Question about Frigidaire GLET1142CS Top Load Stacked Washer / Dryer
Frigedaire stackable takes forever to dry
Our laundry center is electric, with 110, not 220 - so I know it takes longer to dry than a 220 unit. Still, it takes forever. We have pulled it out and cleaned the vent line and hubby reached in as far as he could to clean up to the blower assembly. We removed the lint filter and cleaned a bunch of lint, coins, etc down as far as we could reach with tongs. There must be some way to clean the lint (and sand) from the interior of the machine, but hubby is hesitant to just start removing screws, as he doesn't want to drop the drum. So - can you help him figure out how to clean interior lint? He can't find a model number anywhere - there's a metallic looking plate on the front left exterior corner, but no discernible writing. Washer is top loading. This is in a vacation rental in Hawaii, so tenants don't really care if they are abusing the machine or not. There's a fair amount of sand that we got out, but I'm sure there's more. I am having the same problem with mine and I have cleaned the lint & vents as far up as I can. I had 1 set of queen size sheets in the dryer and it took over 2 hrs to dry them. Any suggestions?
  • moon_k Jan 23, 2009
    I have talked to several people and they said because the dryer is getting heat that it is not the heating element. The same load of sheets would have taken 1 time to dry - this took over 2.5 hrs. I have to turn the dryer on 2 - 3x's per load just to get the clothes dry and they are not even hot they are just warm. I have cleaned out the vents going into the dryer and the vent going into the wall.
Possibly needs a new thermostat.
Posted on May 28, 2009
  • 1,214 Answers
One way to tell if it has a heater element problem is to use an Amprobe to read how much current the dryer pulls when operating. If the amps are 2/3, 1/2, or 1/3 of what it's supposed to pull, then it's an element problem, and you need to fix that.
My only question is, how long would it take to dry that same load of sheets when the unit was new, and does the time now compare to the then?
Posted on Jan 22, 2009
  • Mark Egan Jan 23, 2009
    I cannot find a wiring diagram, but it looks like from the parts list there is only 1 heating element, so I am going to be suspicious of the thermostat, IF the clothes are getting warm.
    If they are remaining cold, but drying just because they are being tumbled through unheated air, then I would be suspicious of the heating element or the associated over temperature sensor/fuse link/thermostat-temp control.
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
How do I replace the belt on stackable laundry center
oh yukkkkkkkkkk hate working on these stackables. u have to break them apart for most jobs, try googling how to take apart ur brand model and youll get instructions, sorry cant help more
Sep 13, 2014 | Frigidaire Dryers
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
Aug 21, 2014 | Frigidaire FFLE2022MW Electric...
Frigidaire fex831fs2 stackable dryer takes too long to dry and leaves clothes damp
Good Afternoon Famties4,
I understand that the dryer portion of your laundry center, model#FEX831FS2, takes too long to dry, even after making sure the vents are clear. First, I suggest checking the exhaust duct, making sure it is at least 4 inches in diameter and made of rigid or flexible metal. Secondly, make sure the duct has no more than two 90 degree bends and must not exceed length listed in the INSTALLATION INSTRUCTIONS. Lastly, make sure your dryer is connected to a 240 volt circuit. Drying time will be 20% longer than drying on a 240 volt circuit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
May 17, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
It's a whirlpool awz 7466. It runs fine, but I do not know which settings it needs to be on to dry my clothes normally. A small load will take at least 2 hours and makes laundry take forever. Any help
Hi Jennifer,
Two hours to dry a small load of laundry (even a large load for that matter) is way too long. You're wasting electricity too. The first thing you should do is consult the manual for the dryer to be sure you've selected the proper setting. The literature for this can be found here.
Consult this literature page 63 for the location and cleaning instructions for the (e) lint filter after each drying cycle and (h) heat exchanger at least monthly. Failure to clean both will result in long drying times. If you have the "Gentle" cycle selected, drying time will be prolonged, too.
Hopefully, these suggestions will help you solve the problem. Good luck!
Jan 07, 2013 | Dryers
Stackable dryer
Hello - Generally speaking, Frigidaire laundry centers do not have fuses. The unit has a thermal limiter usually located in the dryer.
Nov 02, 2012 | Frigidaire Electric Dryer
Dryer gets clothes hot, but forever to dry them.
I have exactly the same problem. My unit is 2 years old and has suffered this same problem since the day I bought it.
May 14, 2010 | GE Spacemaker Washer and Dryer Electric...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
How do you remove the dryer from the stackable kit. I'm trying to take the dryer off the washer for repairs.
hello Boonk
welcome to fixya,
We need to know the brand and model number to help you.
The year or age of the laundry center could prove valuable too!!!!!
You asked ,How do you remove the dryer from the stackable kit. I'm trying to take the dryer off the washer for repairs.
Waiting for this info. huuum
Oct 08, 2008 | Samsung Dryers
Frigidaire GLET1142CS Top Load Stacked Washer / Dryer Logo
120 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
