Computer wont turn on
My little brother press the on button while computer was not fully shut down. it never came back on. i open it and whenever i try to turn it on the fan slightly move once and the AC adapter goes off. i have a couple of ideas on what might be wrong with this but your opinion will greatly help. what do you think is wrong and how can i fix it ?
  • 1 more comment
  • Leigh Perlmutter
    Leigh Perlmutter Jan 13, 2013
    It might have "moved" but it is not running, yes? THe capacitors on the motherboard frequently have some residual power in them to "move" a fan or even light a light briefly!
  • bd126981
    bd126981 Jan 13, 2013
    i opene the computer and yeah i think its still cycling ..however i think the m810 dc in cable isnt passing on enough electricity to the motherboard...iwhenever i turn it on it sends a small amount that makes the speaker make a small "bop" then the AC adapter green light goes off....can you help me with that? would it be the m810 ..or something else with the motherboard
  • Leigh Perlmutter
    Unless there is some damage from rough handling I doubt that the cable is bad, but check out the end connectors and the pins it connects to. A bent pin or pushed in pin could give thaat effect.
    Genius:
  • 1,669 Answers
Check to see if the on/off switch is still cycling. Baby fingers sometimes push the buttons so far in that they can't pop out again. Change the switch if you can't get it to work!
Posted on Jan 13, 2013
  • bd126981
    you think so? why would the fan move then? help me please?
SOURCE: Dell Dimension 5150 starts up on its own!!
Hi All,
I had the same problem - shutting and restarting over and over again. When called Dell, they said it is most likely the motherboard and will need changing. I personally suspected that it has something to do with the power supply.
I was right. I replaced the 305W power supply with a 370W one. Problem solved with just £25 and a trip to Maplin.
Let me know if this helps.
Posted on Jan 24, 2009
  • 50 Answers
SOURCE: Turn on Pc, Continually beeps 6 times then shuts down
it seems that your memory card is out of place. open the pc, reseat the memory, and that should be ok.
Posted on Jun 15, 2009
knatcal
  • 53 Answers
SOURCE: I have a EMachine T6534 which won't start. I shut
Most computer repair shops have a tester that they can hook up to your power supply. You can also purchase one for yourself, they usually run $25-50, it may be viable to purchase one if the shop will charge that much to test.
Posted on Sep 02, 2009
SOURCE: I have an HP touchsmart IQ790uk, error message: cpu fan failed
You are out of luck my friend Hp must be the worst people on earth to buy a pc from i will never get a product from them again
it would seem that the fan you need is a sunon and they only made this fan for HP so you can only buy it from an HP registered seller and thier is only one that does this fan however you can not just buy the fan you must buy the whole cooling system and in the UK it will cost you £280 before VAT and shipping
phone this number 01925251697
they will give you all the info you need
good luck
Posted on Feb 26, 2010
lserni
  • 466 Answers
SOURCE: Computer frequently shuts down unexpectedly/ fans very noisy
You might have a cooling problem due to a fan malfunction. It is not clear whether it's the power supply fan or the CPU fan; in the latter case you might also have a thermal coupling problem. The symptoms you describe certainly seem to point to such.
My advice would be to replace the fan (or the whole power supply; you might also want to purchase a "Silent Power" unit for quieter computing). If it's the CPU fan and you are comfortable with, or know anyone comfortable with a bit of PC servicing, you might want to also unmount the heat sink from the CPU and replace the thermal paste between CPU and heatsink. Clean the heat dissipator (the black metal grille over the heatsink) with hot water and a bit of soap and dry thoroughly, or wipe it energically with a dust brush, before mounting the new fan on it.
Posted on Feb 28, 2010
Testimonial: "That should do the trick"
I have a Gateway Solo Pro 9300 laptop. Whenever I shut it down, the power light turns orange, and the backlight is still lit. Other than that, the hard drive and fans turn off. What does this mean. How can...
That means the computer is in 'Sleep' mode. To completely shut down the laptop, you can press the power button once and it will do a normal shut down.
May 08, 2011 | Computers & Internet
At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
Apr 03, 2010 | Compaq Presario 5000 PC Desktop
Computer well not boot
The computer may have done a routine software update that automatically reboots the PC when complete. HP is known for this. If it fires up when you turn it on, no worries. If its DOA then thats another issue. Best regards.
Aug 22, 2009 | HP Compaq Presario SR2011WM PC Desktop
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
My Philips Freevents sometimes wont turn on and when it does it shuts down without me shutting it down
If the computer shuts down with no warning then it could be your power supply is faulty, which explains it not turning on sometimes. Just check the back of the PC to make sure it is plugged in properly (TURN OFF ALL POWER TO THE PC BEFORE CHECKING). if this does not help, get it looked at by your local qualified computer technician if you don't know how to replace a power supply. Also, a connection to the motherboard to the Power button may have a fault somewhere, which also means take it in for a look if you don't know what to do. If it does give you warning with 'Windows is shutting down' it can be the following things.
1- Your power button on the PC is sticky and movement causes the computer to think you have pressed it and so it shuts down, which can also explain why it wont turn on all the time. Just use some household grease cutter and spray it on the outside of the button, turn off the power supply to th computer and press it in and out a few times to get it back to working order
2- A Virus is shutting your computer down on you, but this does not fully explain why it won't turn on but this could be an effect of the virus so use a virus checker to see if this is the case
3- Your computer system is getting too hot and usually a computer has setting which shuts it down before permanent damage happens. Check your PC fans to make sure they are running and feel around where your computer sits to see if its warm or hot and replace the fans or put your PC in a cooler environment
Hope This helps
Nov 18, 2008 | Computers & Internet
I cant get my mouse pad to work after turning it off in control panel. Im on windows vista and on a lap top. Curser wont work so cant go back in to turn it on again.
Hold the Alt key and press F4. Press Enter to shut down the computer.
Once it's shut down, press the POWER button on the computer's system box to turn the computer on again and reset it back to normal.
Hope this works.
Jul 20, 2008 | Acer Computers & Internet
Broken??
If the computer is only a couple weeks old, you need to cantact Acer for technical support under the warranty.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7293&areaid=7&website=AcerPanAm.com/us
Click the ESupport link in upper right corner
Jul 06, 2008 | Acer Aspire 5315 Notebook
My xbox wont stay shut
push it in until it closes .i know it sounds crazy but it worked for my ps2. i dont know about xbox though.
Nov 13, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
