Question about Generic Hisense 42" Class LED-LCD 1080p 60Hz HDTV,1.5" ultra-slim F42K20E
F42k20e shows no signal
Just got this Hisense F42K20e. Hooked it up, and it's not recognizing the cable input: says "No signal!" Cable was working fine hooked up to older TV, so it's not the cable input. It gets input from a ROKU box and an Xbox 360, looks fine, but nothing from the cable, or from the DVD player running through the cable box. Is it possible that it's anything OTHER than a bad connection on the Hisense?
  • Lew Bryson
    Lew Bryson Jan 14, 2013
    Problem solved: It is a refurb, and had not been re-set to factory defaults. Once I did that, everything fell into place.
2 Suggested Answers
gopakumarg43
  • 74887 Answers
SOURCE: We have a flat screen Hisense with HD but doesn't work on our cable system. How do we change the setup to receive HD?
Refer its user manual for details.
Posted on Apr 03, 2013
How to set display to 1080p on Hisense F42K20E?
You don't. The TV has a resolution of 1920 x 1080 pixels; so it's already 1080p. The number of pixels can't be changed.
What you're probably getting mixed up with is the TV showing the resolution of the incoming signal when you change channels or go to a different source. Standard definition from cable might be flagged as 480i. DVD might show either as 480i, or 480p, or maybe 720p or 1080i or 1080p if you have a scaling DVD player and set it appropriately. HDTV on cable or satellite will show as 1080i or possibly 720p. Blu-rays and PS3/XBox 360 or PS4/Xbox One should show as 1080p when your TV is connected.
Whatever the source signal resolution, the TV will scale it up to fill the panel area of 1920x1080 pixels. So the TV is always using all the pixels, regardless of the resolution of the source signal.
Sep 07, 2014 | Televison & Video
Tv wont switch on
Power supply area Sipiwe, Check Capacitors. Monitoring circuit checks for standby voltage, and if it's not there - tv will not turn on.
Feb 13, 2014 | Generic Hisense 42" Class LED-LCD 1080p...
Hisense led tv has audio but no picture seen .
follow this instruction and fix it. God bless you
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
Jul 20, 2013 | Generic Hisense 42" Class LED-LCD 1080p...
Lovely.c@hisense-usa.com
It is likely that your TV has experienced a power supply failure
Jun 20, 2013 | Televison & Video
How to get full screen
Check the picture setting. Change the aspect ratio and check.
Apr 27, 2013 | Generic Hisense 42" Class LED-LCD 1080p...
Whistling sound comming from my tv
Generally, this type of fault might occur with the vibration of ferrite cores in the main power regulator switching section. Check it.
Sep 26, 2012 | Generic Hisense 42" Class LED-LCD 1080p...
Need help on hooking a dvd to a hisense f42k20e
with the owner manual go from the outputs on the player to the same exact type of inputs on the TV.
Aug 29, 2012 | Televison & Video
Why does my new 42
Who is your Video service Provider? Cable or satellite? I would suspect a bad cable first by changing your cables. if this doesn't solve your problem you may have a bad cable or satellite box, but check your connections and or change cables for a new set.
Aug 13, 2012 | Generic Hisense 42" Class LED-LCD 1080p...
Generic Hisense 42" Class LED-LCD 1080p 60Hz HDTV,1.5" ultra-slim F42K20E Logo
42 people viewed this question
Top Generic Televison & Video Experts
richie46
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Generic Televison and Video Expert? Answer questions, earn points and help others
