Http://www.intel.com/content/www/us/en/tech-tips-and-tricks/dave-taylor-hdmi-article.html
HDMI cables but check the link if you have further questions or stop by a RadioShack with your laptop if your laptop doesn't have HDMI and let them show you the cables you will need to use with the available ports on yourlaptop
SOURCE: How do I connect my Laptop computer to my LCD TV?
Every laptop has at least a VGA (computer video connection) and s-video cable port. A VGA cable is preferred if you want to be able to read text on your LCD TV. Check to make sure that your LCD TV has a VGA connector. It's a port that accepts a 15-pin connection so it's pretty easy to spot if it's there. It's just like a computer monitor cable if that helps. Should be able to find it at any local retail store that carries computers. VGA or RGB cable.
SOURCE: cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
SOURCE: unable to connect to samsung tv as monitor for hp laptop
Hi there
DSUB is VGA, has your TV got a VGA port on the back? if so and you know what the source the channel is then you will need a male to male VGA lead and a mini stereo jack to left and right male phono jacks for the audio, the DSUB or VGA does not carry audio through it.
Good luck and thanks for using Fixya!!
SOURCE: i want to connect my samsung NC10 laptop to my TV
has the tv got pc/vga in ? also doseur pc have s/vid out
SOURCE: the touchpad on my samsung r519 laptop has stopped working
you have to go on Samsung Site in that site you will find option support and Download from that just you type u r laptop model no you will get touchped driver just download in your othere dive from ther rum in to windows u will able to use your touchpad hope fully
