Hi i have a Samsung np-r40 and it dosnt charge or get any lights working, it works fine with a full battery so comp is fine but cant get it to charge or come on useing the mains ive brought a newcharger thats working fine ive taken it apart tocheck the dc plug incase that was loose that looks fine so wat else can it be? It was working fine until my old charger over heated and blew so has there been a powersurge and blew something in the motherboard ifso Any ideas so i can replace it? Regards
    Problem Solver:
  • 19 Answers
If it still works with a battery the computer is fine and the ac power input may be fried. They can be replaced at a cost. I once had a problem like this and found my new ac charger was actually not powerful enough to power the laptop. Check that the old and new ac charger are the same watts amps etc.
Posted on Apr 18, 2015
  • 7,627 Answers
Something, a component, in the laptop may have fried the charger. I don't know for sure. You would have to trace the circuit with a multimeter to locate the bad power component.
Posted on Jan 13, 2013
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Samsung NP R70 Laptop won't charge
Most laptops will work with or without the battery and with the power adapter connected.
If the power adapter is OK, just connect it to the laptop's power socket and wriggle this plug. Does the charging LED flash as you wriggle this plug? If so the power socket may have a dry solder joint or it may be faulty. Either way the laptop needs to be dismantled to solder or replace the power socket.
Posted on Jul 21, 2009
  • 309 Answers
SOURCE: My Toshiba Satellite Pro A200 works fine if I use
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Posted on Jan 08, 2010
Testimonial: "Thanks for the super quick reply. I was thinking along those lines. I'll take both units apart and compare them. Cheers Paul"
Flashing orange laptop light on samsung laptop
If your battery is six years old, it has done very well and you have looked after it. I would think that a new charger will fix your problem.
Dec 21, 2013 | Samsung R519-53S Notebook
Samsung r40 reset to factory settings
hello there Start by pressing F4 when the BIOS "Samsung" screen is showing. This will allow you to restore the original operating system from the recovery partition, if is there. (Also try the other Fn keys - F6 and F8 may do something).
Otherwise you will need to beg, borrow or buy an XP Home installation CD and use that for a new installation. You can use the Samsung key on the bottom to activate it. You can get the R40 drivers from SamsungPC.
Feb 12, 2013 | Samsung NP-R40 NP-R45 NP-R65" (CL102791)
Hello sir, i bought samsung mini laptop but the problem is its not booting operating sytem and im having problem reload it
i had this problem last week i just kept trying to boot windows if your comp starts it will come up and it will say boot f 12 if that dosnt work then put your disc and boot it from that drive
Dec 10, 2012 | Samsung NP-NC10-WAS1US Notebook
Lights on nobodys home
Unplug it, remove battery, hold power button 10 full seconds, reinstall battery, plug in and turn on. It should work fine now. If not, memory stick is likely bad.
Jun 09, 2012 | Samsung Np-r530 Np-r530-ja05us R530 Laptop...
My Samsung R40 will not charge. The cable/charger
it is called the AC power Wall Socket is that what u r talking about do u think u can replace it i think u should call some elec guy to fix it like maintenance guy it has nothing to do with ur notebook its just the pins inside the socket got loose and ur plug is unable to stand in there am i right pls vote if u find me helpful
Feb 22, 2009 | Samsung Computers & Internet
Screen Keeps dimming and contrast function does not work
This is possibly, a loose cable or the screens inverter board is overheating. the inverter is similar to a booster in a flourescant light fitting. which converts power from DC To AC and boosts up the panels Light Tube. CFL if it,s faulty or overheating. this will cause the panel to dim.
also check the plunger at the underside of the screen, isn,t sticking down. designed to cut off the panel when the lid is closed. Finally some model laptops, only boost the brightness running on A/C Power. the battery would run-out fast with screen at full brightness. if theres an fn key on the keyboard, press fn and the brightness button to adjust screen brightness.
Mike @ Compurepair.
Jul 31, 2008 | Samsung V20 XVC 2400 Notebook
Battery Charge error
Hey Lak_69,
One problem I know of is the battery for your camera should be model NP-20 not model NP-40. The NP-20 has 650mAh. I would exchange your new battery for the correct model battery, and see if this works. If this doesn't work I would try cleaning the battery terminals in the camera, and if that doesn't work go ahead and try a new charger.
Sincerely,
Allan
Go Ahead. Use Us.
May 13, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Video camera jazz dv179 how many hours need to charge
I HAVE THE SOLUTION!!!!! the camera comes with a charger that plugs into the wall and into the usb port on the camera
Oct 27, 2007 | Jazz DV-179 Digital Camera
R40 2724-BU1 Power Problem
Check the ac adapter. It seems your adapter is not charging it. Either the ac adapter or your dc port may be the problem. Is this the correct adapter, is it giving the correct voltage. These should be considered also.
Hope this helps you
Oct 20, 2007 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
