Question about Samsung PN58B550 58 in. Plasma HDTV
Green and purple horizontal lines
I bought a surge protector to "ground" the coax cable to get rid of lines which worked but then couldn't get about a dozen HD channels. Had nothing to do with cable box. Bought a new surge protector and same problem happened. So now I have coax cable directly into box again and lines are back. How can I get rid of lines and have all my HD channels work?
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
  • 304 Answers
SOURCE: Samsung LCD tv no sound from one channel only, no
First try viewing regular programming and see if you have audio on both channels. If you do not then go to the user menu and make sure that the chim function is turned "on". Then turn off the tv and listen for the down chime coming from both speakers. If you only hear the chime from one speaker then the Aidio circuits are bad on the Main bd and needs to be replaced.
Posted on Jul 16, 2009
redgs95
  • 15 Answers
SOURCE: 50 inch Plasma Samsung HP-T5054 appears to have power however...
check the power inverter on the power strip. also check the caps on the board and if any of those caps have a round top it is bad and needs to be replaced. i hope this helps.
Posted on Jul 28, 2009
  • 257 Answers
SOURCE: samsung lns4051d 40in has horizontal lines across
This sound likes the incoming signal is week. You should play a DVD player to see if the problem stays same or not.
If you try all sources ie HDMI, AV Component, etc...the TV show the same problem. There are two possibilites: T-Con board or main board need replacing. You should need technician to figure out the problem. Hope it help.
Posted on Aug 13, 2009
Testimonial: "Thank you! I'm a do-it yourselfer. Good info!"
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
Belkin how to connect cables to a belkin pureav 4 way surge protector to tv and dvd
This surge protector takes the power cables of the TV and DVD player. In addition, it will take the coax cable in and has a coax cable out for surge protection on your cable provider's incoming cable.
Apr 15, 2014 | Computers & Internet
TV has green lines on the screen. Was plugged into surge protector. When this happens have to plug TV into wall to get it to work.
HI,
It could be a faulty ground connection in the surge protector. Verify it using the following procedure or replace with a different one.
Procedure
good luck,
mrwindex
Nov 08, 2009 | Panasonic CT-20SL14 Television
Purple and green rolling lines after lightning storm
I have exact same problem...other posts have cited improper grounding from the Cable...which makes sense as the problem does not occrr with the DVD...I have not figured out how to fix it though...
Aug 12, 2009 | Panasonic TH-50PX75U Plasma HDTV
Comcast Causing Purple/Green Hum Bars
this is normally caused by voltage on the coaxial cable which simply can be solve by a surge protector with a cable in and out.. but this is just a way to passify the issue. More than likely there is a bad ground either in your house or on the comcast line
May 06, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Purple lines bleeding over picture contors on plasma tv
I just had this problem with my pani pro plasma display (th-42ph9uk). Tried new wires, new cable box and had no luck. So, I went ahead and scheduled a service call.
Then, I bought a new surge protector - just a simple one from Radio Shack, that allows you to run the cable (coax) through it as well and it solved everything. Turns out it was a ground loop problem - and basically had nothing to do with the plasma.
Give it a shoot. simple fix for a very annoying problem. hope it works
Aug 21, 2008 | Televison & Video
MY Samsung DLP TV Has Green/Purple Lines
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 08, 2008 | Samsung DLP HL-P5663W 56" TV
Noise and horizontal line
Very easy Fix, The problem is the cable box is not grounded properly. (not your fault) Go to the Local store and get a Plug adapter, just to change the TV plug that goes into the wall or surge protector from 3 to 2. Trust me on this....
Best regards
CircuitCity
Nov 29, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung PN58B550 58 in. Plasma HDTV Logo
27 people viewed this question
Henry  Thomas
Henry Thomas
