Question about GE JP356BMBB Black 30" Built In CleanDesiElectric Cooktop with 12"
My GE jp356bmbb electric cook top is not turning on. The power is hooked up and I have electricity to the stove but none of the burners are coming on. If you hold the nob between high and off the on light hardly shows .
  • 213 Answers
SOURCE: We have a 5-burner GE cook top/ The igition for the center burner continually fires.
the spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Posted on Nov 22, 2007
  • 1214 Answers
SOURCE: GE profile performance electric cook
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Posted on Jan 23, 2009
appldoctom
  • 311 Answers
SOURCE: Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Posted on Jan 30, 2009
garing
  • 998 Answers
SOURCE: Hi! GE electric stove light won't turn off when
replace the switch
Posted on Aug 06, 2009
  • 457 Answers
SOURCE: I have a GE 30 inch electric cook top. 2 days ago
sounds like the heater coil is defective or switch is bad. service tech is needed for this. components has to be checkjed properly.
Posted on Feb 24, 2010
Testimonial: "Thanks, This tip was very helpful."
How do I plug back in the GE stove top burners after unplugging them?
The two leads from the burner fit into a socket in the stove top. It's a bit tricky to get it in just right. If the three metal "legs" on the burner fit snugly into the three slots on the stovetop you did it right.
Aug 26, 2012 | General Electric Ge Stove / Oven / Range...
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Red light on cook top remains on always.
Don't really need a wiring diagram, although there may be one inside switch area. (make sure to put it back again if it is there) Will need the full model number to get you the part number you need. (model number usually on a sticker near where the electrical wire enters the cook top)
Turn off power to cook top. Open cover to switches. Pull two "pilot" (usually smaller spade terminals) off the switch for the right front burner, and insulate each with a bit of electrical tape. Turn power back on to see if light now off. If yes, replace that switch. If no, replace those wires and repeat procedure with the next switch until you find the bad switch. Send a comment if you need additional help.
Feb 13, 2009 | GE 30 in. JP326 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Electric stove top
Follow the wire, It should go to a junction box within 4 feet. It may be behind a cabinet. Remove the box cover and unscrew the wire nuts. It usually uses armored wire and this is clamped to the box. Release the clamp . Turn off breaker or remove the 2 fuses first.
Jun 08, 2008 | Cooktops
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
May 01, 2008 | GE Profile JP930 Electric Cooktop
Electric stove
if it is a DOUBLE element burner you might of turned on the second element. double elements the reverse direction turns on.
if single you have a short or a bad switch
Apr 09, 2008 | Cooktops
GE JP356BMBB Black 30" Built In CleanDesiElectric Cooktop with 12" Logo
29 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
