Question about Dryers
Kenmore dryer won't spin
I took off the back and the vent shoot I lifted the top back is there anything elese I have to do to get the tub out???I don't want to horse it and break it.Thanks
  • 640 Answers
Check your door switch
Posted on Jan 24, 2009
Kenmore 96272100 won't spin, but heat comes on....
Broken belt most likely. I looked at your model number and your belt number is 341241. Your actual model number with prefix is:
110.96272100When ordering parts you always add the 110. Anyway to replace the belt you first remove the filter. Then you must remove the 2 screws that hold the filter housing to the top because you gotta raise the top. To raise it you grab the dryers back side right behind each hinge and pull the whole top forward a bit while lifting on the front of the top to release the front portion and rotate it to the back. Then you will need a small screwdriver to assist in unplugging the door switch. Then remove 2 screw holding the front on and LIFT up the front to keep from damaging the bottom clips which are flimsy. Once the front is out of your way get the drum out and inspect the rollers. You can lube them with zoomspout oil, it is safe for appliances.
Dec 13, 2012 | Kenmore Dryers
I have a Kenmore Gas dryer model 11072702101 gets hot does not spin
Hi, Problem here is that your belt either came off or is broken. To get to it, remove two screws at vent. Take a putty knife and press in on the front left and right sides just under the lid. Lift up and prop. You'll find two more screws at the top of the front on either side. Remove. Front will fall out to you and lift up. Remove doorswitch wires noting where they came off of. NOTE FIRST, UNPLUG THE DRYER! Belt part number is 341241 at $20.38. To install, belt around drum, lay down with flashlite. Belt goes around motor shaft. Pull idler pulley back put belt over it and release. Reinstall cab. way you took it off. Hope this helps.
Jan 20, 2011 | Dryers
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Dryer spins no heat?
Inside the tub in the dryer itself is a heating element behind the screen. Try replacing it. Unplug the machine first though.
Aug 22, 2009 | Whirlpool LGB6300 Gas Dryer
Kenmore 800 dryer burning smell and noise.
Access is from the front. Lint screen on top? 2 screws under screen, putty knife to release front clips between top and cabinet. Top folds back and 2 5/16 screws in top corners. Lean front towards you then lift up off lower hangers. Good luck.....
Jun 06, 2009 | Kenmore Dryers
I need to change from a side vent to a back vent on my GE dryer
depending on model, the top gets lifted with a few screws under the main top,( after opening the door), lift the top then there should be a few screws holding the front panel to the sides, disconnect the light/door switch, and the front panel will release, reach around the lower portion of drum and disconnect the belt, remove the tub, from there youll see the vent pipe exiting ou though the side, simply reomve andrelocate out through theback, reassemble the unit and you all set!
Mar 28, 2009 | GE Dryers
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
F02 code - won't spin
You you probably need a pump, but try this first.  Remove the pump filter again and put you finger into the hole going to the pump and see if there is anything in it and see if you can turn the pump impeller. If this checks ok, Put filter back in and put washer into drain/spin. It should spin since you have drained the tub. If so replace the pump.
If it still doesn't spin remove the top of the washer and find the pressure switch. It will have a rubber hose going from it down to the bottom rear of the tub. Remove the hose from the switch and make sure you can blow through it. Hook hose back to switch and try drain/spin again. If washer does not spin now, you will need to do some trouble shooting with a volt/ohm meter or have a tech come out.
Post back to let me know what you find out.
Oct 12, 2007 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
Top Dryers Experts
