Question about ASUS Computers & Internet
Try to take it back to factory setting now have a blue shreen
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
If you can't get to your desktop you can either reload the OS or you can restart the computer hitting f8 it will bring up some options - you can either use "safe mode" or you can go to "last good configuration that worked". One last resort is to insert the OS disc restart the computer hitting f2 and change the BIOS to read the CD drive and load the OS that way too
Posted on Jan 13, 2013
Ihave a 50 inch sceptre led tv has sound but black shreen i canot see the menu or anything
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 18, 2017 | Sceptre Televison & Video
For some reason mt blue ray player was saying 1080i and not p so i went into menu and changed to 1080p but tv is now saying mode not supported and i cant get back into the menu on the blue ray player to...
Try to make use of the yellow video cable, the cable that is part of the RCA cable and try to set the TV to AV1 as soon as the video cable is connected from your BD player to your TV. Turn on your Bd player and you can now set the TV to its correct resolution. Best thing also to reset oyur bd player back to its factory settings.
Oct 22, 2010 | Samsung BD-P1400 Blu-Ray Player
Player isnt turning on , it flashes blue and turns back off , but theres still a dim blue light still on
Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
or
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer’s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 31, 2009 | TruTech SMP-1 GBL MP3 Player
The GPS unit will not charge. I have plugged it into a car outlet and the light turns blue but never makes it to red. I have charged it over night and the blue light is now off but theunit will not turn...
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturers website. Make sure that you back your files up first because when you do this you are setting it back to factory settings.
Oct 07, 2009 | Nextar P3 GPS Navigation System
Getting a red, green, and blue screen when trying to hard reset
your going to have to download a recovery.img of the stock rc29 system and boot that up from that screen. This will hard reset the phone and then from there you can upgrade back to your desired rom.
Jun 27, 2009 | HTC G1
Blue dots on my lcdtv
Sometimes the voltage can be set to high by the factory. Throughout time, blue dots will appear. You will have to remove the back cover off the tv, find the "voltage Screws (they are labeled) and turn down (left) JUST A Notch. Have seen this done many times.
Pray that the panel isn't blown out or bad projector tubes. They are expensive.
Blue dots and screen flicker are VERY common on the newer LCD and Plasmas
Also, if you have a pixel setting on your TV (not sure if that one has it) Try setting it to
480p.
Jan 17, 2009 | Hitachi 50HDX60 50 in. Plasma Television
Toshiba 46HM95 46 tv
If the line is all that is showing with black on the top and bottom. This indicates a loss of vertical deflection which is caused by the loss of the veritcal sweepignal. Check the output of the vertical section of the TV set. You will need an oscilloscope, and multimeter along with a schematic.
Oct 01, 2007 | Toshiba 46HM95 46" HDTV
Only red bulb working
Tried restoring to factory settings? Only blue was working for me and it helped *shruggs*. You can try... On the remote, press MENU then 1 2 3. Hit Enter. And it's restored to factory settings :]
Aug 24, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Computers & Internet Logo
15 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
