Question about Optics
Where can I purchase this little battery box for my Meade ds114
Need this battery box for the AA's that plugs in the telescope console to power the scope
  • don henson Jan 15, 2013
    Thanks Everyone for your assistance, will try Astronomy Mall for this battery box . See Ya Don. "Hollywood"
  • 3,961 Answers
Look at this link
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/4341368/Main/4340068#
The Astronomy Mall mentioned there does carry Meade battery packs for this discontinued model.
Posted on Jan 13, 2013
SOURCE: MEADE LX90 TELESCOPE
Had the same problem. Took it to a dealer and we put a new controller on but the funny thing was that my old controller worked fine on another scope but it would not work on mine. Agreed with "Guest" above - Mead's after sales service is bad.
Posted on Apr 08, 2008
  • 1027 Answers
SOURCE: meade LX200GPS telescope
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
Posted on May 22, 2008
SOURCE: missing finder scope
This will do just fine--
http://www.telescope.com/control/product/~category_id=finder_scopes/~pcategory=accessories/~product_id=07228
Posted on Dec 27, 2008
  • 1027 Answers
SOURCE: Meade, model: 6600, 6", need instruction manual & eye pieces
Sorry about Meade's responses, but their website has a download section for the telescope manuals - you may not find one that matches exactly, as they produce hundreds of models, but one that is close should suffice. As for eyepieces, there are several good vendors out there; Orion Telescopes, Meridian etc. Just check the barrel size; either .965" (Japanese standard) or 1.25" (American standard).
Posted on Aug 21, 2009
SOURCE: Meade LX200 10" SC Telescope
You have a standard lx200 problem. If you transported your scope a lot with the drives "locked" it damages the RA and DEC drives. If you keep using it, the motors burn out and start drawing too much current. This sometimes blows the motor driver chips on the motherboard which are getting very rare.
The burned out tantalum caps can be replaced with better aluminum electrolytics very cheaply. If the ones in your Autostar burned out, they often burn up the ribbon cable. Also, they often take out U11, a 74LS14 chip on the motherboard. Also a cheap repair. You should take the Autostar apart. If they are burned up, it will be obvious. If your ribbon cable survived, you should replace the caps with aluminum electrolytics. I believe they are 6.8 uf.
So, if you can work an ohmmeter, measure the resistance of the two drive motors with the plugs unplugged. If it is about 14 ohms they are ok. If they are about 3 or 4 ohms, they are toast. Check the worm drives for end play. If there is just a little, you can adjust them. The battery jack on the control panel often breaks the solder joints on the board, causing one of the problems you describe. You can check that and replace/resolder as necessary. The on/off switch often fails and gets intermittent. These are also cheap and can be replaced. I don't repair these for a living but I repair a few of them for friends in the club. These are pretty common problems.
Posted on Aug 25, 2009
I really need the the battery pack to make work my Meade DS-114AT telescope? or I just need a transformer of 12V to plug in at the outlet to the wall?
You can use a regular deep cycle 12 volt battery-- or any 12 volt car starter battery. All you need is the correct 12 volt cigarette lighter style cable for your scope.
www.scopestuff.com should have the proper 12 volt plug for your scope.
May 01, 2011 | Meade DS114-EC Telescope
I purchased a Meade DS-90AT at a garage sale but it is missing the battery pack (the holder for 10 AA batteries). I called Meade and learned it is no longer available. Any suggestions as to what I can...
You can use any 12 volt power pack like a car starter battery pack-- with the proper cigarette lighter style power cord.
Just buy one with a cigarette lighter style plug-in port- 12 volt-- you can find these at auto parts stores for about $49.
Nov 15, 2010 | Meade DS-90AT Telescope DS-90AT
I have a DS114 Electronic Digital Meade. I only
1 1/4 inch OD is a standard size for eyepieces. You should be able to buy eyepieces in other focal lengths at any shop that sells telescopes, or online. I found hundreds of them with a quick search on Amazon, some made by Meade.
Nov 04, 2010 | Meade DS-114EC (325 x 60mm) Telescope
My battery pack (plastic holder) is broken. Where
Call Meade at this web site:
http://www.meade.com/support/index.html
Apr 30, 2010 | Meade DS114-EC Telescope
The focal tube on my Meade DS 114 has several stripped teeth. The auto-focus skips and jumps! Where can I find a replacement part (Meade no longer carries them) OR how can I repair this; ie, create new...
You will need to buy another focuser like one of these.
http://www.telescope.com/control/accessories/telescope-focusers/1*25-inch-orion-basic-rack-and-pinion-focuser
http://www.telescope.com/control/accessories/telescope-focusers/2-inch-orion-crayford-style-telescope-focuser
Feb 21, 2010 | Meade DS114-EC Telescope
Battery pack is broken, need a replacement. Anyone know where I might find
Meade may be able to replace this. Call them here:
Oct 23, 2009 | Meade DS114-EC Telescope
I have a meade 4501 telescope. It has an
See if a manual is listed on the Meade site Here:
http://www.meade.com/manuals/index.html
That shows the power supply voltage.
Jul 12, 2009 | Meade Optics
I need a battery pack for a Meade DS-114.
I found a supplier that has the holder for $1.92, but the shipping is $14.99 - - -so, there's a question of how bad do you want the battery holder ?
http://www.a1parts.com/battery_holders/battery_holders.htm
Feb 28, 2009 | Meade DS114-EC Telescope
Optics Logo
184 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
