Question about Tomy THOMAS FRIENDS REMOTE CONTROL STEAM SOUNDS THOMAS TRAIN
Cant get the steam to work on the engine have put in water and new batteries and the steam is still not working
I am having the same problem with our control steam sounds thomas train. I've been searching to no avail. If anyone can help me please leave me a message thank you!
Posted on Apr 30, 2013
My shark steamer is foaming and no steam is coming out
You cant put soap in the steamers, only water. Clean out water container and start new. Also, clean hole where steam comes out with something thin. Make sure it is heating up enough to produce steam, otherwise heat assembly is broken.
Mar 08, 2017 | Shark Vacuums
What could be wrong when the a/c works fine then blows hot and temp gauge runs hot and see steam from engine?
Hello friend.
Steam from engine is usually blown head gasket or hairline fracture of piston liner letting water go where it should not and causing boiling of the water.. This will give similar problems.
The piston liner problem got me going once , Absolutly fine when engine idling for HOURS but when put under load and driven , the Temp FLEW up and steam came out,. Needs a workshop or good DIY Mechanic to take a look.at the engine. Probably nothing to do with AirCon.
Aug 25, 2014 | 2005 Ford Taurus
I have a brand new Kitchenaid Artisan, which works perfectly apart from one thing; it doesn't appear to output hot water probably. It does output steam and a lot of it, which eventually will turn into...
If it is a 5KES100 model then yes that's how you do it, you get your hot water from the steam boiler so the steam needs to be released before the water can come through. Turn the tap wide open and press and hold the steamer pump button. The rush of steam on full open is short lived.
Oct 16, 2013 | KitchenAid Coffee Makers & Espresso...
Running hot if you dont put water or antifreeze in it everytime you drive it, smoke and steam comes from the engine when stopped, one fan wont come on but its not the fuse,etc..
Your first task is to locate where the smoke and steam is issuing from. The possible sources are (from cheapest to most expensive) Heater core hoses or radiator hoses or thermostat housing gasket failed or radiator or head gasket.
If you can find where the steam, or water is coming from, I cant tell you what to do then. The second fan will not come on until really hot, usually only one fan runs.
Dec 15, 2010 | 2001 Chevrolet Impala
I added water and the vicks medicine and no steam
medication was never meant to go into a humidifier. it clogs the transducer. if you can clean the vicks off the transducer plate you might squeeze another season out of it, otherwise by adding medication to the machine you just gave it an early death.
Oct 23, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
After the coffee is made, the water seems to continue to heat
check this:
  1. termo swich,
  2. swich for steam
  3. termoswich for steam
replace with new if thay does not work good, and obligatory put one new TERMOFUSE for your safety, becouse she does not trigered obviously.
Apr 01, 2009 | Bunn VPR Coffee Maker
I bought two new ink cartridges. i can't get them to work.
Replace the cartridges. Sometimes the NEW printer cartridges doesn't work. If you go to the store they will replace them.
Another tip is:
Put boiling water in a cup
Put the end printer cartridge (ink) close to the water to receive the steam during a couple of minutes. (Do not put into the water)
Put it back into the printer and try again.
Oct 07, 2008 | Lexmark Office Equipment & Supplies
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
The Steam Mechanism Won't Operate
hi there,
I too am having a similar problem with my breville espresso machine. Whereby i used to be able to froth the milk with no problems but these past couple of days, the steam button light is illuminated, when i turn the knob to steam the milk, the steam button's light goes off and the hot water gets illumintaed and all i get is hot water. It also does not make that thumping noise it usually does just before the steaming begins. Please help!
I have tried clenaing it, letting the hot water run for a few minutes (not just seconds) but still the issue isn't resolved. I am thinking about taking it back to the manufacturer as it is still under warranty. Only prob is they are on the other side of the state :o(
Many thanks,
Alison
Dec 03, 2007 | Breville ESP8XL Espresso Machine
Tomy THOMAS FRIENDS REMOTE CONTROL STEAM SOUNDS THOMAS TRAIN Logo
352 people viewed this question
Top Tomy Toys Experts
Jennifer Rock
Jennifer Rock
Colin Stickland
Colin Stickland
phil
Are you a Tomy Toy Expert? Answer questions, earn points and help others
