I need assistance with my external hard drive and new laptop
  • 2 more comments
  • ashturman Jan 22, 2009
    Since I bought my mac I have not been able to save documents to my external hard drive. I would like to reformat the hard drive if necessary but don't know how. I've looked for a number to contact Mad Dog, the hard drive company but not bale to find a number
    reformating the hard drive OR finding a way to save documents on the external hard drive.
  • S203celest
    S203celest May 11, 2010
    do you know what format the hard drive is in?
  • Austin Evans
    Austin Evans May 11, 2010
    What exactly are you needing assistance in doing?
    Problem Solver:
  • 19 Answers
IF you are running XP, goto my computer, right click on the external and choose format
Posted on Jan 22, 2009
5508859r windows7
You do not have the best version of Win7... you have the cheap one. If you had the fancy Win7 version of even any version of WinXP you could see your files, if the HDD is good. Ask a friend for assistance and plug the USB adapter into another PC. (I have my diagnostics PC with WinXP to avoid the issue.)
Jun 27, 2014 | Gateway 5508859r - Hd 160gb Ata Ide
Iintend to change my sata hard drive to a SSD hard drive.How do I format before change
When you install Windows on your new SSD hard drive you can then transfer data from your old hard drive using an USB hard drive adapter or install the old hard drive into an USB hard drive adapter case and use it as an USB external hard drive after you have transferred your data to your laptop.
When you connect the USB hard drive adapter to the laptop, the laptop will see it as an external storage device, you can then open the various folders anf files and copy them to your new hard disk.
Apr 07, 2012 | Dell Computers & Internet
Installing 7200.10 with a Windows 7 Home Premium Service Pack 1, 32 Bit OS,. Have placed drive into an external case with USB connection and external power source. Laptop Computer does not recognize this...
it is impossible to install windows 7 to an external drive on any PC. to install it you will have to remove the drive you have in the laptop and then run the setup for windows
Apr 07, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
My Toshiba Satellite 2805 S301 USB 1 port, does not recognize my Passport external Hard disk drive. What can I do to solve this problem ? Thank you, very much for your assistance.
Hi
assuming that the external hard disk is usb
i would try this
plug in the external hard drive
then go to device manager
then hover your mouse at the top of the box
and look for a icon that says scan for new hardware
then hit the scan icon
your laptop may or maynot recognize the external hard drive at this stage
now leaving it plugged in restart the laptop
and with any luck windows will now recognize it
good luck
hope you get sorted with it
Mar 20, 2011 | Toshiba Satellite 2805-S301 Notebook
Want to replace 80Gb HDD with a bigger one. How? Do I have to copy everything from the original one to the new one before actually replacing it? how?
Before you change the 80 GB Hard Drive you can take the backup of your hard drive to the External Hard Drive or if you have any sata case so you put your new hard Drive in the sata case and make 2-3 partitions in the new drive and copy your data in the new hard drive except in first partition which will be primary C Drive for your laptop and will replace data when you install windows in it. after the windows is installed and your data is verified in your new hard drive you can clear your old hard Drive or use it as an External Hard Drive (as you like )
2nd thing which is more safer and reliable is that you make backup CD/DVDs for your data before proceed to formatting or even changing hard drives, it will be very useful and helpful for any unforeseen data loss
if you require more assistance regarding this feel free to reply to this post
Regards, BA
Jan 14, 2011 | Acer Aspire 9300 Notebook
Have reached the limits for my hard drive Can I fit a larger hard drive other than an external unit
Yes you could, but check your specificaion to see what the maximum size hard drive the BIOS in your laptop can support.
By installing a new hard drive, you need to install Windows on this hard drive, together with the Acer Aspire's device drivers, your programs and your data. This is a lot of work and time.
If it was me I would add an external USB hard drive and copy my data to this external hard drive.
The advantages of this method besides not having to re-build your laptop, you can exchange data between computers without the need to take along your laptop, you only need to take your external USB hard drive.
Nov 28, 2010 | Acer Aspire 1690 Notebook
I need to install a new hard drive .. how do I do
  1. urn the laptop over. Position your laptop in the direction so that the Toshiba label, on the bottom of the hard panel, is facing you. Your Toshiba label is positioned correctly if it is positioned on the upper-left side of the external hard panel. Remove the battery pack from the bottom your Toshiba laptop to be sure it is powered off.
  2. Step 2 Remove your laptop's external hard panel. This panel is the external plastic layer on the back of your computer to cover and protect your computer's most important hardware components. The screws you need to remove are located on the four outermost corners of the bottom of your laptop. Follow the chart guide listed in Tips for screw and screw driver compatibility and removal. Distance your screws from your workstation to avoid mixing them up and/or losing them.
  3. Step 3 Locate your hard drive panel drawer door when you have totally removed the external hard panel. It is located where the smaller door in the bottom-right panel was before your removed the external hard panel. Your hard drive will be locked into this specific drawer door and the computer itself. Completely unlock the hard drive and remove the drawer from your laptop.
  4. Step 4 Remove the entire hard drive from the drawer door. Hold the hard drive on all sides to ensure that you do not drop it. Place the removed hard drive in an enclosure area to avoid damage of any kind.
Place the new hard drive in and put it back up.
Please let me know if you have any further questions or concerns.
Thanks.
May 04, 2010 | Toshiba Satellite A105-S4334 Notebook
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
How do I transfer my laptop hard drive to an external hard drive?
Go to start and click on accesories then under system tools or in the acsesories panel you will se something that says systemp backup or backup, click that then follow the steps to do a TOTAL BACKUP to the letter of your drive. My recomendation to you is to make a folder on your external hard drive to store the backup.
Jan 27, 2009 | Maxtor Hard Drive
New laptop/new hardrive
It is a plug and play..nut you may need some of these tools..
Oct 29, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
