 05, 2009
SOURCE: can't get the right usb connection on my mp3 to download music.
Win Xp -> Go to Start-Control Panel - System - Device Manager - Last on the list is MTP player, click on it and select upgrade driver - i will choose myself - i there will be two options ( MTP player and USB mass storage device ) Pick Usb mass storage and then OK. Then your MP3 player is visible in My Computer
Posted on Jun 16, 2009
  • 338 Answers
SOURCE: When I plug my Sony Walkman NWZ-B135 to my USB
hi, you may have to install a driver for windows to properly recognize the walkman.
did u purchase a (mini)cd with drivers fittng your windows verson with it?
else get the drivers here:
http://support.sony-europe.com/dna/downloads/firmware/firmware.aspx?site=odw_en_GB&m=NWZ-B135
install, reboot, replug , browse via WIN explorer, add mp3's, unplug , enjoy.
good luck!
Posted on Aug 04, 2009
Sony walkman nwz-e344 freezes when connected to usb, please help
I had a similar problem with my Sony NWZ-818 today and simply pressed the reset button with a pin to reboot the player (little hole on the side) and it worked!
Aug 21, 2010 | Sony Walkman NWZ-A828 Digital Media Player
Bought Sony Walkman NWZ-A828 Player for my wife June 2009 to play whilst in her car.The unit has just packed up,absolutely no response -dead. Have tried the reset button & suggestions in the...
Not sure if yours is the same problem but mine wouldnt turn on unless it was plugged in to the computer and even then it would respond so I search sony website and found this -
Cause:
Remedy:
So i bought a usb adapter charger plugged it in and it now is back to its former self!
Aug 13, 2010 | Sony Walkman NWZ-A828 Digital Media Player
My walkman wont turn on
Not sure if it's the same problem as mine! My battery was ran completly flat and then wouldn't turn on even after being plugged into the computer and hours of it juset sayin 'connecting'. I looked on Sony's website and found this -
Cause:
Remedy:
I bought a usb adapter charger plugged it in and its back to normal!
Jul 28, 2010 | Sony Walkman NWZ-A828 Digital Media Player
Sony walkman will not recognise VLC files
Sony Walkman will accept converted video file and it's format should be MPG-4 or MP4. other format will no be played and be sure you have to put that in your "Video" folder of your Walkman.
Feb 04, 2010 | Sony Walkman NWZ-S616F MP3 Player
I have a Sony Walkman NWZ A828. How do u sync
I think ur MP4 file is in wrong resolution for sony walkman, you could try this Daniusoft video covnerter, It is already optimized for output setting for sony walkman ... easy-to-use.
Jan 13, 2010 | Sony Walkman Video NWZ-A815 Digital Media...
Sony walkman nwz a828 wont turn on
Have experienced similar issues to yourself. When I try to connect the bluetooth headphones the unit will not pick them up then, when ending bluetooth, the unit freezes. I found that pressing the reset button with a pin (on the rear) will turn the player on again. However, this has not yet solved the bluetooth connectivity issue.
Jul 08, 2009 | Sony Walkman NWZ-A828 Digital Media Player
Sony Walkman connection problems
I had a similar problem, mine wouldn’t turn on unless I plugged it in the computer and then it still wouldn’t work!
I found this on Sony’s trouble shooter -
Cause:
Remedy:
So I bought a USB adapter charger! Plugged it in and now it is working!
HOPE IT WORKS FOR YOU!
May 15, 2009 | Sony Walkman NWZ-A828 Digital Media Player
My sony nwz-a828 won't turn on
I just bought mine yesterday and after turning it off whilst the bluetooth was disconnecting it would not turn on again. Then I pushed the reset button on the back and it has started working again.
Mar 10, 2009 | Sony Walkman NWZ-A828 Digital Media Player
Sony Walkman NWZ-A828 Digital Media Player Logo
1,180 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
