No receiver came with my logitech comfort cordless keyboard secure connect Y-RAU7. How do I connect? Can't get it to work.
SOURCE: Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
SOURCE: logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
SOURCE: Logitech CE0560 keyboard and mouse; first keyboard
First put new batterys in the mouse and key board. if you don't have a tester use a flashlight. pen light. push the remote pickup. light will blinknext push key board button and the mouse next. then try it and see if it works.
sometimes do the mouse first, Then the key board
SOURCE: Logitech mouse n keyboard wont connect
whenever you chage the battery you have to syncnonize your keyboard and mouse to sensor of the reciver. you can see on the back side of the keyboard there is connect button just press it and on the recevre side also press the connect buton same setting do with mouse also.
SOURCE: cordless keyboard not working.
there is a button under neath the recerver and the keyboard, hold the button under the recever and then hold the button under the keyboard
wait for a few secounds each time u hold this button then release and it should find it self then
