Question about Broilmaster Premium P4 Grill
Low flame on one side
I've cleaned the venturi tubes and the burner, but still getting very low flame on left side.
  • Bill Jan 19, 2013
    Turns out, the problem was corrosion in the valve connection to the venturi tubes. Required a bit more disassembly but got the job done. Thanks.
    Novelist:
  • 200 Answers
If your grill is older and has seen several seasons check for obstructions elsewhere the venturi is only one place for problems, check for hose kinks loose connections. If this is in a cold weather area, it maybe just low pressure. Also look for collected/ponded water in the burner tubes, especially if the flames are yellow.
Posted on Jan 16, 2013
  • Douglas Dinnebeil
    Douglas Dinnebeil Jan 21, 2013
    Glad you found the problem; when answering these questions I can usually feel if a person can handle the problem and you sounded like one of those people. Nice job!
What is a venturi tube on a gas grill
Its part of the burner which goes on the orifice is all in one just take out the burner .
Jul 20, 2014 | Vermont Casting Grilling
The center burner knob on my jenn-air grill gets hot, the far left knob is off, and the outside cover is showing burning residue
From what you have described, it sounds like the offending burner tube is partially clogged and causing the burner flames for back fire and heat the control panel. To solve this, you will need to remove the burner and clean it and it's venturi valve thoroughly. You can accomplish this with a soft bristle brash grill brush or an old tooth brush.
Hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Sep 04, 2011 | Jenn-Air Grilling
Left flame has orange flame.
From what you described, it sounds like the burner's venturi valve is clogged. Probably by a spider's nest. Remove the burner and clean it.
Hope this helps and Happy Grilling. Thanks for choosing FixYa.
Jul 30, 2011 | Coleman Roadtrip Grill LXE 9949-750
Second third and fourth burner will not light?
Susan, there are several reasons that can cause the problem you described. The first being that theburners that won't light need to be removed and thoroughly cleaned. The cleaning also requires cleaning the Venturi Valve on each burner. The Venturi Valve will look like 2 slots cut into the side of each burner tube near the burner's open end, that fits over the burner orifice. Spiders like to build nest in the Venturi Valves. Be sure to turn the gas tank valve OFF and disconnect the hose from the tank, before attempting any work on the grill. After you have finished cleaning everything, reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY (Slow motion, slow), until it is fully open.
Then light the burner farthest from the tank first and turn it to HIGH. If the flame height kooks correct, light the remaining burners the same way. If all the burners lit and the flame heights look correct, you solved the problem (with a little help).
Hope this helped you. Please let me know and Happy Grilling!!
Jul 05, 2011 | Brinkmann 810-8410-S Stainless Steel...
I have a 2005 Weber Genesis Silver propane grill. The first and third burners work fine, but the middle burner will not ignite. I have cleaned it and still no flame in the middle. I'm about to order...
Jeanne - Did you remove the burner to clean? If not. you weren't able to clean the Venturi Valve, which is part of the burner. Spiders love to get in the Venturi Valve & build a nest. When that happens it stops the gas to that burner. I suspect, that may be the problem. The Venturi Valve, is part of the burner (the open end part) that's closest to you, when you face the front of the grill. It will look like 2 slots (one on each side) cut out of the burner tube, where it fits over the burner orifice. But, you can't see it, without removing the burner. An old tooth brush works well to clean it.
Hope this helped you to solve the problem. Please let me know and Happy Grilling!!
Jun 19, 2011 | Weber Genesis Silver B Grill
Full tank, very low flow/flame, how do I clean venturi, if this is the problem. Unable tp remove V-shaped tent over burners
I suspect that your problem is related to the grill's regulator. But, there is a solution. Turn the gas tank valve OFF and the burners to high for one minute, then turn them OFF. Also, disconnect the hose from the tank and wait 5 minutes, After 5 minutes, reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, turn ON and light the burner farthest from the tank, first. Has the flame height returned to normal? If so, light the remaining burners the same way. Now, do all the flame heights look normal? If so, you solved the problem.
If it didn't solve the problem, you will need to replace the grill's hose/regulator assembly. You can get one at any home center or hardware store that sells gas grills and accessories. Take your old one with you, for comparison purposes.
The V-shaped Tent (also called a Flame Tamer) should just lift up and out. According to your Owners Manual, they are not attached in any way, They just sit there, Once they are out of the way, you can access and remove the burners for cleaning. The Venturi is part of the burner, where it fits over the burner orifice. It will have a slotted opening. It mixes the gas to air, so that you get an even, clean burning flame. Spiders love to build nest in them. An old toothbrush works well in cleaning the Venturi's .
Hope all this info was of some help to you and will get you back grilling real soon. Please let me know. Thanks.
May 17, 2011 | Sunbeam Grill Series 760
Low flame - doesn't heat enough
Hi, Patty. The low burner flame on a natural gas grill an be caused by several things.
1. The gas line shutoff valve is not fully open.
2. The burners are clogged and need to be removed and properly cleaned
3. The venturi valve(s), which has spider screens may be clogged.
The things listed above are the top 3 reasons for the low burner flame problem on a Natural Gas Grill.
To help you accomplish the cleaning of the burners and the venturi valves, I have included a link to your Owners Manual, that you can download & print for future reference. It has detailed instructions and diagrams in the Maintenance section, that will show you how to accomplish this.
http://help.weber.com/manuals/pdf_files_2011/Gas/Spirit%20ES%20Series%202007newer/OwnersGuides/Spirit_210310_NG_OwnersGuide_89961_022811.pdf
Hope this helps you to solve the problem. Please let me know. Thanks and Happy Grilling!!
May 14, 2011 | Weber SPIRIT E-210 (NG)
The side burner flame is always yellow and does not adjust high to low. Always high & yellow. How do I adjust to get the hot, blue flame
If your propane tank is not just about to run empty, then you can probably thank little spiders.
When a gas burning appliance sits idle for a week or more outdoors, spiders like to build nests in the venturi tubes (that's the tube with the holes in it where the combustion air gets sucked in). This changes the way the combustion air mixes with the gas and causes the gas to not burn completely. The incomplete combustion is not very hot, and so the flame appears yellow. This is not efficient. It wastes gas, is too cool for grilling steak and creates soot residues. This is very common on gas grills (bottled propane or piped natural gas). It also happens to pool heaters.
Fortunately, the fix is easy, and you usually don't need to take anything apart. Get a piece of stiff nylon string from a weed-wacker, about 12 inches long. With the burner cool, push the string into any hole in the venturi tube and spin it by rolling it between your fingers. The spider nests are sticky (made from the same stuff as spider webs) and they usually adhere to the nylon string.
Not sure what the venture tube is? It's going to be between the valve and the burner. The valve shoots a stream of gas into the venture tube through a pinhole nozzle called an "orifice". You can do a Google image search for BURNER VENTURI TUBE to see lots of different types. Every gas burning appliance uses some form of venturi tube.
Aug 17, 2010 | Garden
Low flame even on high
Check the propane regulator if equipped
Check the gas orifices - they may be carboned up and require cleaning
Check the venturi tubes (the tubes that go over the gas jets) - they may have spider webs or other insect cocoons in them
Make sure the gas valves work correctly (high/low)
You mentioned that you replaced the burners - are they correct for the unit and installed ok?
Make sure the gas valve on the propane tank is opened all the way
Mar 22, 2009 | Grilling
Gas grill prob.
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
Sep 01, 2008 | Grilling
Broilmaster Premium P4 Grill Logo
136 people viewed this question
Top Broilmaster Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Broilmaster Grilling Expert? Answer questions, earn points and help others
