Question about Sony Vaio Vpceb33fm
Powerwill not power up
Power supply is putting out 19.5 volts system wll not turn on
  • stephen gilbert Jan 16, 2013
    ORDERED A NEW MOTHER BOARD, TY
  • Sony Master
  • 7,627 Answers
Has there been any damage? drop? You get nothing? No LED's? Charger LED? Fan spinning? Nothing? Has the AC jack been pulled by the cord, damaging the AC jack connection. If you try to reboot on battery power? nothing? Try reseating the Memory Mods. Replace the CMOS battery.
Posted on Jan 13, 2013
My dc691p speakers require 9 vold dc. Will it do any harm to use a 19 volt dc
yes, your speakers will be damaged. do not connect 19 volts to a 9 volt device. go to walmart or radioshack and purchase the correct power supply.
Mar 01, 2014 | Juster AC-691 Computer Speakers
Which power supply?
If it worked at all with the 12V supply, it probably wouldn't last very long. Don't recommend it.
Nov 29, 2013 | Televison & Video
I have ac Acer S202HL LCd monitor. When I booted up one day it didnt come on.
first check with your both power supply out put is coming 19 Volts dc.
if its not coming check with multi meter primary and secondary of your adopter continuity.if no continuity replace with proper working adopter.
Nov 07, 2013 | Acer S202HL LCD Monitor
Is my Acer 19 volt adapter suppose to have a steady 19 volt supply, or power on an off in 1 second intervals?
Should be steady 19v.
If it is pulsating (switching on & off), then it most probably have a failed smoothing capacitor that needs to be replaced, or the voltage regulation section of the circuit is defective.
Jun 11, 2011 | Acer Computers & Internet
I need to know which pin is the live and neutral for a behringer dx 1000 pro mixer
On the power line cord the neutral usually has a wider blade. Also the cord MAY have ribs on the side of the neutral conductor. The polarity of this cord is NOT important to the operation... the power supply does NOT care.
If you are asking about the cord that goes from the power supply to the mixer, then we need to talk further. This three wire connector has a ground and two 19 VAC hots. Describing the pins in the triangular pattern would be risky... HOWEVER you can use an ohmeter to find the single ground by looking for near zero ohms on one and only pins of the mixer to a ground on one of the 1/4 inch jacks. The dual 19 VAC power supply is rated at 1.5 Amps (1500ma) for each of the 19 VAC outs.
Note these 19 Volt hots come from either side of a 38 volt centertapped transformer with the centertap to the ground.
Dec 24, 2010 | Behringer VAmp 2 Power Supply
NO POWER
Check ur power source,like the plug in outlet?Yes,than the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 30, 2010 | Proscan 19LA25Q 19 in. LCD Television
T23 2647 Think pad AC power adapter lost
No. You must use a power supply that is 16 volts or that is specified to be used with the laptop.
You can find the information about the power consumption (volts and amperage) underneath the laptop. If it says 16 volts then you MUST use a 16 volt power supply.
If you try using a 19 volt power supply you run the risk of damaging the motherboard or blowing the motherboard completely.
Regards.
Mar 18, 2010 | IBM Computers & Internet
My Codegen Switching Power Supply 350W Model 300Xi Atx2 o3 (P4) is smoking when I turn on my PC
Using 115 volt or 208 volt switch?Found on back of supply
Is the fan clog with dirt and is it turning?
Check your wiring as some supplys can be wired for 115 volt or 208 volt.you want 115 volt.
Jan 16, 2010 | AMD Codegen 350W ATX P4 Recommended...
Acer AL1916W 19" LCD Monitor '' no power''
I'm having the same problem and it turns out to be the main board.This Service guide is for Version 1.0 but turned out to be helpful
http://www.abcelectronique.com/forum/attachment.php?attachmentid=12292
Feb 28, 2008 | Acer AL1916W 19" LCD Monitor
Sony Vaio Vpceb33fm Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
