Logitech 2.1 speaker z103 woofer not working
The IC of woofer is heated and burned out. The number of IC is still unavailable to me. Please help to find me that IC number of the Logitech 2.1 Z103 Speaker + Subwoofer. I purchased it just 1 year before.
SOURCE: no sound
FOR MACS... Last February(08) I bought the V20 Logitech speakers for my Apple iBook laptop. I got them to work. Hadn't used them for about a year and had forgotten how to get the sound to emerge. I went to System Preferences. Clicked on Sound. I had plugged in the USB. Didn't show up. Unplugged it and plugged in again and there it was! I clicked on it and the sound came through immediately. So wait to plug in the speakers until you have opened Sound. (And Pandora (superb Internet radio station) is playing flawlessly.) I am not familiar with PCs. Sorry.
Posted on Jan 27, 2009
  • 3 Answers
SOURCE: How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Posted on Feb 01, 2009
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Posted on Feb 18, 2009
  • 5 Answers
SOURCE: Logitech THX Z-2300 Speakers Don't work and subwoofer does
Well, just because someone at Logitech said the speakers are definitely broken doesn't necessarily make it so. They told me the same thing, yet when I read on another forum that plugging earphones into the wired remote sometimes seems to make things better, I plugged earphones into the wired remote -- and Voila! All of a sudden the blue light went on and I had sound from all three speakers. The sound continued working properly even after removing the earphone jack. IMO the problem could be with the wired remote rather than with the speakers themselves. My speakers work again!
Posted on Jul 23, 2009
  • 3 Answers
SOURCE: Logitech THX Z-2300 only one speaker works
try tapping the speaker box in your palm while the speaker is connected. There might be a bad contact of the wires inside. I had to open up my speaker to find that out. i moved around the wires connected to the cone of the speaker and then started to hear music once i did that. it was the left speaker by the way.
Posted on Mar 09, 2010
A five pin IC with 60AHN printed in the case is burned. Could you please identify this IC so that I can replace it?
If you enter the exact numbers that appear on the chip on Google you will find it and its equivalents and where to buy. Try it.
Sep 08, 2015 | Apple Logitech S315i Rechargeable Speakers...
I open my b212a and disconnected the speaker and horn wires and know i have completed my repair i am read to reconnect and i don't remember which set of wires are the positive side
Because the system is bi-amplified, it is important to replace the wires correctly to avoid phase problems. I don't know how the wires are colour coded, but if it is any help I downloaded the schematic and the wires are numbered 1: Woofer Active 2: Woofer Earth
3: Tweeter Earth and 4: Tweeter Active. Sorry if that's no help. Otherwise it should be easy to trace the wires to see which connect to earth.
Dec 12, 2013 | Behringer Eurolive B212A Speaker
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
KLIPSCH SUB WOOFER SW350 PARTS
you can order it on internet either asking the electronic companies, i tried that years ago found in usa a company which gave me a direction of a ic production company of tailand - ad the end it leaded again to a company near tepic where everybody were looking for .and here we go just right on front of the electronical ingeneur which said here in the whole country is nothing.
Apr 17, 2012 | Klipsch Sw-350 8-inch 350 Watt Subwoofer...
I insstalled logitech SL11 desktop speakers on my XP2000. Now I can't get any games sounds. There is sound on my computer, but nothing from speakers
check do u install sound driver..or check the speaker and woofer cable also check woofer and CPU sound cable this is working
Mar 13, 2012 | Logitech LS11 2 Speakers
One channel has no sound
One channel of the amplifier is burned out/damage. It is usually a package IC amp. Live with it or take it get repaired because the IC is hard to order. If you want to do it yourself, open the sub (big box and look for an ic attached to an aluminum heatsink. Look up the part number on the internet and see if you get any hits.
Apr 29, 2009 | Logitech Z-2300 Computer Speakers
Altec lansing AVS 500 IC
The amps are 8-pin CHN 4558CN [K1D142] and 8-pin PHIL TDA8199 [LD8136] The Voltage Regulator is a 14-pin LM324N There is a 3-pin LM7812CN 12-volt regulator... They are in the sub-woofer housing which is held in place by tape so it can be pried off if done with care. Hope this helps. If you have all the cables and wires in place I would appreciate knowing the connection sequences (someone cut all the wiring to the set I have.)
Jan 22, 2009 | Altec Lansing 621 Computer Speakers
Logitech X-240 woofer
you should google it and find a woofer of the correct size with at least 8 ohms to be safe. (more ohms= less risk of fire!) good luck!
Jul 26, 2008 | Logitech X-240 Computer Speakers
Sub woofer problem
I would check the power input otherwise if brand new return for replacement
Nov 29, 2007 | Logitech Z-5300 Computer Speakers
Repair of Z560 amplifier
try fixing its amps by simple reheating it. if still doesnt work try replacing its parts... it is certain that it has a prob on the amps.
Oct 14, 2007 | Logitech Z-560 Computer Speakers
214 people viewed this question
 Grubhead
Grubhead
