Question about Maytag MVWX500XL High-Efficiency Bravos X Top Load Washer - Lunar Silv
Maytag bravos mvwx500xw0 has no power after closing lid
Washer has no power after closing lid circuit breaker is good and wall plug works with other appliances
    Sergeant:
  • 291 Answers
You should hear a click just before the lid closes and a click just after it opens. If no click, check lid switch and it's actuator.
Posted on Jan 13, 2013
  • 27 Answers
SOURCE: Maytag Neptune MAH5500B stopped suddenly - no power or lights
Control Panel is bad, need to replace
Posted on Jun 14, 2009
smartr10U
  • 1305 Answers
SOURCE: Washer is "dead." Was stopped after fill up, and now no power.
Try pushing firmly on the center of the lid.... with the lid closed... it could be that the lid switch isn't making proper contact to turn the machine on.
If this is the case, you can open the lid, and while holding the lid open with one hand, put firm pressure on the rear lip of the lid right in the center..where it makes contact with switch...
This was a common occurence at my laundromats because people would sit/stand on the machines..
Hope this gets ya up and runnin'
Posted on Jun 20, 2009
SOURCE: Maytag Neptune washer front load- Can't open the door
Take out the bleach and softener tray (it just lifts out, angle it a little) and unscrew the 4 bezel screws and take out the bezel. You will find a red or green plastic pull line that is supposed to release the door. You may have to "man-handle" the door a bit and pull hard on the line before it will release. Once you work on the door release mechanism (I had to replace the wax motor again, even though it was the "upgrade" black plunger type) I recommend shooting a little silicon spray on the white plastic moving parts of the locking mechanism to get them to move more easily.
This is true on a Maytag Neptune MAH3000AWW front loading washer. Mine is 11 years old, and had the initial wax motor work done at 7 years.
Posted on Jul 07, 2009
VtToolMan
  • 704 Answers
SOURCE: How to Find Lid Switch on Maytag Washer
The newer top loading washer designs don't use standard switches as was typical many years ago.
Today, these washers use a magnetic switch, and bypassing is not easily possible, due to the logic circuits that monitor the washer and all the various cycles.
For any reputable tech to provide a instructions to bypass any safety feature, would be highly irresponsible and would expose us to legal action by this site and the product manufacturer.
Please understand, providing a way to defeat a product's safety feature is against the law and will remain on the internet for years to come, along with the person(s) that provided it, exposing me and my family to a potential lawsuit - sorry, but I wouldn;t do that for my own family, yet alone some stranger.
Just chaulk it up to new technology, just like seat belts and air bags have changed auto safety.
Hope you understand and find this Very Helpful - Enjoy your new washer and best regards!
Posted on Aug 26, 2009
Testimonial: "I suspected there wouldn't be a way to bypass it, but thought it was worth asking. It'll make laundry take a little longer. Thanks for the help! "
  • 220 Answers
SOURCE: Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
Posted on Sep 01, 2009
Maytag Bravos MVWB300WQ1. While sitting idle I heard a click and now the machine will not turn on plus it popped the circuit main circuit breaker.
The clicking sound may have been insulation / plastic in one of the electrical components cooling down after failure. The problem is more than likely the motor or lid switch. If you are capable, remove motor wires / plug, insulated same, plug into the power, turn on & see if it trips the circuit breaker. if it does not it is the motor, if it still trips check other electrical components.
Apr 20, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravos model mvwx500xw0 will not drain and spin properly
This could be a lot of things. One of them is the belt on the bottom that connects the transmission to the motor, of course it could be the transmission/clutch.
Feb 22, 2014 | Maytag MVWX500XW - Bravos XTM HE Top Load...
Maytag Bravos MVwX500XW0 Top Load Washer is not spinning
Check the inbalance/lid switch for continuity.Ck speed selector switch (if any)the water level and water temperture switches for proper opreation.NOTE:If any of the selector switches on the console are only poartially pushed in,it may cause improper function.I do not know how old your washer is.TEST LID SWITCH FIRST.If above does not solve,ck timer circuits for continuity.Get ready for this:there is to much to ck with out been there.is motor buzzing,test capacitor,washer spins but does not agitate,ck the agitator splines if they are not rhe problerm,the transmission might be the problem.GOOD LUCK.FYI I own Whirlpool washer and dryer and I repair my own,I prefer KENMORE/WHIRLPOOL/ROPER PRODUCTS because they are easy to repair and parts are not as high priced.
Sep 15, 2012 | Maytag Bravos X MVWX500X 4.3 cu. ft....
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Maytag Bravo Top Loader Lock will not work
There is likely to be a problem with either the door/lid solenoid/lock or the 'door/lid closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 03, 2011 | Maytag Bravos MVWB400V Washer
My Lid on my washer displays open when I close it and won't start if lid is open... please help.
your lid switch is not working or may be jammed try opening the top of the back of the washer make sure the lid switch is working im not sure if the mtw range uses switch or magnetic recognision with switch there is a small lid switch that clicks when the lid is slightly lifted with magnetic it makes no noise however they can both be bypassed by cutting the switch wires normaly black and red running along the right side of the control board (making sure power plug is not plugged in) stripping the two wires and joing them together
this should work
Dec 28, 2010 | Maytag Bravos MTW6600T Top Load Washer
My washer won't turn on, I checked circuit breaker and plug. Model # MAV4758AWW
Below is information provided by www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams.
You may also find this to be of assistance;
http://maytag.custhelp.com/app/answers/list
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jul 17, 2009 | Maytag Washing Machines
Maytag bravos
You have a broken lid switch, get me the model # and ill post a schematic and part #, thanks Dave www.washermd.com
Dec 17, 2008 | Maytag Bravos 4.5 Cu. Ft. Washer
Maytag MVWX500XL High-Efficiency Bravos X Top Load Washer - Lunar Silv Logo
447 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
