Question about Samsung WA5471AB 4.7 Cu. Ft. Top Load ENERGY STAR Washer with PureCycle
How do you properly level a Samsung wa5471ab top load washer?
Front legs are not adjustable and cannot level. only the back legs are adjustable. Have had to use cardboard under the back legs to level the washer. Am I missing something.
  • serafinidan
    serafinidan Jan 13, 2013
    It is the back legs that are not adjustable not the front legs.
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Samsung WF317 Front Load Washer code nd
Check the drain pump itself. But at the same time if your clothes are still sudsy it sounds like it is not going through all the cycles. Almost like it is skipping a cycle
Posted on Feb 12, 2009
  • 38 Answers
SOURCE: New front load washer dryer is vibrating badly when drying
Q - My washer keeps moving around n the floor, is there any simple things that I can check ?
A - Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Posted on Mar 14, 2009
  • 380 Answers
SOURCE: we installed new samsung front load washer &
Have the shipping bolts been removed? Look in the user manual to locate these.
Posted on Dec 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: Samsung WF330ANW front load washer--was just
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
Why does it not drain?
It "should drain automatically. If yours does not, please make sure the washer is properly leveled both front to back and side to side, make sure the drain hose is not inserted too far into the drain pipe and that there are no bends or kinks in the drain hose that might cause a blockage. Samsung also recommends cleaning the debris filter on a regular basis (at least once per month). To avoid spillage when cleaning the debris filter, it's important to first empty the rubber drain tube located next to the debris filter into a container. For more information, please refer to the User Manual."
Source: http://answers.us.samsung.com/answers/7463/product/WF330ANB_XAA/samsung-4-3-cu-ft-washer-questions-answers/questions.htm
You can download the "User Manual" and "Troubleshooting Guide" from here:
http://www.samsung.com/us/support/owners/product/WA5471ABW/XAA
I hope that helps you!
Jun 21, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Ds codemkeeps coming up even though the door is shut
The "dc" error code indicates an unbalanced load is preventing your washer from spinning properly. Try redistributing the load, then press the Start/Pause button. If the load appears well-distributed, you may need to make adjustments to the leveling legs to make sure the washer is properly leveled, removing the clothes and running a spin only cycle to make the necessary adjustments. Once firmly leveled, be sure the plastic leg locks are tightened to prevent them from vibrating loose.
Apr 14, 2014 | Samsung WF337AA Front Load Washer
Leveling kenmore elite front loader
  • Place the level on the top of the washing machineicon1.png to see if it is level. Make sure you test it side to side and front to back.
    Pull the washing machine away from any walls if you have to make an adjustment to the legs.
  • Lift the washericon1.png and place the wood block underneath the washer. Place the block near the leg that needs to be adjusted, but don't let it obstruct the leg.
  • Loosen the nut that secures the legicon1.png with the wrench.
  • Raise the height of the leg by twisting it to the left, or lower the height by twisting it to the right.
  • Remove the block of wood from under the washer and recheck the machine with the level.
  • Raise or lower the leg if additional adjustments are needed.
  • Tighten the nut on the leg with the wrench when the machine is level.
  • Repeat the process for each leg that needs to be adjusted.
  • Move the washer back into position and check with the level again to make sure the washer remains stable to finish leveling the machine.
    Regards,
    Richard Roth
    http://appliancecafe.com
  • Nov 13, 2012 | Kenmore Elite 45986 Front Load Washer
    Why does the tub hit the liner on my whirlpool washer?
    Sounds like it may be off balance. First tilt the rear of the washer onto the front legs a few inches (make sure the rear legs come off the ground if even just a few inches.) and then let the washer drop back on its rear legs. This is an auto level feature on many washers. Now use a level on the outer edges on the top of the washer and make sure it is level. Adjust the front feet as necessary. Also make sure you are evenly loading your washer so the tub does not "swing" into the side.
    Mar 17, 2011 | Whirlpool Washing Machines
    Leveling legs during set-up
    If you just purchased this wahser and had it delivered, make sure you remove the shipping bolt(s). There is a large pin inseted in the back of the washer that must be removed BEFORE you attempt to use it. All the balancing in the world will not prevent it from vibrating if the pin is still installed.
    If the shipping bolt has been removed, the following link can give you some added pointers on how to level your washer:
    http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
    Whirlpool manufactured top loaders have an auto-leveling mechanism on the rear feet that needs to be adjusted first. Once the rear feet are set, adjust the front to match the back, by turning the front feet. Make sure you check the level side-to-side as well. DO NOT place the level on the washer lid when checking the level as the washer lid is usually bowed and will not give you an accurate reading. Once you have the washer leveled, you can place nuts on the front feet to lock them in place and prevent them from becoming unleveled. The rear mechanism should be rechecked periodically by following the procedures in the link I provided.
    If you have any questions, please post back and let me know. I hope this helps you.
    May 10, 2010 | Roper RAS8445KQ Top Load Washer
    SPINNING OUT OF CONTROL MACHINE IS DANCING ACROSS THE FLOOR
    You need to adjust the legs on the bottom to get it balanced so it does not spin and cause it to bounce. fill a clear glass of water up to 1/8 inch of top place on machine on the side and then the front observe if unit is level if not adjust till level from right to left and front to back. spin outthe adusting feet on the bottom of the washer.
    Jun 14, 2009 | Samsung WF337AA Front Load Washer
    Kenmore 700 series top load washer problem
    This machine has self adjusting legs in the rear. Tilt the machine forward and see if you can hear the spring loaded legs adjust in the back if not they may need some lubrication and some help. tap on legs with hammer gently and they will usually release. Front legs have screw adjustments and very important locking nut which 99 out of 100 installers wont use. Thank you
    May 29, 2009 | Washing Machines
    Back legs have collapsed; washer is tilted
    They should unscrew from the bottom of the leg - if the washer "sank" it likely stripped the threads, and you will have to adjust it manually.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    May 02, 2009 | Kenmore 23822 Top Load Washer
    Hotpoint wf620 aquarius very noisy and not letin any water in
    A washer usually shakes or vibrates when it isn’t sitting firmly and level on the floor or because it has an out-of-balance wash load. First eliminate the possibility of the latter—adjust the load if it has scrunched up on one side of the tub. Then check the machine for solid, level support. For the machine to work properly, the floow must be flat, level, and strong enought to support the heavy, water-filled washer without deflecting under the load.
    1) Unplug the washer.
    2) Look under the washer, and make sure all feet are resting firmly on the floor.
    3) Make sure the front legs have locking nuts to keep them tight and that the legs have rubber caps. If they don’t, buy these parts and install them.
    4) Make the front feet as short as possible by screwing them up into the machine. Place a level on top of the washing machine and adjust the front feet slightly if needed to level the washer; do not fully extend them.
    5) If necessary, tilt the washing machine forward. This will let the back feet self adjust. Recheck for level, and adjust the front feet again.
    6) Plug in the machine, and run it empty through the spin cycle to see if it still vibrates.
    7) If it does, call a repairperson or the manufacturer to ask about solutions.
    Dec 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
    Leveling a washer tub how to do so
    first get a level. second, some have self leveling rear legs, just lean the machine forward and set down slowly. the rear legs are now level. if you dont have self leveling rear legs, the legs screw in, so just screw them in or out as well as the front legs untl it appears level by eye. now place the level on the washer. check it front to back and side to side. try rocking the machine to see if there is any movement. if there is adjust the legso it stops rocking, all the while keeping an eye on the level
    Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
    Samsung WA5471AB 4.7 Cu. Ft. Top Load ENERGY STAR Washer with PureCycle Logo
    57 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
