Question about Bissell Ready Clean Power Brush
Bissell ready clean leaks water from bottom reservoir
  • 3 Answers
SOURCE: bissell spotbot: leaking the dirty
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Posted on Aug 14, 2009
SmartAlec
  • 171 Answers
SOURCE: Bissel Quicksteamer leaking
Hi there SmartAlec from NelsonVacuums.com.au here. I do a lot of work on the Vax range of machines (very similar) and 90% of the time it is the filters and/or the seals once they get a build up of shampoo on them they no longer seal properly but once removed and rinsed thoroughly they work again. Rinsing the machine through with clean water after a shampoo job will help this not happen again.
Hope this helps
Happy Vacuuming! :)
Posted on Aug 26, 2009
  • 11 Answers
SOURCE: Clean solution leaking out the bottom
If you don't put back the tie-wraps that secure the hoses, it will leak.
Posted on Sep 19, 2009
heatman101
  • 43501 Answers
SOURCE: I have a bissell proheat 2x and it leaks water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 23, 2010
heatman101
  • 43501 Answers
SOURCE: won't dispense water/cleaning solution
heatman101
iutitu
Posted on Sep 30, 2010
My Bissell ready clean carpet shampooer is leaking water. How do I repair
First you must determine where it is leaking then find out why....it could be a bad hose, fitting, tool, wand p, heater, pump, etc. inspect closely or take it to your local vacuum repair shop.
Aug 14, 2017 | Bissell Vacuums
The pump on my bissell ready clean 40n7 don't work water goes out on the floor how to fix it
U have some seal that is leaking or worse yet you may have a crack in the housing. Look for the source of the leak and take corrective action if possible
Nov 02, 2016 | Bissell Vacuums
Bissell carpet shampooer model 9200-9 that is not dispensing cleaning solution
I had the same problem with my Bissell carpet cleaner. I tried all the recommendations but nothing worked. After reading all the blogs, I discovered that many people had the same problem. Fortunately, I still had the receipt from Costco which they honored and gave me a full refund. I was ready to throw it in the trash.
Oct 06, 2015 | Bissell 2X Proheat 9200 rug cleaner
After cleaning the heater, my unit now leaks when it's turned on.
Hi there. Sorry to hear you're having difficulty with your ProHeat 2X leaking. You may want to contact one of our Authorized Service Centers to have a qualified technician inspect your machine.
Here's a quick link to help you locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Aug 11, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
I shampooed my carpet, loaded clean water twice and added the cleaning solution. Then it dawned on me, the carpet is wet and there is not dirty water return. What am I doing wrong?
Look for a place where the dirty water reservoir is not sealed. There is air being sucked in somewhere else instead of the bottom where it's supposed to **** the water.
Jul 20, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Just need instruction on how to use
fill the solution reservoir in the back and on the bottom choose your desired setting, make sure the rubber clean water bladder is full of hot water and turn on. pull trigger and slowly move forward and backwards. Happy cleaning .Steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Spot Bot leaking water from reservoir through brushes
make sure that your collection tank is empty and correctly attached. If it is full, it will shoot water on the spot, but not **** it up several times in the cleaning process leaving a large wet puddle bigger than the original spot.
Mar 16, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Where does the water go
Remove the small rectangular lid on the side about halfway up the machine. Place 2 gallons of hot water in the side opening (to the bottom of the three raised plastic markers), add one lid-full (10 ounces) of Bissell Carpet Care solution, and you're ready to clean.
Here are the manuals in PDF, English and Spanish: http://www.bissell.com/searchresults.aspx?searchtext=1672&mode=userguides
Nov 11, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Clean machine
This is what was wrong with mine....very simple solution to fix: Check the bottom of the water reservoir. It should have a black rubber washer attached to the lip that goes down into the main system. If that part is inside the main system, instead of attached to the water reservoir, the reservoir doesn't make a tight enough seal for the suction. Just carefully remove (I use tweezers) the black rubber part (almost like a thick washer) and put it on the reservoir. Should fix the problem!
Aug 24, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Ready Clean Power Brush Logo
112 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
