External Super Multi DVD Rewriter will not format disk
When I attemp to format the disk, i get an error ''write once media such as CD-R or DVD-R is not supported by this version of DLA. I am using a Maxwell DVD+RW Rewritable disk. Why is it telling me this when I attempt to format the disk?
  • 15 more comments
  • krisdogmom Jan 22, 2009
    i am formatting the disk because when i insert it i am told that i have to.
    i tried uninstalling and reinstalling the software for the burner but i still get the same issue
    it's a brand new disk and i am formatting it because it is telling me i have to. i attempted uninstalling and reinstalling the software for the burner but i get the same problem
    the disk i am using is a maxwell DVD+RW rewritable. i am using image burn however this problem is happening even if i go into my c drive and try to recognize the disk in my e drive
    no, that's great. if that's all the problem is i can use a few extra costers and take the rest back. thank you.
    i just bought the burner yesterday. i will try to get some regular DVD's and try it out.
    can you tell me how to disable the DLA? i read that on the net yesterday but couldn't find how to do it.
    i have checked through the help file again and did a search again and still cannot find info on how to disable DLA
    i have attempted to find out info on how to disable DLA but cannot find
    the problem is not happening with the program i am using, it's happening when i insert any disk. i have tried several even when img burn is closed
    sorry to be a pain, but even if i downloaded Nero, i can't get that far because my burner won't recognize the disk without asking me to format, then telling me it doesn't support it.
    i went into the drive but could not find DLA so i did the other suggestion. i did not get any prompts but i am assuming it did it? now do i do the opposite to enable?
    i will go tomorrow and buy regular DVD-RW disks and see if that will fix the problem. i bought DVD+RW because i read on a site that this was the best to use.
    I am using Windows XP. I just unplugged everything and uninstalled, reinstalled everything and I still get the asking me to format the disk and doesn't support the media error.
    Another question. i have tried going into command prompt and disabling DNA,never got a prompt so i don't know if it worked. i cannot locate it on the help files for the Cyberlink software that comes with the burner. i also cannot locate it in the burner drives itself. any other way to locate DNA?
  • krisdogmom Jan 23, 2009
    i was just connected with remote go to support but my computer quit and now i don't have a support key to get back in
    Niko ohtonen was great. He was extremely helpful and patient with me. He stayed with me until the problem was fixed. I can't say enough. I wish all customer support was so educated and knowledgable. thank you again.
  • 837 Answers
You at the very least need to change to "-R" type discs ...
Posted on Jan 22, 2009
    Sergeant:
    Champion:
  • 435 Answers
DLA stands for Drive Letter Access
Are you sure you are using RW disks ?
What software are you using to write ?
Did you use Nero ?
  • Karthik P Jan 22, 2009
    Upgrade to the latest version of the writing software
  • 679 Answers
There is something wrong with the question, first of all "format" refers to deleting the drive that one is using, format is a preestablished layout for data. You only format either a "drive", or a "re writable disk". So why you are formatting a rewitable disk makes absolute sense, unless you used the same drive to format the disk or disks on a prior occasion.It is quite common for a dvd that was burned on a drive in computer A, not to work properly in computer B's drive. I can burn a screener on a dvd and watch a perfect copy in my drive, and give it to my neighboor and he can't get it to play, either due to the codecs, or the fact that his "player" doesn't read Divx,Xvid, or some other format. My dual burner drives are sony, and won't work with mawxell cdrw's, they just don't like them. This has plagued the dvd drives scince day one. Now if you add a program that is not proprietary like the one you are using, you just throw a second variable into the mix. You may find that as mentioned a different software program, yeilds different results. I have found that once you find a disk that your burner likes to eat, you are better off just using that one than trying to figure out why it won't work, as there is probablly nothing you can do about that.
  • George Bill
    George Bill Jan 22, 2009
    Also you are better off using dvd-r disks unless you get the ones you use very cheap, I get a pak of 100 for about 15-20 dollars. So they are just so cheap that it's no big deal if you make a coaster now and again. Once you rewrite a few times the quality suffers and you more than likely aren't saving any money using them.
    Genius:
  • 2,920 Answers
What version of windows are u running on> try unplugging the dvd burner and unistall everything involved with it then shut the computer down..plug everything back in and let the computer find the rewriter on its own and then go from there. sometimes you can reformat your hard drive with it hooked up and it will find it also but try the easy way first
    President:
  • 2,559 Answers
Sounds like you're using Sonic
DLA stands for (drive letter access) and is designed for RW disk
Disable DLA in the drive's properties page
Or just drag n drop the file on the disk with windows
The discs written by DLA are only readable on windows system
with DLA or some UDF reader installed.
    Sergeant:
  • 378 Answers
Right click on the drive icon, select properties and there should be a check box to enable or disable DLA mode.
If not, open a command window and at the prompt type
dla.exe disable X (X is the drive letter) and press enter.
    Brigadier General:
  • 3,614 Answers
You should try using NERO for copying and duplicating media.
Using Nero can solved your problem here.
Nero has a application wizard that will guide you step by step doing certain project you have.
Better to use this one.
Good luck....
  • micromaster
    micromaster Jan 22, 2009
    Since you're willing to remove/disable, and fix DLA error on the media software you use.
    Here is a instruction on "How to diable DLA" (for XP)
    1. Right-click the drive name in My Computer.
    2. Select Properties from the shortcut menu.
    3. Click the DLA tab on the Properties dialog box.
    4. Click the "Enable DLA on your drives" checkbox until
    the checkmark disappears.
    5. Click OK.
    After completing your backup, enable DLA by restoring
    the checkmark in the "Enable DLA on your drives" checkbox."
  • micromaster
    • if you have a copy of NERO.better to;
    • do a complete un-installation of the current driver & the burning application you have using.
    • Install the current version of NERO that you have.
    • Do Double checking on the disc you have inserted and use, could be your are only getting the error only from that disc you have.
    • Use and test it again with a new/different disc.
    President:
  • 1,214 Answers
The issue is DLA. I would try to disable DLA and try again, or, go to Help for the software that was provided with the writer and read up on enabling /disabling DLA.
  • Mark Egan Jan 22, 2009
    IN windows explorer, right click on the drive. There should be an Option to enable or disable DLA.
    President:
  • 1,990 Answers
Welcome to Fixya! it sounds like you may have a Bad Burner.
  • 8,197 Answers
You need to use a CD-R or a DVD-R disk only. You can not use the RW cds or dvds. Sorry
    Sergeant:
  • 221 Answers
Some Memorex discs are a little dodgy, do not use format on a write once disc i.e a DVDR or CDR. format is for CDRW and DVDRW , formatting a write once disc normally messes up the disc.
DLA stands for drive letter access and is designed for RW disks, so it wouldn't be usable in this situation. The Nero version is called "InCD". If you're going to use Nero, you should probably uninstall DLA.
With Nero you should be able to create a data disk using the "wizard". Make sure you've selected DVD or CD, depending on what you're using....
  • 13,433 Answers
Why are you trying to format the disk? I would suggest you use nero to erase the contents of the disk if you have some files you need to get rid of you can get nero from www.nero.com before burning in new files.
  • 2 more comments
  • Ekse Jan 22, 2009
    Hi
    you can download nero 9 free trial and try it out for 15 days from this page
    http://www.nero.com/eng/support-nero9.ht...
    you should be able to burn your files with nero.
  • Ekse Jan 22, 2009
    Would you like if I look into the problem myself over remote support?
    http://www.fastsupport.com/269346074
    I won't be available for long, the above link will start the remote support session. use the manually download software link if you have problems.
  • Ekse Jan 23, 2009
    Don't worry.
  • Ekse Jan 23, 2009
    I've emailed you the new details.
LG Slim External Super-Multi DVD Rewriter MODEL#GP08LU10
Please explain what the problem is and include some details.
Feb 11, 2014 | LG Slim External Super-Multi DVD Rewriter...
I bought a lg ge20 external super multi dvd rewriter and lost the installation cd. anyway around it please?
search for the drivers online, all you have to do is google the product and type in drivers after wards, you then download them for free and voila it should work
Mar 30, 2011 | LG SecurDisc 20x External Double-Layer DVD...
How do I change burn speed settings on an LG external GE20 super multi-dvd rewriter?
Settings are available in the software you use for burning the disk. Please check the burning options.
Jan 03, 2010 | LG SecurDisc 20x External Double-Layer DVD...
Cannot back up DVDs on LG Super Multi 20x DVD rewriter
You definitely should call LG--your new gaget isn't working, and it is under warranty. Or try going to their website to see if they have any software upgrades--sounds like you have a bummer, and perhaps a reinstall from their website will do the trick.
Feb 07, 2008 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Computers & Internet Logo
David Payne
David Payne
