Question about Boating
Need to reassemble an 6hp johnson fuel pump and need to know correct gasket order
It's a 1977 6r77m motor
5 Suggested Answers
  • 10865 Answers
SOURCE: 6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Posted on Sep 16, 2009
  • 53 Answers
SOURCE: need exploded view of 14 hp johnson outboard motor fuel pump
Need year mode?. But you can go to this website and get all you need. Don't worry I'm not a salesman. I just use this site for my own business. www.crowleymarine.com. click on parts catalog then follow directions.
Posted on Nov 04, 2009
  • 46207 Answers
SOURCE: i need to change a water pump on a johnson 6hp
unbolt lower unit and you will be right there . shift rods vary so check where it is and how to unhook.
Posted on Apr 25, 2010
muffteck
  • 202 Answers
SOURCE: how to adjust timing on johnson 6hp outboard motor
look at a manuel i think it is automatic in the switch no manuei adjustment get it timming through the cd like some of the mercks
Posted on Nov 11, 2011
What is the plate behind the carby with fin like things on Johnson 6hp
Sounds like your describing the reed valves. They open on the intake stroke to let the air/fuel mixture into the cylinders.
Jan 31, 2017 | Johnson Boating
What is the gap setting for a champion 910 spark plug for a johnson 6hp four stroke outboard motor
if the plug is a standard plug as used in a car , it is the wrong plug
the plug to use is a multi point plug or anti foil plug and the gap is preset
single point plugs such as used in cars motor mowers etc , foul up from the oil / fuel mixture that deposits carbon across the gap so the use of a multi point anti foul plug is recommended in outboard engines
if you persist , for an conventional magneto /coil operation .025" and a later electronic ignition .050"
Sep 30, 2016 | Boating
I have a 60hp Johnson outboard motor, ran fine in a barrel of water put it on the boat. Put the boat in the water& the motor started but had no power it wouldn't rev up & it wouldn't move the boat& then it...
Check fuel pump diaphragm,could also be stuck needle and seat in carburettor.dont think it is head gasket,would not cause fuel to come out of exhaust.take off carb cover squeeze primer,if fuel comes out of front of carb it is needle and seat.also check if choke is not sticking
Aug 14, 2014 | Boating
I have a 50hp johnson outboard the motor is turning over but I dont seem to get a spark to the plugs
would this help
Primary cause of hard cold start: operator error.
Open gas tank vent, pump primer bulb until it is firm, raise hi-idle lever full up, push the key in and hold it in while turning it to "start".
If you can flood your engine with the primer bulb, then your carbs need rebuilding. Pump the bulb until it is firm - that fills the carb bowls - they have a float valve that closes when full. This is true of every carbureted 2-stroke outboard ever made.
"Pumping the throttle" is useless - these are not automotive carburetors - all it does is open and close the butterfly valves.
Your motor does not have conventional choke plates; instead it has a primer solenoid, which opens a valve and allows fuel to drain into the cylinders to richen up the mixture for cold starts. You should hear the solenoid "click" when you push the key in.
Bad compression leads to hard cold starts - you should have at least 100 PSI in all cylinders, and the lowest needs to be within 5% of the highest.
If you have good compression and spark on all cylinders, the primer solenoid actuates, and the fuel line holds pressure, then you need to remove your carburetors, dissasemble, soak overnight in carb cleaner, blow out passages with compressed air (or aerosol carb cleaner), reassemble with new kits (including new o-rings, gaskets, and float valves & seats), reinstall, link & sync, and adjust slow-speed mixture
Mar 15, 2013 | Boating
Johnson 6hp outboard engine fuel pump diagram
Here is where you can get a service manual, they have a lot of info you might need...
Johnson Evinrude Manuals 1917 2007
Jun 11, 2012 | Johnson Boating
I need to change a water pump on a johnson 6hp outbord moater. modle no. 6R-70B
Mar 15, 2010 | Light Outboard Motor Boat Bass Fishing...
Sep 16, 2009 | Boating
My 1976 Johnson 6hp outboard idles OK,but won't rev up to power under load when I open the throttle. When I checked the spark pluge, I found the top one to be wet with fuel mix, but the bottom one was...
check for spark against the block. they sell a test kit, i think harbor freight sells one, where you hook it in line and should be able to see if it is firing or not.
Jul 29, 2009 | Boating
Water coming out of the transmission lever grease fitting
The water discharge hose goes through the case in back of the motor. The hose or fitting could be broke or loose. If not the discharge then the water pump is leaking.
Apr 07, 2009 | Boating
Boating Logo
90 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
