Question about Acer Black AX3400G-U4802 Desktop PC with AMD Athlon II X2 Dual-Core 255 Processor and Windows 7 Home... (99802077327)
How to removed windy sound like in my acer harddrive
Pls help to removed windy noise
  • Acer Master
  • 2,878 Answers
I don't believe you can. It is the sound of the disks spinning.
Posted on Jan 14, 2013
My acer aod270 does not see the harddrive. How do I fix it?
Be sure to check that all the cables ect. are connected tightly.Because if one is lose that may be why your BIOS doesn't always see the hard drive. BUT If the "clicking noises" you hear are coming from your harddrive it could be that it is failing. You could try reformatting the drive and starting over with your install of Win 7 but if the harddrive is failing which hearing any clicking noises indicates than that harddrive is no longer going to work nomatter what! That's what happend to me several times with harddrives and the only option was to replace it with a new one. This sometimes just happens or because of wear & tear or bumps/drops over time to the harddrive.
May 19, 2012 | Computers & Internet
Hi, my son has a new windy watch and we need to set the time. pls advise how
Here's the link to download the manual for the Quicksilver Windy Watch.
http://www.quiksilver.com/graphics/uc/quik/manuals/quik_manual_watch_windy.PDF
I hope this is what you need.
Bobya
Aug 19, 2011 | Quicksilver Toys
My gr650 has a slight windy noise in top of motor it also has slight tappy noises when im riding can not hear the winding but can hear it tapping when stopped ,i changed the oil and oil filter thought it...
The upper windy noise, I would keep an eye on but the tapping noise sounds more seriouse.
I would purchase some Slick50 to add to the oils. They do a special grade for particular bike engines and it will ensure you minimise the wear.
I take it this noise has happened recently or has it been getting worse over a few thousand miles or so?
If it has just happened it may be piston slap if it it there at all times or if loudest on the over run little end bearings.
When you are able, check the compression and take the top off to examine the pistons, (broken rings) and bearings.
Hope that helps a bit
Dec 17, 2010 | Suzuki Tempter GR 650 Motorcycles
When I start my laptop it makes loud beeps, then it says no hard drive detected... Whats wrong?
The harddrive is not working, or is not connected properly.
Shut the laptop down.
Remove the battery.
Turn the laptop upside down.
Remove the screws in order to remove the harddrive cap. (The acer laptops have small signs on the caps. The cap that has the little circe-cylinder signs on it, should unlock the harddrive)
Remove the screws keeping the harddrive in place.
Remove the harddrive.
Clean the connectors on both the harddrove as the motherboard.
Reconnect the harddrive and turn the laptop on.
If it is working, turn it off, and fit all the screws in again.
If it is not working, then you probably have to change the harddrive. You could also connect the harddrive to another computer, to make sure if it is broken.
Sep 17, 2010 | Acer Aspire 5100 Notebook
Acer laptop aspire 5740 high pitch noise while using
Hi:
This noise will only from serveral places within the computer, the most common is the system fan, then the harddrive and or the CD-rom. I would guess that its the system fan thats causing the noise.
Jul 16, 2010 | Acer Aspire 5735 Notebook
Tower is making clicking noise and a reeving sound but everything is loading and running ok
Please take this time to back up all your data. This could be a sign your Harddrive is failing if it is not your harddrive it could be a fan. You need a tech to look at your system right away to prevent failure. Fans are cheap to replace but if they fail you can lose your entire computer. If its your harddrive your looking at 2-3 hours labor and hardrive replacement. Generally it is worth doing.
http://mylive-tech.com
Techs are waiting to help you.
Jan 01, 2010 | Acer Computers & Internet
How to replace a harddrive in an Acer Aspire 4520
open the back cover by unscrewing ..there u can see a small hard drive replace with a new one...
Dec 02, 2008 | Acer Aspire 4520-5582 Notebook
Acer extensa 5220 - how do I remove the hard disk?
Checked if there is rubber behind the harddrive, that rubber is used for holding harddrive so it won't loose from motherboard.
If there is any, you can removed the rubber first. the rubber shape is like block.
Apr 26, 2008 | Computers & Internet
Key bord & Mouse Paid hang Acer Aspire 1642ZWLMi PC
Try to remove your battery first, battery can cause the mouse and keyboard freeze.
about the shut down problem, is it take long time to shut down, if it is, you should check your harddrive.
Mar 15, 2008 | Acer Aspire 1642ZWLMi Notebook
Acer Black AX3400G-U4802 Desktop PC with AMD Athlon II X2 Dual-Core 255 Processor and Windows 7 Home... (99802077327) Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
