I have more than one situation. (1) My printer sends our a blank sheet of paper every time I request a document to print. WHY? (2) Yesterday everything was going fine and without warning I got a message to align my printer. I did. Then I was told that if I only had black on the print out there was some thing wrong with the cartridge. (maybe the tape was still on the cartridge. I checked...no tape. When I put the cartridge back in got the same message. Now I can't print anything and this is not a good thing. I havae a home based business and do a lot of print of all kinds of documents.
    Problem Solver:
  • 7 Answers
This sounds like it could be a driver problem with your prnter.I would delete the printer from your computer and reinstall the driver i have had simular problems and this has sorted it out. Try this with one printer only to see if it solves the problem.Also you do not mention the model of your printer.Hope this works if not get in touch and I may be able to offer another solution.Yours mel
Posted on Jan 22, 2009
The printer is feeding a blank sheet of paper between printed sheets. How do I rectify this?
This causes the printable area on the page to be that much less (10 3/4 or 10 1/2 on an 11 inch page). The software thinks the paper is 11 inches long and keeps track, down to the micro inch, where it is on the paper. When it reaches the 10 1/2 inches, your printer calls the page done and ejects it. However, the software thinks there is still another 1/2 inch to print (usually the footer area). Now when you insert a new sheet of paper, the software finishes printing the rest of the page (normally a blank footer) and form feeds to the next sheet. To correct what the software thinks the paper size is, you need to run the Preferences application and change the default settings. Select the Printer button. In the next window, select the 'Change Defaults....' button. Change both the Document size and the Paper size to a height of 10.875 and click OK. Try a new document to see if the paper size is correct. You may need to go back and change the height a few times until it is correct (the height changes in .125 increments). Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
Oct 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
932c prints intermittantly
this is b coz of paper quality and sometimes due to moisture but try loosing the static and restart the system
May 07, 2009 | HP DeskJet 932c InkJet Printer
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
Sep 04, 2017 | Office Equipment & Supplies
The printer is printing blank sheet
Hello Shirelle,
Make sure there is nothing covering the jets on the cartridge. Also how long has it been laying around? it might have dried out, and/or expired. On new printers the cartridges have expirations and it will not use them after a certain amount of time. Also try a printer self cleaning and see if that does anything. If none of that works, it might be the printer. - Vincent
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Sending one printed fax, yet reciever gets additional 3 blank sheets.
Open up the document feeder and look for a trapped down or sluggish switch
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
32 people viewed this question
jasbo
jasbo
