Question about Coby LEDTV2226 22 in. TV
No red led on front panel & wont power on at all
Turned off now no red led on front rt panel and wont power on at all
    Genius:
  • 1,669 Answers
Check the wall outlet to see if you have power going to the TV. Next, the case will need to be opened; look inside for a fuse near the power wire. Beyond that you will need someone with TV experience to help you.
Posted on Jan 12, 2013
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Motherboard connections (to front panel)
remember the colored wire is +, the + and - should be printed very small on the board near the connectors as well as what they are example (HDLED is hard drive LED) or (PWRLED is power LED) or (PWRSW is power switch) these are examples yours may differ slightly
Jan 31, 2013 | Gateway (4000811) Motherboard
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
My renault laguna 1999 rt remote key fob wont work?
IF YOU TYPE 1999 RENAULT LAGUNA REPROGRAMME KEY INTO A GOOGLE SEARCH, YOU WILL BE ABLE TO PRINTOFF INSTRUCTIONS TO REPROGRAMME THE KEY TO THE KEY READER.THE IGNITION NEEDS TO BE OFF TO DO THIS
Jul 09, 2009 | 2004 Renault 181
LG RT-42PX10 plasma - No Display
Power supply on left hand side module. check if heatsinks are cold. possible faulty. fuses and input voltages first check.
Mar 18, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Wiring diagram
First, you can buy a harness for whatever vehicle you're putting it into and the colors on THAT harness will match the harness on the radio.. With that said:
black---------ground
red------------12V Switched (ignition)
Yellow-------12V (constant)
blue-----------power antenna
blue/white--Amp turn on
orange-------dimmer
white--------Left front+
white/blk---Left Front -
Gray---------Rt Front+
Gray/blk----Rt front-
green--------left rear+
green/blk---left rear-
purple--------rt rear+
purple/blk---rt rear -
Aug 04, 2008 | Sony CDX-M610 CD Player
Rt 202 led light red and no sound
With the system turned off, disconnect the speaker wires from the amplifier. Turn on the system. If the light stays red, then the amplifier has an internal problem. If the light turns green, then your problem is a blown speaker, or a speaker wiring issue.
Jun 03, 2007 | MTX RT202 Car Audio Amplifier
Coby LEDTV2226 22 in. TV Logo
105 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
