Question about M-Audio Studiophile BX8a Speaker
M-audio bx8a not loud enough?
Here is the problem. Month ago one speaker started to have a distortion in sound , it was random. So i took it for repairs. Finaly ive got the speaker back, but with some problems. The speaker is filled with somekind of stuffing????
Well both speakers sounded practicaly the same in terms of loudnes at the same calibration setting. After the repairs..the "healty" speaker is twice louder at the same calibration setting than "repaired" one...
And another thing that i almost forgot...When the calibration buttons are on the same setting ( lets say 12 o clock ) the noise from the speakers is practicaly the same ( loudness ), so shouldnt be the music the same?
tnx for help!
cancerags
  • 36 Answers
SOURCE: Connect BX8A speaker to PC
Hello waddragon,
First, let's start with the BX8a. Those are powered speakers (built-in amplifier in each) so, you do not need a pre-amp. What you need to connect them to your computer is a 3.5mm to XLR cable OR a 3.5mm to 1/4" TRS cable, also known as 3.5mm to two 1/4" mono plugs (the back of the BX8a has inputs that accept either type). Cables are available at most any electronics stores. Make sure you buy a long enough cable to run from the back of the computer to where the speakers will be.
It sounds that you only have one BX8a which means you'll be listening to only one channel of the stereo output. In any case, make sure before connecting the speaker(s) to the computer that speaker power is off and volume control is at minimum. Connect the 3.5mm cable end to Line Out 1 jack of the X-Fi sound card and either the XLT or TRS ends to the speaker(s) input(s). Play some audio content on your computer, turn on speaker(s) and slowly increase volume to a safe level. Everything should work fine.
Let me know how it goes.
cancerags
Posted on Dec 28, 2007
robotek
  • 1512 Answers
SOURCE: Audio
Hi rocroc, first, check to see that all the screws are tight that hold the speaker drivers, and panels in place are tight. Loose screws can make a monitor rattle. Access to the internals in powered monitors is often by a rear connection plate, or through the from by removing the woofer. A cosmetic band is often used around the woofer to hide the screws. you will need to carefully remove this before you can get to them. If all the screws are tight, then you may have a problem with the driver itself. best way to check is by doing an audio sweep from 20hz to 5khz with it sitting on the benchout of the box. If it has any weird noises, the voice coil assembly may be loose or damaged. If the "pumping" problem happens with no signal, then you may have a problem with the internal circuitry. Check for loose bits first, and get back to me here, happy to talk more about it.
regards
Graeme
Posted on Mar 07, 2008
JULIANFIX
  • 975 Answers
SOURCE: BX8A studiophile monitors distortion problem
it could be a loose connection or the cone is cracked inside , the only way to find out is to open and take a look inside ,check the connections , the 2 wires from box to speaker, ALSO CHECK where the cone meets with the magnet , hope this helps AJ
Posted on May 14, 2008
robotek
  • 1512 Answers
SOURCE: woofer not working on new bx8a speaker
Hi ermo
Your new speakers are BiAmped, and if a woofer is not working then it is probably a fault in the amp or connection for that woofer, or the the woofer itself has a problem. If they are brand new, I suggest you take it back to purchase point to get sorted out. There is nothing that you can do that will NOT void your warranty. If you do not have a warranty, then get back to me here and we can work through the problem. Cheers
regards
Graeme
Posted on May 25, 2008
  • 60 Answers
SOURCE: I found one of my BX5a monitors buzzing loudly
it sounds like you have a strong electrical surge is there alot plugged into your outlet? a fridge? microwave? Laptop?
Posted on Mar 14, 2010
I HAVE THE M-AUDIO SP 5B MONITORS AND ONE OF THEM WON'T THROW OUT ENOUGH POWER TO PUSH THE SPEAKER WITHOUT MAKING A BUZZING DISTORTED SOUND. IT'S NOT THE SPEAKERS BECAUSE I TESTED IT ON THE OTHER SPEAKERS...
It sounds like the speaker might be "blown". If you take the cover off... looking at the speaker, does the speaker's cone have a crack? Or is it separated around the edge... if so, it is blown. Most of the time this can be fixed... but you will have to take it someplace.
Is there a company in your area that professionally installs car audio systems? If so, they usually can repair speakers, or they will know who can.
Mar 02, 2011 | M-Audio Studiophile BX8a Speaker
I have a pair of m-audio bx8a deluxe monitor speakers. I need to know how hook my iPhone up to them or just one of them. I tried using a adaptor and plugging into the trs input but the music is distorted....
The conection you made is not quite right. This is because the TRS (and the XLR) connectors at the back of the BX8a are for balanced signal. You have to use either this cable or connect both middle and ground point of the TRS connector at the ground. In other words the ground from the ipod must be connected with ground AND middle ring of both BX8a and the ring of the ipod must be connected with on BX8a TPS tip and the tip of the ipod must be connected with the other BX8a tip. I don't know if you are familiar with soldering connectors, in this case post me back to make a schematic for you with the connections.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Feb 17, 2011 | M-Audio Studiophile BX8a Speaker
My left speaker is loose
The symptom you are describing is exactly what is known as a "BLOWN" speaker or the voice coil has "shorted", this is caused from the volume being up to loud, heating up the voice coil and frying it, in the future if the bass/sound is distorted then turn the volume down just enough to stop the distortion and this will save the speaker.
As far as getting a replacement speaker, you will have to contact the manufacture to get a replacement.
Good Luck !
Apr 21, 2010 | Philips FWC577 CD Shelf System
M-audio Bx8a's one monitor very low volume compared to other.
NO, I HAVE HAD TWO PAIRS OF THESE SPEAKERS. tHE SECOND PAIR I HAD FOR TWO WEEKS AND SAME PROBLEM, EITHER LEFT OR RIGHT SIDE GOES OUT.
I Insert a compressor on the stereo buss to protect the speakers from transients and they just loose the woofer everytime.
They cannot be trusted, DONT WAISTE YOUR MONEY.
Sam J.
Chief Audio Engineer
AudioWorkShop Studios
www.audioworkshopstudio.com
Jul 29, 2009 | M-Audio Studiophile BX8a Speaker
Humming BX8
Hello docjgg,
This sounds like it may be a loose connection (ground) generation common mode noise or it may be a capacitor in the power supply going bad and not providing enough filtering of the AC voltage (allowing for 60 cycle hum). You should get a schematic for the speaker or just take some rule of thumb measurements of the power supply output, with an oscilloscope (you will be looking for ripple voltage, what you could do is use one of your good speakers as a comparison of good to bad.
If you do not want to work on this yourself, you could take the speaker to any TV repair shop or audio repair shop.
I hope this helps
Thank you,
Shuttle83
May 25, 2008 | M-Audio Studiophile BX8a Speaker
May 14, 2008 | M-Audio Studiophile BX8a Speaker
Hello waddragon,
cancerags
Dec 28, 2007 | M-Audio Studiophile BX8a Speaker
Loud and strange noises
The built-in speaker amp or the volume switch may be going bad on you. A quick test is to disconnect the speaker set and replace it with a headphone or another working speaker set. If it behaves normally then the problem is in your original speakers, if not then you may have software driver issues or less likely an issue with the sound card. Let us know what you find out.
Jul 28, 2007 | Dell 5650 Computer Speakers
Speaker issues
This is a duplicate posting, click on the following link to read the active post: http://www.fixya.com/support/t161863-loud_strange_noises
Open Questions:
See all M-Audio Studiophile BX8a Speaker Questions
M-Audio Studiophile BX8a Speaker Logo
91 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
