Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Green light comes on 3 times and clicks and then wont come on.
We have located the 150 cp and the others and none of them look puffed up. Also tried the blow dryer trick still no luck. Any ideas what I should be looking for and what needs to be replaced
  • shafferl16 Jan 22, 2009
    Where is this flyback located. I can't find it. Is in on the deflection board or near it? I am willing to pay the $60 bucks to replace it but how do I know that is what is bad?
    Thanks for the response.
  • bdaddytm Jan 23, 2009
    tv plays in black and white when cable is hooked up to rca
  • RCA Master
  • 8,617 Answers
Replace the flyback, thats usually what is defective when the led will come on 3 times then go out. You need flyback 259296 which is very easy to replace. You can get one at the following link with free step by step instructions with pictures. Read the reviews on the flyback. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 22, 2009
  • Sonny Berry
    Sonny Berry Jan 22, 2009
    Heres a picture of it circled on the deflection board. If CP150 isnt domed on top its most likely the flyback as the flyback is the number one component to fail and cause the 3 flash then shutdown.
Tv wont turn on most of the time it will try three times then you have to wait a minute to try again
On yor Deflection board CK capacitors cp114 cp120 220uf 35v and cp150 1000uf 16v if cp 150 is swollen or puffed up on top replace all 3 caps Deflection board is the bottom board on left hand side with FBT flyback transfomer
Aug 12, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W14 wont turn on it makes a weird noise and the power light blinks as it's making the noise three times than the blink stops and noise too
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 12, 2010 | RCA D52W19 52" Rear Projection Television
The tv will not power up. Blinks three times and shuts down. TL010 shorted ,replaced but still has problem.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If any of them is puffed up on top replace all the 3 capacitors CP150 2200UF 16 other 2 are 220UF 35v they will be green with gold writing on them. Resolder all pins on Fly Back Transformer (FBT) also. FBT could be in the power supply. Check the SMPS and in any event replace CP 120: 330UF/35V/HF & CP 150: 2200UF/16V/HF (May be bulged or vented)
Always Resolder Cl031 & Cl032 (usually looks ok on visual inspection but common to ring crack).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 06, 2010 | RCA D52W136D 52 in. TV/DVD Combo
52 in rca rear projection hdtv wont power up power light flases three times
3 capacitors on the deflection board cp150,cp114 cp120 2200uf 16v use 25v 220uf 35v cp 150 most of the time is puffed up on top.
Dec 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W17 wont come on, the green power light goes on and off three times then stays off.
On deflection board CK capacitor cp 150 2200uf 16v use 25v if i is puffed up on top it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v for parts call Mats 1-800-628-1118
Nov 12, 2009 | RCA D52W19 52" Rear Projection Television
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv want show picture tv power light stays on but no pic no sound
on your deflection board ck capacitors cp150 cp114 cp120 if cp 150 is puffed up on top it is Bad 2200uf16v other 2 caps are 220uf 35v replace all 3 .Heres another thing you can try on front panel Press and hold vol-and ch- with TV off, hold both at same time wait for 10secs untill TV comes back on.
Sep 22, 2009 | RCA D52W19 52" Rear Projection Television
Picture won't show
Pull Back off CK both ribbon connectors on deflection board make sure they are in good there is 2 of them they connect the deflection board to the SSB board that has tuners on it ,also try with tv unpluged spay wash FBT flyback transfomer let dry then plug set back in and try.Also CK capacitors cp150 cp120 cp114 if cp 150 is puffed up ontop it is bad so replasce all 3 capacitors 2200uf 16v 220uf 35v.
Jul 22, 2009 | RCA D56W20 56" Rear Projection Television
Tv light turns on and off ,TV never actually comes on.
CK capacitor cp114,120,150 if ant of these caps are puffed up on top it is bad so replace all 3 capacitors cp 150 is 2200uf 16v other two are 220uf 35v
Feb 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
