Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Lenovo 3000 Notebooks : N100 Power Failure!
Have a N100 notebook and battery does not recharge and now runs on AC power but would shut off by itself very shortly after switching it on. Brought a new AC adapter and battery straight from the lenovo website, received it, but did not solve the problem. I called lenovo directly they are not sure what could be the cause of the problem. They never heard of this problem. Laptop is only a year or so old, and only use couple hours a day. Wondering if anyone have the same problem and had it resolve, I would appreciate any insights you can offer. Thank you in advance for you help! Hello.
My N100 0768 is running Vusta.  It will not charge the battery and it shuts down at random times but never gets hot.  It lasted 6 minutes the first time I tried to boot it after I got it back from an authorized Lenovo repair shop, and then when I reboot it again it lasted only 3 minutes.
Lenovo replaced the fan, and that resolved the shut down problem for less than 30 days.  Just yesterday, the repair shop replaced the mother board and then the CPU, that did not resolve the problem.  It seems that the longer the laptop is turned off, the longer it will stay on once it is booted.
It does not even stay on long enough for me to backup all my files.  Lenovo wants me to restore it to the factory defaults, and that means I will lose all my programs and all my data.  The shut down occurs even if I do not load Vista.
Can anyone help me resolve the shut down issue? Thank you very much. Peg peggydaly@yahoo.com
  • 9 more comments
  • peggydaly Jan 22, 2009
    Hi.
    Yes, the machine actually shuts down completely.
    Thank you for your help!
  • Anonymous Jan 24, 2009
    I am currently having the same exact problem with my laptop.
  • peggydaly Feb 09, 2009
    Hi.
    Your solution does work for a little while, thank you!  I was able to cool the laptop down using a fan, so I backed up my files and then ran hard drive diagnostics - the hard drive was working just fine.  I sent the laptop back to Lenovo - they replaced the monitor and serviced the fan (again), and reset my laptop back to factory defaults (re-imaged the hard drive).  My laptop shut down less than 10 minutes after I got it home a week later.  I removed the battery, plugged in the ac adapter, and powered on the laptop.  It stayed powered on overnight, but it shut down sometime during the morning on the next day. Lenovo can't find the issue, but I will call them again today.  I will update this post if something interesting happens.
  • tjornhom Feb 11, 2009
    A friend of mine has this same problem. I tried the solution of taking the battery out but it still just shuts off after about 2 minutes.
    Has anyone come up with any other solutions?
  • mayavmadon Apr 05, 2009
    Same problem as everyone above machinespecs N100 0768 is running Vista Home. I amgoing to try the work around and report back in the morning!
  • mayavmadon Apr 06, 2009
    The work around suggested above by amp_rulz works, i tried it last night and left the laptop on for the whole night and it didnot shutdown!!
    My wife was using it in the evening and all was well!
    I am also trying to contact Lenovo to get an answer to this issue.
    Thanks amp_rulz !!
  • rude83 Apr 13, 2009
    I have the same problem with my Lenovo 3000 N100 0768-A49. I initially thought it was an OS problem, did a complete reinstallation of Windows XP ... no use. Installed Ubuntu afterwards, still same problem. Removing the battery did not help. Now I'm listening closely to see if I hear my fan. Lenovos are inferior, will NEVER buy another Lenovo.
  • adrian53 Apr 17, 2009
    I have the same problem running operating on winows XP. it just cuts out sometimes it goes to restart all over again, it can be after 5 mins or 4 to 5 hours. It is definately a design fault. Any solution yet ?
  • Anonymous Apr 30, 2009
    I have Lenovo 3000 N100 series laptop, have been using it since past 2 yrs now, what a piece of ****!! first created problems with the battery and now gets shut down after every 2 mins!! wonder what could be wrong! Service centers are too exensive and after reading these posts I am nt even sure if they would be able to help...!! any solution please do let me know- reachme_saurabh@yahoo.com
  • Kristof902 May 11, 2010
    Class Action Lawsiut is not the way to go Hp had simmiler problems with an Nvidia chipset cooking the board in the F500 series but in there sace the best recourse was small claims courts because the companies lawyers can't be involved
  • John Griffiths May 11, 2010
    Ok, quick question for troubleshooting purposes. Are you sure that the machine actually shuts down/Off? Do all the lights on the laptop go out as if you have shut it down? If you have the power light still on, then this could indicate a problem with the invertor or the lcd panel itself. Let me know and ill try and help you more.
This seems to be a common problem on Lenovo N100. Lenovo should present a solution or make a recall of the machine in order to keep their reputation
Posted on Oct 06, 2009
Hi.. I have a temporary solution to your problem. I had the same problem. Remove the battery and the ac adapter from the laptop. Just reconnect the ac adapter without the battery and switch on the lap. Presto.. Problem solved.. It doesnt power off anymore unless u remove the ac adaptor. Usefull if u hav needed files n want 2 create a backup. Still i havent found out a permanent solution to this problem. I suspect its a motherboard fault
Posted on Feb 05, 2009
I have the same problem. It seems that running on battery it's fine, but if the AC adapter is in the frame at all then it cuts out with no warning. It has taken me a while to come to this conclusion!! It sounds as if a small relay clicks just as the computer trips
Posted on May 11, 2009
Same problem, n100 768 lenovo, did some digging, seems to be a motherboard design fault, but Lenovo refuses to own up to it, what is needed is a Class Action Lawsuit, if anyone hears of one please contact me radisindahouse@yahoo.com
Thank You
Posted on Oct 14, 2009
I have similar problem with my Lenovo N100. I tried several suggestions provided in this and other threads but none worked.
I have tried to run the laptop just on power code, without battery as suggested by few. It seems, this works for few but not for all.
Too bad Lenovo is not taking any responsibility and coming up with solution. It sucks that now I have buy a laptop just within 2 years but one thing is sure, it won't be Lenovo this time.
Posted on Feb 16, 2010
Tip
Levono 3000 n100 Notebook shuts down all the time
1. Pull out the battery.
2. Open the panel on the bottom that has the fan and remove the fan and heat sink. 3. Clean the top of cpu, 4. Put some thermal paste on the cpu
5. Put it all back together. 6. Safely dispose of the battery, If you plug the battery back in you will have to go through the whole process again 7. Run off ac adapter.
8. Buy a new battery.
on Jun 10, 2010 | Lenovo 3000 N100 Notebook
Power Failure of Lenovo 3000Y400; AC adapter and its power cord are well connected to the computer and power outlet & equip the battery. But my computer still without power indicator & any...
Welcome to Fixya!
You can run the computer by just using the power adapter. Take out the battery and turn on the computer just using the power adapter. If the computer wont turn on then possible problem would be the power adapter itself or the socket where you connected the power adapter to your computer.
You need to send the computer to Lenovo depot repair center for repair.You may try to use other lenovo adapters just to check if the adapter is the problem.
Thank you for using Fixya!
Dec 02, 2010 | Lenovo 3000 Y410 Notebook
Lenovo n100 is 10 minut after power off.
If you are running on battery power and it powers off, then the battery is not fully charged or the battery is worn out or faulty.
Rechargeable batteries have a finite number of charge and discharge cycles and after 2 or more years they will lose its charge capacity until it will not charge at all.
A new battery will solve your problem provided the charging circuit in the laptop is OK.
Sep 26, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 N200
sounds like the mother board maybe on its way out - is it under warranty?
Jul 24, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Download driver
open internet browsing software and type in address bar www.lenovo.com and select your country and select support-downloads and drivers and select brand-notebooks and handheld,family-3000 N100 ,type-0768,model-A52 and operating system-operating system select and continue link click,Refine results select your device for driver
Feb 24, 2009 | Lenovo 3000 N100 Notebook PC
Lenovo 3000 n100 won't power up
I had posted the Aug 19, 2008 comment about having this problem twice. I tried a new universal AC adapter, and it worked! (new adapter is a Targus APA63US) Now battery is charging and laptop also runs on AC alone. So perhaps it's an adapter problem instead of a battery problem. Get one at a store with a good return policy, so if it doesn't work for you, just return it. And if it does work, then happier days. I've had mine about 2 weeks. So far so good, though with what I've learned about Lenovo since having this problem, it wouldn't surprise me if something else goes wrong, or if the damn thing just blew up, ha ha. Also, this adapter set me back about $100 that I really should not have needed to spend! arrgggh ...
Cheers and Best of Luck and hope this helps other frustrated Lenovo owners!
Jul 11, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Radalin -
I've done a lot of laptop repair, and have run into similar issues with various laptops. What you've described sounds to me like a problem in the power circuit on the motherboard. There are a number of things that can cause this, and, generally, none of them are an easy fix - blown capacitor, bad power IC, bridged leads on a relay. If you have any experience working with integrated circuits, you can always test the power loop on the laptop with a multimeter. However, you may want to look into obtaining a warranty repair, or purchasing an extended warranty so that you can get a warranty repair; if there has been no user error(i.e. fluids spilled on the computer, dropped computer, left in excessive heat or humidity), then its a factory defect on the motherboard.
Hope this helps!
-thinstatic
Jun 11, 2008 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
1,852 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
