Question about Sony Handycam DCR-TRV9 Mini DV Digital Camcorder
Camera drops frames when capturing to computer
Had one like it fixed at cam repair shop and they replaced a small part inside. I was wondering if that is something that I could do myself if I can get just the part somewhere.
    Genius:
  • 1,669 Answers
For factory parts go to:
http://www.searspartsdirect.com/partsdirect/part-model/Sony-Parts/Camcorder-Parts/Model-DCRTRV9/0996/0331400?sid=PSx20071217x00001a
Posted on Jan 12, 2013
Canon Camera Error E32. Camera Error Camera will shut down automatically. Please restart your camera. Please help me. I am using Canon Powershot
The most common problems in these small tiny cameras is the lens alignment. If you drop the camera with the lens extended this alignment will ****. If you are a handyman you can fix it by yourself by oppening it inside and realign/putting the lens in right position. Sometimes you can do that by forcing them to extednd manualy but that is very risky. If not handyman I recomand you to take it to a repair shop.
Jan 27, 2011 | Canon PowerShot SD1400 IS IXUS 130...
Camera won't come on
1. Replace batteries with new alkaline batteries.
2. Sometimes an SD card may malfunction. Remove the SD card and turn the camera on. Check your manual for proper use of SD card.
3. Still having issues? If you bought the trail cam within the last 12 months, send it to Moultrie for repair.
Here is the link with a return form an procedures for the return.
For more information about trail cameras, visit my Hunting Supplies Website
Jul 28, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Delay in video. is there a way to fix this? Is thi sdone through video filter/ frame rate? tks
hi,
Some of the cheaper web cams are only capturing 15 frames per second (FPS) or less, whereas better web cams can capture 30 FPS and a larger picture too.Visit the website of the manufacturer of your webcam and see the details of that camera. It's possible you can increase the speed some through your camera settings. Look for your camera's icon in your Control Panel or in your Device Manager section and check your settings.just needed to change fps and the back lighting. <3
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Ezonics EZCam III Webcam
Looking for Manual or Description for Intel cs431 camera.
20717861-177x150-0-0_intel+cs431.jpg Intel Pro Video PC Camera CS431 Web Cam Consumer Rating: Be the first one to write a review on this product Information: Compare prices at 1 store Manufacturer: Intel - See Site Product Details and Features Key Features Web Camera Type Personal Web Camera Image Sensor Type CCD Interface Type grayquestion.gif USB Video Capture Resolution grayquestion.gif 640 x 480 Digital Video Capture Speed 30 frames per second Miscellaneous Compatibility grayquestion.gif PC Product ID 20717861 Compare stores & prices http://www.shopping.com/xPF-Intel-CS431
Jan 02, 2009 | Intel Easy PC Camera Webcam
Fuji fine pix A400 zoom error
the camera may not be dropped but the lens may have initiated incrrectly, like it was turned on inside the case that the something prevented the lens to fully mount (telescope out) to default capture position.
it is repairable with Fuji Techs, but if the cost of the repair is worth 3/4 to the original price when you got the unit and is out of its warranty, then it will be best to get it replaced, and you may use this camera for harsh environments, like outdoor trekking or a helmet cam perhaps, it just a personal idea.
http://www.fujifilm.com/products/digital_cameras/a/finepix_a500/images/a500_e_manual.pdf
Jun 22, 2008 | Fuji FinePix A400 Digital Camera
Dropped frames during capture from camcorder
Firewire cards are quite cheap, under $20, replace the card. If you still have problems then it is most likely with the camcorder.
Jun 05, 2008 | Canon ZR830 Mini DV Digital Camcorder
Dropping Frames & No Sound
Normal 0 Go to Control Panel and Click on Sounds, Clickon Audio, then Click on the Microphone. Then Click on the dropdown and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Jun 01, 2008 | GE MiniCam Pro HO98067 Webcam
Dropped the camara,it turns on & everything works EXEPT capture button
Unfortunately, as you have found, the cost to repair these cameras is usually not viable, as it is cheaper to replace the camera.
Even if it is repaired, often the impact from being dropped can cause small fractures in boards or loosen the optics and while they may work ok now, can continually develop faults later.
My advice would be to replace the camera, as you will also get a new warranty as well.
Mar 24, 2008 | Kodak EasyShare V603 Digital Camera
DOWNLOADING FROM CAMERA TO COMPUTER
Digital Video (DV) camcorders use a small port, usually located underneath the LCD flip-out screen, or behind a small plastic cover on the camera's body. My Canon has it on the front under the microphone. A special cable is required to plug into this port, and then into either the computer's USB or Firewire port. The camera is turned on, plugged in and Windows XP/Vista will offer to import the footage.
Analog (8MM, Hi-8, VHS-C) use a cable that has a headphone type plug on one end and audio/video RCA plugs on the other. These camcorders require you to equip the computer with a video capture device.
Without knowing the model of the camcorder, it is impossible to give any additional information. The operating system you are using would also be helpful information.
Nov 09, 2007 | Video Cameras
Small hair in view finder
That camera has a removable focusing screen. Usually the object(hair) is sitting on top of the focusing screen so the screen has to be dropped down to remove it. There is a clip(frame) accessable from the mirror box that needs to be un-hooked. The frame swings down and usually the screen and a brass shim(s) comes down with it. If your careful and don't actually remove the frame, screen and shim it's pretty straight forward to gently blow the hair out. After removing the hair, gently swing the frame up and clip it back in.If the frame, screen and shim actually fall out it's tricky getting them back in correctly. The screen is also very soft and scratches easily so much care is needed. If you're uncomfortable trying to attempt this then take the MZ50 to a good repair shop. We do this service free and usually while you wait. Other shops may charge you a fee to do it. If the hair is behind the eyepiece then the top cover has to be removed to get the hair out. That is a totally different problem and the camera will need to be repaired. Since the hair dosen't affect the image on the film, you may just want to live with it or have it removed when something else needs to be done when the camera has to be disassembled anyway. Hope this helps.
Apr 28, 2007 | Pentax MZ-50 35mm SLR Camera
Sony Handycam DCR-TRV9 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
