Question about Health & Beauty
My singer lock cutter won't cut fabric
Purchased Singer Lock cutter P/N 555790 for my Singer Sew Mate #5400 and after attaching it to my machine,it sews but the blade doesn't come down low enough to cut the fabric.
SOURCE: Pop up cutter wont lock down and only one cutter
Same thing happened to me. I took it apart and got it fixed but then could not get it to lock down (wouldnt go down the whole way) There is a plastic that locks it down (if that is broken your out of luck)--and springs that pop it up. The key to getting it back in place is to push it down very evenly straight so that both of the metal rods go directly into each of their respective holes.
Posted on May 06, 2010
SOURCE: I purchased the conair trimmer model GMT175W I
Just twist and pull backward on the tip where the seam is. It does kind of feel like you're going to break it, but it won't--it is made to snap off like this.
Posted on Jul 12, 2010
guyster7148
  • 192 Answers
SOURCE: My kenmore Ultra Mini sewing
By any chance did you check the throttle??? A lot of even the newer models get jammed. This is caused by no lubrication. Try to lubricate the machine and give it a whirl, bet it works!!! Please do not forget to vote for the help you got today.... Guy :)
Posted on Sep 13, 2010
redcloud74
  • 9 Answers
SOURCE: After resetting the cutter blades
if your clippers have a power setting screw on the side try adjusting it. turn till you hear it make a godawful noise then dial it back till it runs smooth. if that does not fix the prob, your blades might not be aligned properly
Posted on Jun 17, 2011
Tally Girl
  • 1125 Answers
SOURCE: Can't get the Lock Cutter
tally_girl_35.jpg have you got the little silver arm with a gap in it (see photo above mounted over the needle bar? This is essential as the movement of the needle bar going up and down is driving the blades in this attachment.
The walking foot attachment for sewing machines works the same way, you need to place the little arm over the needle bar to make this aftermarket accessory work as its not driven by the sewing machine motor, purely by the movement of the needle bar.
Saying that, I would be suprised if this attachment cut heavy weight fabric or several layers well, like many things made to imitate a purpose built machine (serger) there is no substitute for the real thing. It might be fine to just trim the fabric loose threads off a fabric edge but also you would need to watch that the trimmed bits are going somewhere and not getting into the seam or your machine. On a serger, the blades are working right beside a vertical drop off with a waste tray below and there is a lot of lint and fibres trimmed which quickly builds up. With this attachment, you'd have to manually ensure that the trimmed fibres are swept out of the way.
I hope this helps you to get it working though - 4 thumbs up if so. :-)
Posted on Jun 22, 2011
How do you replace bobbin
Usually, slide back the footplate, release the catch on the bobbin holder and lift it out.
the manual is available here at a cost
http://www.sewingpartsonline.com/instruction-manual-singer-5400.aspx
This one says it is available free
http://issuu.com/service-repair/docs/singer_5400_series_service_manual.pdf
Sep 23, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
How to fix code E7 on a singer sew mate 5400
I would go to the Singer site and email customer service to find out what that code means. It can vary according to which machine it is. Once you have found that out, you'll know how to proceed.
Apr 13, 2015 | Singer Sewing Machines
How do I fix the looping under the material when I sew?
the looping on the bottom usually is a tension problem, the top & bottom tension are unequal usually fixed by adjusting the top tension.
some people that I've talked with have had success with changing to a different size needle ( depends what type of thread is being used).
when the machine is threaded the foot needs to be up ( this releases tension on the thread), when the foot is lowered it the tension is set on the thread. if the material being sewed is too thick it raises the foot too high & releases tension on the thread ( the material has to be really thick to do this).
if there a piece of thread or lint in or around the tensioner or bobbin area it could cause trouble.
other wise if you've tried everything you can think of, take it back th the store & have them try it & tell you what is wrong.
also this machine has bad reviews (i'll provide a link so you can read them), people having the same problems as you are. the newer singers just don't seem to be the same quality tha the older ones were.
all bad reviews
http://www.amazon.com/Singer-5400-60-stitch-Sewing-Machine/product-reviews/B007ZG9DTQ/ref=cm_cr_pr_btm_link_1?ie=UTF8&showViewpoints=0&sortBy=byRankDescending
mixed reviews
http://reviews.walmart.com/1336/20573406/singer-5400-sew-mate-60-stitch-sewing-machine-5400-reviews/reviews.htm
Aug 26, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
Attachment "Lock Cutter" for Singer model #1120
contact singer customer service about the directions you need
Mar 04, 2012 | Singer Sewing Machines
Can't get the Lock Cutter Attachment to work. The right hand cut fabric won't feed through the fabric just won't go through and get cut and over sewn
Jun 22, 2011 | Singer Inspiration 4206
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
