Question about Acer Computers & Internet
How to remove like wind noise on my harddrive acer
Pls help me remove like windy noise in harddrive
    Problem Solver:
  • 17 Answers
Harddisk media damage
replace hard disk
Posted on Oct 17, 2013
While Driving My Nissan Altima there is a static noise coming from the front driver side
Check door and window weatherstripping for gaps and wear that will allow the wind noise.
Apr 20, 2014 | 2008 Nissan Altima Hybrid
I can hear the wind blowing extremely noisy from my gas fire /chimney
It is not likely blowing from the fireplace, rather your hearing outside wind noise through the chimney pipe.
On windy days this is normal.
The noise can only be limited by the flue pipe damper and the length of the pipe.
Apr 14, 2013 | Heating & Cooling
How to removed windy sound like in my acer harddrive
I don't believe you can. It is the sound of the disks spinning.
Jan 12, 2013 | Acer Black AX3400G-U4802 Desktop PC with...
My gr650 has a slight windy noise in top of motor it also has slight tappy noises when im riding can not hear the winding but can hear it tapping when stopped ,i changed the oil and oil filter thought it...
The upper windy noise, I would keep an eye on but the tapping noise sounds more seriouse.
I would purchase some Slick50 to add to the oils. They do a special grade for particular bike engines and it will ensure you minimise the wear.
I take it this noise has happened recently or has it been getting worse over a few thousand miles or so?
If it has just happened it may be piston slap if it it there at all times or if loudest on the over run little end bearings.
When you are able, check the compression and take the top off to examine the pistons, (broken rings) and bearings.
Hope that helps a bit
Dec 17, 2010 | Suzuki Tempter GR 650 Motorcycles
Wind noise in the front doors
you may want to check under the hood and dashboard to make sure all your rubber seal or there. open the hood and leave it open if you can see light anywhere looking from under the hood that could be the problem. if not check the seals around the door and the opening to the car to make sure they are there and not deteriorated
Apr 26, 2010 | 2003 Subaru Forester
I heard a noise when is running like a windy.
You may just need to top up your power steering fluid,low fluid will make a winding noise that will increase of decrease depending on engine rpm.
Jan 15, 2010 | 2003 Chevrolet Venture Passanger
I have a whistle or humming noise from the front of 05 Montana.
Put wide tape on different areas of the windshield edge as a test to see if the noise changes.Then you may know where the noise originates and can correct the noise.
Just by chance,it is a wind noise? and not a front wheel bearing going bad?which is common on these vehicles and can create a humming at different speeds.Next time when the hum shows up turn the steering wheel slightly left and right at road speed and if you can change the hum,it's 99% a wheel bearing.
Apr 02, 2017 | 2001 Pontiac Montana
Samsung sc x105l noise problem
Your lack of patience is entirely irrelevant to the situation.
The noise may well be from ambient wind in an outdoor situation.
Aug 11, 2017 | Samsung SC-X105L Memory Card Camcorder
Acer extensa 5220 - how do I remove the hard disk?
Checked if there is rubber behind the harddrive, that rubber is used for holding harddrive so it won't loose from motherboard.
If there is any, you can removed the rubber first. the rubber shape is like block.
Apr 26, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
