Question about Cadence Exercise & Fitness
Can you slide the belt over to fix it - Cadence Exercise & Fitness
    Genius:
  • 1,669 Answers
Here is an article that may help you:
http://www.articlesbase.com/health-articles/weslo-cadence-treadmill-c44-doityourself-home-repair-895087.html
Posted on Jan 12, 2013
How do i fix my seat belt is locked up tight and wont move.How do i fix it?
need to remove the plastic trim where belt retracts to slide up out of way and inspect seat belt retractor drum for debris jamming ratchet or against locking mechanism check belt is not twisted and last look for rust
May 13, 2014 | 2001 Hyundai Santa Fe
Car squeals on start-up how i and what bolt do i tighten up
The loose belt. Some are auto tensionors. If equiped with auto tensionor check belt condition first
Jan 10, 2013 | 2002 Mitsubishi Galant
Smell coming out of vacuum
If it is a smell of burning rubber, it is time to change the belt. It is an easy fix. Most belts can be changed by opening the bottom plate, lifting the roller up, and sliding in a new belt. You can find vacuum cleaner belts here. If you are not able to find the belt, let me know the model number and I will send you the link to the belt
May 25, 2012 | Hoover Vacuums
Replace belt on hoover vacuum U4655
Turn the machine over and remove the 4 screws which hold the cover on the brush. Remove the cover and brush roller. Remove old belt. Slide new belt over the motor pulley, first. Then slide roller through new belt (if self propelled model, slide roller through the small belt, also) and slide brush roller into slots on housing (note: slots are different, match roller sides to correct slot.)
Oct 22, 2011 | Hoover Vacuums
Motor runs, brush won't turn, burning rubber smell
Easy to fix. The burning rubber smell is hair in the roller against the belt! Congrats, you have a healthy vacuum, you are lucky! Unplug the vacuum, remove the screws that cover the belt and roller brush. If you are nervous, take pictures with a cell phone or digital camera as you go for re-assembly. ok, pull the long roller out of it's slot and out of the vacuum. cut all hair off the roller and carefully move the belt from side to side to do the same. If the belt slips off, it slips back on easily. If the area is too tight for fingers guide it back on with any long thin wooden object. You can squeeze the belt to narrow it and slide it back over the thin metal rod that spins it from the motor. Slide the roller through the belt and back into it's slots. If it won't slide back on, turn it a quarter turn. Repeat till it does slide back into place. Put the face plate back on-tighten screws, flip it over, plug itr in and it should work!
Sep 05, 2011 | Bissell Vacuums
Fixing pulley belt , is there a way to replace pulley belt without taking off the motor mount
no. isnt it a great design? Its easiest to take the bolts loose then take out the one stud and spacer,and slide the belt out/in.
Jun 19, 2010 | 1995 Buick Park Avenue
How to fix a stuck seat belt VW GTI 2009
I just solved the problem for a stuck rear center seat belt in my 2002 Jetta.
Flip the base seat cushion forward against the front seat backs. Trace down along the belt to its tether point on the floor. The belt is sewn around a steel loop. The loop is anchored to a black steel hook. A thin silvery retainer plate is spring tensioned on top of the loop to prevent it from sliding off of the hook when the seat back is folded.
Therefore, you need to press the silvery retainer plate away from the hook (push up) to allow the loop to be slid from the hook. The belt was tight with the seat back in the upright position, so it was necessary to fold the seat back forward to create slack in the belt. Now push the belt loop towards the trunk and slide it off of the end of the hook (only possible with the retainer plate pushed up out of the way).
Now with total release of tension on the system via the bottom end of the seat belt being untethered and with the seat back returned to the upright position, normal extension and retraction of the belt will be reestablished. Next, simply extend the seat belt and slide the loop back into place over the floor hook. It snaps past the silvery retainer plate without all the effort required to hold the plate up during removal of the loop during disassembly.
Check again, the seat belt should be extending and retracting properly. Now just put the seat cushion back into regular position and you will be able to safely buckle up three people across the back seat.
It took about as long to do this repair as it has taken to post this answer to the problem. Note, the seat belt safety mechanism only allows normal extension and retraction of the belt when the seat back is upright.
Nov 29, 2009 | Volkswagen GTI Cars & Trucks
How to fix the serpintin belt
Replace the belt, dont fix the old one. use a breaker bar to lift up on the belt tension pulley. while holding it up slide off the belt from one of the other pulleys. ***Slowly release the tensioner.*** then remove the belt. replace with a new belt (the same size as the old one) put it on all the pulleys except the last one. lift the tensioner up then slide the belt over the last pulley. recheck all pulleys to see if belt is on all pulleys correctly. then start engine.
Oct 03, 2009 | 1992 Honda Accord
Slipped belt
look at the fixing on the motor you have to undo the bolt and it slides in to alow you to put the belt on then slide motor back and nip up the bolt
Jul 19, 2008 | Hotpoint Washing Machines
Where is belt on dryer and how to fix drum won't turn
The belt on a roper dryer is inside the body, accessed and changed as follows
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
May 07, 2008 | Roper REX4634KQ Electric Dryer
Exercise & Fitness Logo
50 people viewed this question
Top Cadence Exercise & Fitness Experts
Jim London
Jim London
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
