Mitsubishi Air Conditioner FDKN Series leaks water after 30 mins
Hi - wonder if you can help. i have a FDKN series Mitsubishi Heavy Duty Air conditioner. after about half an hour on 18 degress centigrade the indoor unit starts to leak water. i've taken out the filters and cleaned them which helped but now the water leaks from a different area. the air con is cool throughout. is this a loose hose or is it on it's way out?
Thanks Jason
    President:
  • 1,214 Answers
It could be one of two things -
1) The unit is not hanging level (assuming this is a wall mount, through the wall, or window unit), or
2) The condensate drain or trough to the drain is plugged/clogged/filled with trash.
Posted on Jan 22, 2009
Loading staples into a Stanley sharpshooter staplegun
There are 4 staplers in the Stanley SharpShooter family. You drop the staples on top of the "slide out loader," then slide it into the gun. See models and staple sizes below:
TR150HL Stanley Sharpshooter
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples
TR150 SharpShooter
PHT150C SharpShooter Heavy Duty Hammer Tracker
  • TRA700 series or Arrow T-50 heavy duty staples (1/4"-3/8")
TR250 SharpShooter Plus Heavy Duty Staple/Brad Nail Gun
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples and 1/2", 9/16" and 5/8" Brads
More information on the Stanley SharpShooter and a quick loading demo can be found here: http://www.expotv.com/videos/reviews/12/134/StanleyTR150HLSharpShooterHeavyDuty/185661
Sep 11, 2012 | Stanley Proto Stanley TR150HL SharpShooter...
Mr slim series ac, controller showing sp fault code. What does this mean?
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Aug 05, 2011 | Mitsubishi Heating & Cooling
Ac unit turns off after about 2 mins and has error code "E3" on panel. Unit is a Quietmaster Electronic series SM21
Hello
E3 is usally a inside fan error code.Possible the fan is going bad or the unit is not wired as it should be.
Check that your incoming voltage is what the unit calls for and thhat all wiring to the unit is correct.
Jul 20, 2011 | Friedrich QuietMaster Heavy Duty SL33J30...
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Water not cutting off at full level and leaking-Kenmore washer 80
The water lever sensor/switch is not working and needs to be replaced. IT has a air tube that senses the water lever by pressure. It the tube is clear then the switch needs replaciing,, If they is a clog, clear it and retry before replacing it.
Feb 06, 2010 | Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
Instruction manual for Whirlpool Heavy Duty Series 8 Machine
I have the manual if you need help, but the mechine is simple to use, just put the fabric conditioner in the top of the thing in the middle (inside the machine) the bleach dispenser is is just for bleach. You just get a cup of washing poweder and throw it in!
Mar 21, 2009 | Washing Machines
Heating & Cooling Logo
621 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
