Dear all, i have a problems with the monitors, with the horizental transistor C5929 , and mosfet sss7n80a, and P9NB50FP , and i could not find these parts in my country , i want to know the equivalant for these transistors , and thank you very much
  • 585 Answers
You can find nearly any available datasheet at www.alldatasheet.com Hint: the P9NB50FP is a generic and should be from more than one maker. Drop the SSS and search for the generic 7N80A, as the SSS is a specific manufacturer. Add a 2S to search for 2SC5929. Once you know the parts ratings, you can cross them on the site by searching for similarly rated parts. There should be many equivalents.
Posted on Jan 23, 2009
Irf630
It's hard to tell what the problem is without looking at the device itself. A straight-forward solution would be to replace IRF630 with a different MOSFET, that tolerates higher voltages. However, this is not an optimal solution because the problem might be caused by a malfunctioning power supply, a bad filter, etc. It would be of greater help if you provided voltages from the transistor's pins.
Jun 20, 2013 | LG 500LC Monitor
Screen horizondally pulled right side and screen rolled to left side
hi,
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
ok
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
Equivalent of transistor c5929
2SC5929 - Si, NPN, diffused CRT Horizontal Deflection Output Transistor.
Producent - Matsushita/Panasonic
(Absolute Maximum Ratings)
IB=5,5A
Ic=12A
Icpeak=22A
VCB0=1550V
VCE0=600V
Ptot=50W
similiar tx; C5931, C5129, C5587, C5909
Aug 05, 2010 | Computers & Internet
LG 17" 700E CRT MONITOR MOSFET 2N10 IS Immediately BURN OR SHORT WHEN SWITH ON THE MONITOR..
this might be the problem of the disk capacitor of value 2kv, which is located at the horizontal section, i.e from the collector of horizontal output transistor.
Aug 04, 2010 | LG 700M 17" CRT Monitor
No variation in display while increasing size
this problem is due to horizental deflection circuit.
plz check a high frequncy filter diode at eht .it has locked with h-yoke conector. also check all diodes and mosfet in eht area.
thanks
Mar 02, 2010 | Samsung 793S 17" CRT Monitor
Well my ACER AL1916B LCD monitor blew up.
The MOSFET that blew up will more likely to have the switch mode driver IC that went out with it also, you need to verify that the IC is good otherwise you will blow up the new MOSFET, you may be better off buying a new board from here: http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1160140&Click=54985
By the time you order the new MOSFET and other parts it may end up more han $35, just a suggestion.
Feb 04, 2010 | Acer AL1916B 19" LCD Monitor
Hello sir, only horizental single line show in my display, what is this problem?
That is caused by absence of the vertical signal, more likely to be a problem with a semiconductor (specially a transistor) broken inside the display. Also, it may be caused by a "cold joint" or a problem with the solder. Heat caused by the "excessive" use of this monitor causes the joint to fail.
May 13, 2009 | Samsung SyncMaster 550S Monitor
Dell Monitor repairing trobleshoot
check the circuit of secondary line 1st check the all dioed must be shorted. then replace the horizontal transiistor out put.
Apr 18, 2008 | Gateway FPD2275W LCD Monitor
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
Computers & Internet Logo
473 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
