Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
My ice maker 10amps fuse burn out when turn on the machine
Fuse keep blowing out everytime i turn it on. Can someone please help me figure out the reason why?
Hoshizaki Ice maker
Model: F250BAE
AC 120/60/1
A 6
  • Hoshizaki Master
  • 1,230 Answers
This may sound too simple. A fuse is a safety. It usually blows when the amps are higher than the fuse rating. Since yours blows immediately, I would look very closly for a pinched wire, a crossed wire, or a wire that has rubbed through. Once that is eliminated, start isolating components one at a time. Check their web site. It's pretty good. Also, their tech support line is pretty good. It's worth the wait. 1-800-233-1940.
Posted on Feb 13, 2009
Our ice machine is making too much ice. When we open the door, ice spills out - so for some reason, whatever triggers the machine to know that it has enough ice made, seems to be malfunctioning. Any...
When frost builds up on the little flapper at the top of the door above the ice maker it can get stuck. It tells the ice maker to keep making ice. Try cleaning the mechanism of frost and make sure it operates freely.
Oct 17, 2013 | Electrolux Stainless Steel Under-counter...
Hoshizaki km - 280 mah ice maker not making enough ice
A few simple things to check is the condenser for dust. Blow it out. If their is a water filter going into the unit change it. Get some ice machine cleaner and follow directions. Do these things before calling anyone out.
Aug 12, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Why is the ice maker dripping allot of water inside and not producing ice even though the compressor is running?
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 21, 2010 | Hoshizaki Freezer Commercial Ice Machines...
When the room is full stop making ice , the problem is leaking water with rush from the ice maker
Good day,
don't understand your question at all. When room is full. Full of what ??
But for know, I'll include a step by step procedure for repairing ice makers. Any further questions, please just ask..
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Mar 31, 2010 | Freezers
Blades in my Jenn Air ice maker are not turning, ice maker no longer producing ice. Model JTB1988AE.
There may be some ice buld up blocking the lever from turning. A blow drymay be a quick fix. I can't see in there so just guessing. Please leave a good thumbs up for the effort. The Raz Shack
Mar 09, 2010 | Freezers
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
254 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
