Question about Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt
Why does my Line 6 Spider 3 15w amp randomly go to flange?
No matter the setting I have it in, the flange kicks in and I have no control over it.
  • 109 Answers
Provided that you're not using any external devices, and plugging the guitar directly into the amp, this sound solely like an internal switching problem. Meaning...it will require service. Chips can get faulty like that sometimes. If you're using any external pedals, remove them and see if it happens. If not...the pedal(s) are to blame.
Posted on Jan 14, 2013
paulm10
  • 73 Answers
SOURCE: line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Posted on Jul 09, 2009
  • 1137 Answers
SOURCE: My Line 6 Spider 3 75 Watt amp is having trouble.
Try this site:http://line6.com/community/community/support
Posted on Aug 13, 2009
  • 5603 Answers
SOURCE: Hi My line 6 spider 111 30 has a problem
The hum MIGHT be directely from teh power transformer vibrating the chassis RATHER than via the speaker. This is an important detail to investigate.
Posted on Jan 14, 2010
  • 88 Answers
SOURCE: I have a line 6 Spider III, 30, 30 watt. when I
possible software problem
Posted on Feb 04, 2010
  • 1137 Answers
SOURCE: broken knob (phazer) need a pott for it ...Help !!
Check their site here under Support:http://line6.com/community/message/59307 if you do not feel comfortable servicing it yourself. They will be able to tell you where the nearest service center is and if you can't get it to one then the specs for the pot. Any good electronics supplier should be able to sell or order you the exact replacement you need. The trick is providing them with the technical info they need. If you or a friend or a nearby reputable electronics service perso can disassemble the amp and unsolder the broken pot from the circuit board it is quite easy to take it to a supplier and have them match it.
Posted on Apr 16, 2010
My line 6 lowdown 750 keeps cutting out when i play a low b on my bass
Protective circuits kicking in. You may be overdriving the preamp to a clipping condition the amp sees as a problem. If it is under warranty, contact Line 6 and see if this is normal for this amp. It should not be, but you never can be sure.
Apr 26, 2012 | Line 6 Music
When I play my Line 6 Spider III Amp (Stack), the volume and gain output is very weak even though the settings are maxed, and the tone is very strained and sharp. It basically lost all of it's kick.
Poor contacts at jacks can cause this... it results in the contacts acting like a small capacitor passing only the high frequencies at very low level.
Power amp inout jacks are notorious with switch contacts that pass the preamp signal to the power amp if the power amp input isn't used.
There are many other possibilities and only hands on troubleshooting will determine the cause.
Jul 23, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
My line 6 spider iii30 30 watt amp works with
There is likely a switch contact on the headphone jack that routes the amp output to the speaker. These jacks on most music stuff are JUNK and the contact may not be closing.
If the spring contact is bent so it won't close you can bend it to contact BUT the springyness usually is gone and the contact will be marginal.
May 10, 2010 | Line 6 Spider Iii 30
Broken knob (phazer) need a pott for it ...Help !!
Apr 08, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Don't need a repair. I need a manual. know where I
Line 6 has the manuals on their site.
The Spider III 15 is in two parts: part 1 and part 2
The first is the manual, the second is the sample settings.
Both are PDF files.
Jan 20, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Line 6 spider III 15 watt sound problems
Paul
Jul 04, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Open Questions:
See all Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Questions
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
65 people viewed this question
Top Line 6 Music Experts
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Line 6 Music Expert? Answer questions, earn points and help others
