Question about Maytag Refrigerators
Maytag refrigerator MFI2569vem2 making a cricket noise, it is coming from the Embraco compressor model EGX 70HLC
SOURCE: Maytag stopped getting cold, buzzing noise every now and then after pwr outage
Frig requires either compressor relay or the compressor itself...should have some warranty still, so call an authorized servicer. Ray
Posted on May 30, 2008
22yooper
  • 828 Answers
SOURCE: Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
Posted on May 31, 2008
SOURCE: Refrigerator making a whinning noise.
this is the way firidges are made. **** isnt it..
Posted on Aug 08, 2008
Sea Breeze
  • 4654 Answers
SOURCE: light is on, fan runs, compressor will not come on
Below bottom grate is a defrost timer. Turn slowly clockwise until you hear compressor start. If this works, replace defrost timer.
Let me know, Thanks, Sea Breeze
Posted on Mar 19, 2009
  • 400 Answers
SOURCE: Maytag Performa Bottom Freezer refrigerator making weird noises
This can be due to low supply voltage, causing the compressor thermal overload to trip out. Therefore when this happens the compressor gets hot and it keeps trying to start but fails. It can also be a faulty starter relay, which is located in the conncetion box of the compressor and is very simple to replace.
Posted on Mar 20, 2009
Need to identify the prongs on my compressor. embraco egy90hlp wiring diagram
PDF]General Index - Embraco
www.embraco.com/DesktopModules/.../Arquivos/MP01EG.pdf
EmbracoApr 7, 2011 - Figure 6b Series EM - Compressor Model Identification Code . ....Compressor Wiring Diagram T Series (electrical component with terminal ...
Embraco PW 5.5A compressor - pins layout? - Refrigeration Engineers
www.refrigeration-engineer.com > ... > Domestic
Sep 4, 2008 - 4 posts - ‎1 author
My fridge-freezer quit working tonight - it's probably over ten years ... It's an EmbracoPW 5.5A, and the pins form an upside-down triangle, ... So, I want to try hard-wiring it but I'm struggling to identify the compressor terminals.
Identifying Compressor Terminals: Start, Run, and Main ...
fixitnow.com/wp/.../identifying-compressor-terminals-start-run-and-main...
Sep 9, 2010 - Let's say you're gonna do some tests on your refrigerator compressor to see if it's okay. Or, you need to figure out how to wire up a generic ...
Refrigerator compressor electrical question - AllisChalm
Jan 18, 2016 | Refrigerators
Do I have a 20 pound cricket behind the refrigerator??
That's the compressor. Check the compressor mounts to see if they are cracked, loose, or have hardened or broken rubber bushings. Also check to see if the compressor housing is improperly touching something that transmits its vibration and acts like a sounding board. Sometimes there is a problem with freezer icing in high humidity conditions, leading to ice buildup on the refrigerant tubing at the compressor (excessive running) - this makes the tubing insulation rigid and things get really noisy. The fix is to shut everything down, let it defrost, and clean out the defroster drain tube.
If you can't find anything like that, you may have something going out in the compressor. If possible, make an audio recording and play it for a service technician at an appliance shop - he may be able to identify exactly what the problem is.
May 08, 2014 | Refrigerators
I purchased an Amana refrigerator that has been making a humming noise and will not keep food cold or frozen. what' wrong? The model # is ABB1924DEB, and I purchsed it in 2005. is it included in their...
The recall was for units that had embraco compressors. the relay would burn up and not start the comperssor. (hum and click) some amanas had tecumseh compressors. They would just scize up and not run (hum and click)No recall. remove the back cover and see what name is on your compressor. If its hot and trying to start, Embraco needs new relay, Tecumseh needs to be replaced with a embraco compressor.
Dec 01, 2009 | Refrigerators
My refrigerator buzzes for 5 or so seconds then
the buzzing noise your hearing is possibly your compressor trying to start up. this is generally a buzzing for 5-7 seconds followed usually by a click noise if it goes on for several hours you will notice the temps in the unit starting to rise. for alot of may tags with the tecumseh compressor the compressor had to be replaced. if it has an embraco compressor you can just replace the start relay on the compressor. let me know what you find thanks Peyton
Mar 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Need schematic for refrig repair
i need to know how much pressure gauge on low and high for two side whirlpool refrige
Nov 26, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Is it worth it for me to replace the relay?
Take off the small panel on the back bottom of the fridge.  Mounted to the left side of the compressor is the relay.  It may have a black plastic cover over it that will need to be removed.  It looks like your model # is MSD2756GES if so the part # for the relay is 61006186.  If the compressor is a Tecumpseh, which has a little blue sticker of an indian on it, then I would bet that the compressor is bad.  If it is an Embraco I would try the relay.  Compressors are covered for 5 yrs. from the date of purchase.
Oct 10, 2007 | Maytag MSD2756GES Side by Side...
Refrigerators Logo
51 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
