Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
Smoke coming out of pool motor. Capacitor replaced, internal parts look ok
  • 372 Answers
WHEN this motor catches on fire it will destroy the rest of your pump and probably take out your filter also. Maybe your house while it's at it.. Replace the motor. You are literally playing with fire.
Posted on Jan 13, 2013
  • DL3019 Jan 16, 2013
    Thank you for the solution. i took the pump to an electric motor repair shop that specializes in pool motors and they agreed the motor was shot and not able to be repaired $155 for anew motor..Thanks again!
2 Suggested Answers
MOTORWIZJ
  • 1383 Answers
SOURCE: smoke is coming out of pool pump motor
IT COULD BE THE START CAPACITOR AND COULD BE A EASY FIX OR IF YOU LOOK IN THE VENTS ON THE BACK OF THE MOTOR AND SEE THE STRING AROUND THE WINDINGS BURNT OFF .. THE MOTOR IS JUNK AND YOU WILL NEED A MOTOR. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY FOR FREE TESTING.. I'M IN LONGWOOD FLORIDA AND DO NOT SHIP . THANKS AND VOTE IF'N I HELPED YA .. JAY
Posted on May 24, 2010
Just replaced the capacitor,started the pump, water running in the skimmer, checked to be sure the shaft was turning freely and it is, then smoke was coming out the back! I have made sure the impeller was...
Sounds like you may have a failed start switch in the motor. It appears the start winding did not drop out and the pump would not come up to full speed.
Aug 24, 2013 | A.O. Smith SQ1102 Pool Pump Motor
Polaris pump making a noise. loud noise, can i get parts to fix it.
If you want to fix it all yourself then you can get parts to fix a pump like that. With the symptoms you have it may be a starting capacitor.You can take apart the pump to gain access to the impeller. If the impeller rotates easily then the motor is probably ok if you replace the capacitor. If you open it up and bring the capacitor or better yet the whole motor and or pump in to an electric motor repair company in your area they should have a new capacitor to sell you or a new motor if needed. A new capacitor may cost maybe 20 to 40 dollars and a new motor may cost you 200 to 300 dollars.
If you are not wanting to turn wrenches yourselfthen my best suggestion is to bring it to Leslies Pool Supplies and they oftencan put it right for the price of the parts while you watch (they may not have a cap or motor in stock).
I hope this helps.
Sep 30, 2011 | Polaris 280 In - Ground Pool Cleaner with...
I am buying a home where the home inspector told me that the pump for the pool is working but the motor is not, what would it cost me to replace the motor. I am not a handyman, can I replace it myself or...
Replacing the motor is not very easy but you might be able to be a major part of the repair. I say repair because the motor may be ok. The capacitor might be all that is wrong.
My advise it that you make sure no voltage can be supplied to the motor. Next you need to use a combination or socket wrench to remove the four bolts that hold the pump together. The pump should be able to come apart exposing the internal parts. The cover that covers the wiring connections on the other end of the motor can be removed and the wire terminal screws can be loosened until the wires can be disconnected. At this point the motor assembly can be separated from everything else.
What you can do next is bring the motor assembly down to Leslies Pool Supplies and they can first determine if installing a capacitor on it will make it work. If the motor is bad they will have one or can get one and assemble it with any other parts including the seal, etc. in order to get it back in good order.
You can then bring it back and install it with information they provide.
If you are not comfortable with the above method then you could find a friend, neighbor or relative that could help you do the work at your location or you could get a professional to do the repair.
I hope this helps.
Sep 05, 2011 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Model SP15921TLNP 1HP pool pump. Only had 1 year. We have had local quick on off power outages in this area. Now Pump does nothing. Using tester have power into the motor. I think may be capacitor but I...
Capacitor should be inside cylindrical cover on motor's side; simplest test is to replace it. If motor humms but won't turn maybe bad capacitor, stuck bearing (turn by hand) or bad/dirty centrifugal switch contact. If no humm at all, may have burnt internal neutral wire.
Jul 08, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
Smoke is coming out of pool pump motor . i turned it off straight away. is the motor stuffed?
May 22, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
My emerson pool engine just hums, what is wrong with it?
SWITCH IT OFF and check the shaft will rotate freely and there is no play in the bushings either end. If it is mechanically ok either one of the windings is burnt out or if fitted the run capacitor is at fault. If you can access the windings make sure they are continuous with an ohm meter. To check the capacitor apply the meter across the connections and the resistance will rise as the capacitor charges up if it's OK. This humming is usually caused by the rotor not rotating and the effect of the electro-magnetic field upon the internal laminated parts. Either the bushings are worn and the rotor is touching the stator part of the motor, or the electo-magnetic field is not cycling around the rotor.
Aug 10, 2009 | Kitchen Appliances - Others
PUMP TRIPS BREAKER, BUT SHAFT ROTATES FREELY
Probably not. Take the capacitor off and inspect it for physical damage and if it looks ok take it to an electric motor shop for testing. Assuming it is ok your motor will probably need work or replacement.
Jul 12, 2009 | AO Smith Pool Pump Motor 1HP Square Flange...
USQ1102 pump gets power, buzzes, trips breaker
The motor-start capacitor is bad. This is a very common problem. It can be easily and cheaply fixed by replacing the capacitor. Replacements are usually less than $10.
See http://www.youtube.com/watch?v=ZEIv5ClLqXg for a step=by=step guide.
When you have the capacitor in hand, check the model# which is printed on it. Alternatively, you can Google the motor brand & model to find the parts list which will identify the right one. Then Google the part number, to find a seller.
Jun 27, 2009 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Where can I find a replace thermal overload protector?
http://www.mypool.com/Products/Catalog/mo.asp for the capacitor.
See if there is another part number for that breaker (CET51 ABM).
Feb 28, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
625 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
