Question about Pacific International Pacific Evolution Men's Mountain Bike 26" 18 Speed
I need an owners manual for a pacific evolution bike
My bike will not go into 6th gear
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Are you sure the derailer or sprocket are not bent? The next thing if not that is the cable itself is it pulling the delairer to release the gear from the gear it is in? one final is the bike just may not go into 6th gear depending on which gear you have the front sprocket in because it would pull the front sprocket to far past the crank space where the pedals are at.
Posted on Jan 16, 2013
Rear hub assembly pacific evolution
Unfortunately, there is only one last ditch effort to free up that freewheel. The following link takes you to a very simplified diagram of how a freewheel works : File Roue libre cliquet svg
What's happening in your instance is that the pawl, colored red, is not engaging the outer teeth, possibly due to corrosion, or age. What you can do is use a penetrating oil to get inside the mechanism to try to free it up. In the following link, you will see a freewheel that is most likely similar to yours: Shimano Hyperglide Freewheel
You want to add oil to the edge of that inner ring that says "Shimano" (yours may not say that), while spinning the cranks to draw the oil in. Hopefully, after a while, and maybe a lot of oil, the pawls will free up and start catching.
Mar 21, 2014 | Pacific International Pacific Evolution...
Brand new bike gears won't engage. The gear shift is on 6 and the chain is on the smallest cranks.
the derailleur cable is too loose. Shift the shifter into the smallest cog, make sure the chain is on the smallest cog. The derailleur cable will most likely be very slack now. At the rear derailleur, there will be a nut or a allen bolt pinching the cable to the derailleur. loosen this, pull the cable finger tight, tighten the nut or bolt again and then try shifting again. You can dial it in using the barrel adjuster on the derailleur or the shifter.
Oct 15, 2011 | Pacific International Pacific Evolution...
What size bolts does the rear frame take for mounting a bike rack
Since you probably need to go to a hardware store to get them anyway, you could just take the bike in and guarantee a good fit. They're probably metric. Make sure they're long enough. Get washers.
May 23, 2011 | Pacific International Pacific Evolution...
The gears will not change at all. It seems like the part that you twist to change gears is seized on both sides. This is causing the bike to ride very slow.
Actually, it's causing you to have no gearing options. If you were Lance Armstrong the bike would move fast ;0) even with a flat tire.
http://www.parktool.com/blog/repair-help/shift-levers-shifters
Crimped, corroded shifter cables can prevent accurate shifting. I'm thinking you need a bike mechanic to look at it.
After it's all fixed you might want to view some resources concerning shifting, braking and general riding skills. It's all out there.
Feb 23, 2011 | Pacific International Pacific Evolution...
I bought a 2009 pacific 24'' girls bike. did not receive owners manual. What does 18 speed torque drive twist shaft mean? and how does it work?
HI,
In addition to having been a bicycle mechanic and enthusiast for a great number of years, I purchased the same Pacific bike for my daughter.
The torque drive twist shaft, is their overly technical name for the twist shifter that one uses to change between gears. Some bikes have a toggle shifter, which is a little lever to change the gears. These bikes have a shifter that twists on the handlebar to switch through the gears.
By the way, the manual would not have been helpful. They give a generalised manual with all of their bikes apparently, that have non-specific information about general assembly, lubricating different parts, tire inflation, and bike safety.
We got ours direct from the factory, and the manual that came with the bike was simply the most unhelpful publication I had ever seen.
So there you have it. If you have any additional questions, please write back.
Thank you for using FixYa.
Sep 09, 2009 | Cycling
Pacific International Pacific Evolution Men's Mountain Bike 26" 18 Speed Logo
357 people viewed this question
Top Pacific International Cycling Experts
Michial Gueffroy
Nathan
dante
Are you a Pacific International Cycling Expert? Answer questions, earn points and help others
