Question about Mitsubishi WD-65738 DLP TV
Blinking green light on wd-65738 mitsubishi tv
The light wont stop. we have changed the lamp. and it still wont stop, and wont come on. we tried to reset it too. just keeps on blinking green.
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
SOURCE: WD 62725 Timer geen light keeps blinking
Here is how you fix the problem. Turn off the power to your TV for 10 seconds, then turn on. Next, take a paperclip and push in the reset button for 10 seconds, then release and wait until the light stops blinking - may take up to 5 minutes - be patient. Then turn on your TV as normal and your problem will be fixed.
Posted on May 30, 2009
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
SOURCE: Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Posted on Feb 09, 2010
Mitsubihi WD-65738 no power, no lights. Is there a fuse I can check? Maybe by the plug?
Follow the power cord inside to the power board--line fuse will be there--have fun and patience as a lot of screws to remove to get there---as seen from rear power board should be to far left side.
Dec 03, 2012 | Mitsubishi WD-65738 DLP TV
My mitsubishi WD-65735 1080P has a green blinking light under the word lamp..what does that mean?
all these sets have a boot up if unplugged.
If power is lost or disconnected when reconnected green light will blink for about 70 seconds (set is rebooting) and then go off allowing set to be turned on.
Questions?
Mar 12, 2012 | Mitsubishi WD-65735 Television
5738 status light blinks red 5 times then orange 7 times
if it is a 7 then u must replace.
SOURCE: i am a mechanic
Jan 21, 2012 | Mitsubishi WD-65738 DLP TV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I have the Mitsubishi WD-65738 65-Inch 3D DLP HDTV I was watching it and it made a pop sound, then the screen went black what can I do.....
Tv "LAMP" LED light indication on the tv frame word light up or blinking LED light.Check the tv projection Lamp first.The tv projection Lamp might litterly broken into glasses sharts itself.The tv projection lamp still intact,still should be change too though.After the tv projection lamp has been change the tv should work now.If still have problems the board that call the Balast board probally dead too.Becauuse this Ballast board only jobs are to help to ignite and keep tv projetion lamp light up and to work only.
Sep 01, 2011 | Mitsubishi WD65737 65" DLP TV
Blinking green light, will not power up
Try holding the menu button on the tv while turning on the tv.The other problem might be the connection to the lamp in the tv.They have a nasty habbit of coming loose ore falling out if the lamp is inserted to hard.
Mar 13, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-65738 DLP TV Logo
342 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
