Question about youtube.com
2006 ford crown vic abs codes b1342 b1596 - youtube.com
What is code p2106 p2135 on a 2006 crown vic
Code is P2106, throttle Actuator Control System - Forced Limited
Mar 13, 2015 | 2006 Ford Crown Victoria
What is p2106 code on a 2006 crown vic
Throttle actuator control system is in FMEM mode of forced limited power.
http://engine-codes.com/p2106_ford.html
Stalling
first scan for engine code.Codes P0600, P2105, P2107.
throttle body is common problem with ford
second connect fuel pressure gauge and drive
General Specifications
Item Specification Fuel tank capacity 71.9L (19 gal) Fuel Pressure Hot restart 448-482 kPa (65-70 psi) Key ON Engine OFF (KOEO) 140-415 kPa (20-60 psi) Key ON Engine Running (KOER) 170-280 kPa (25-40 psi)
Mar 23, 2014 | 2006 Ford Crown Victoria
2006 ford crown vic abs code b1596
B1596 ABS Module Service Continuous Codes NOTE: If other DTCs are present, REPAIR them before installing a new component.
TURN the ignition switch to the OFF position and wait at least 30 seconds. Turn the ignition switch to the ON position. REPEAT the ABS self-test. If any DTCs are retrieved, REFER to the Anti-Lock Brake System (ABS) Module Diagnostic Code (DTC) Index. If no DTCs are retrieved, CARRY OUT a drive test above 15 km/h (9 mph), then REFER to the symptom chart.
Anti-Lock Brake System (ABS) Module Diagnostic Trouble Code (DTC) Index DTCs DTC Caused By Description Action B1342 ABS Module ECU is Defective INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. B1484 ABS Module Brake Pedal Input Open Circuit Go To Pinpoint Test D . B1596 ABS Module Service Continuous Codes NOTE: If other DTCs are present, REPAIR them before installing a new component.
TURN the ignition switch to the OFF position and wait at least 30 seconds. Turn the ignition switch to the ON position. REPEAT the ABS self-test. If any DTCs are retrieved, REFER to the Anti-Lock Brake System (ABS) Module Diagnostic Code (DTC) Index. If no DTCs are retrieved, CARRY OUT a drive test above 15 km/h (9 mph), then REFER to the symptom chart. B1676 ABS Module Battery Voltage Out of Range Go To Pinpoint Test E . C1145 ABS Module Speed Wheel Sensor RF Input Circuit Failure Go To Pinpoint Test B . C1155 ABS Module Speed Wheel Sensor LF Input Circuit Failure Go To Pinpoint Test B . C1165 ABS Module Speed Wheel Sensor RR Input Circuit Failure Go To Pinpoint Test B . C1175 ABS Module Speed Wheel Sensor LR Input Circuit Failure Go To Pinpoint Test B . C1222 ABS Module Speed Wheel Mismatch Make sure the tires are the same size and correctly inflated. INSPECT the wheel speed sensor rings. CLEAR the DTC. TEST drive the vehicle. REPEAT the self-test. C1266 ABS Module ABS Valve Power Relay Circuit Failure Go To Pinpoint Test K . C1296 ABS Module Wheel Speed LF Signal Fault Go To Pinpoint Test C . C1297 ABS Module Wheel Speed RF Signal Fault Go To Pinpoint Test C . C1298 ABS Module Wheel Speed RR Signal Fault Go To Pinpoint Test C . C1299 ABS Module Wheel Speed LR Signal Fault Go To Pinpoint Test C . C1300 ABS Module ABS Hydraulic Pump Motor Circuit Failure Go To Pinpoint Test A . C1805 ABS Module Mismatched PCM and ABS Modules Do Not Match CHECK the part numbers. INSTALL the correct module. C2775 ABS Module TC ON/OFF Switch Stuck Failure Go To Pinpoint Test H . U0073 CAN Bus Control Module Communication Bus Off REFER to Section 418-00 . U1900 CAN Bus CAN communication Bus Fault - Receive error REFER to Section 418-00 . U2023 CAN Bus Fault received from External Node REFER to Section 418-00 .
Jan 14, 2013 | 2006 Ford Crown Victoria
I have a 2006 Ford Crown Vic Police Interceptor. I am having a problem with the dash. As I am driving it all the warning lights come on and the speedometer, tach, and odometer all stop working. I have...
Has anyone bothered to scan the IPC (Instrument Panel Cluster) or the GEM (General Electronic Module) to see if there are any fault codes? Does the engine run OK when this happens? I had a Grand Marquis that was doing something similar and the modules had several U-codes. Finally found the problem in the Transmission Range Sensor - it was shorting out the data line.
Dec 02, 2010 | 2006 Ford Crown Victoria
My abs light came on in my crown vic what should i do ?
it sounds like one of your abs sensor on your wheel got unplugged
Feb 04, 2010 | 2005 Ford Crown Victoria
youtube.com Logo
303 people viewed this question
Top youtube.com Computers & Internet Experts
Mike
Are you a youtube.com Computer and Internet Expert? Answer questions, earn points and help others
