Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
The idler pulley broke and shredded the belt. After replacing pulley, belt is not sitting on pulley straight. Is there some kind of part to bring pulley to where belt runs even on it?
    Scholar:
  • 117 Answers
Did you replace the idler pulley or the belt tensioner? If it was the idler pulley, make sure you transferred the insert that centers the bolt. If it was the tensioner, there is a nub that must fit into a slot on the engine block to keep it flush
Posted on Nov 02, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I have a troy bilt 13ax60tg766 it shreds blade belt after run for 5 min
There are two idler pulleys on that machine and a drive pulley and mower pulley etc. These all have to line up in a straight plane. The idler pulley set might be seizing after running . There are a lot of things that could be causing this.
Nov 27, 2017 | Troy Garden
I need to know why my truck is shredding serpentine belts
it is difficult to diagnose a fault without direct access to a vehicle but can Iask where any of the components driven by the belt are tightening up, i.e. beginning to wear or seize. If one of the periheral components being driven by the belt is not rotating freely it will be acting on the belt as a brake. The forces on the belt will be out of balance. If all pulleys rotate freely there should be no abnormal friction so no snapping. Where the belt is being driven (by the crank?) and it is slowed down by a pully that is not rotating as freely as it should that will introduce forces that will destroy the belt.
It may be that your vehicle is about to experience component failure and the snapping of the belt is a symptom of it
Good Luck tracking the problem down
May 30, 2015 | Cars & Trucks
I have a 93 k2500 5.7 gas Chevy cheyenne that was squealing so we changed the tenssioner and pulley then changed the idler pulley along with the belt so far it has threw three belts and shredding them like...
The tensioner pulley moves back and forth to keep belt tight..the idle pulley just sits there and spins..none should have play at bearing. If u misplaced a washer/spacer it could cause the misaligned issue that is shredding belt..
Sep 27, 2014 | Cars & Trucks
We just replaced the belt on the dryer and a week later it broke, shredded
Check all pulleys turn. One pulley must be shredding the belt. Possibly the idler. Bearing might be seized in the idler pulley. Free up the idler bearing then.
Feb 24, 2011 | Kenmore Dryers
Why belt keeps shredding
usually due to a bad bearing, or from resistance due to a frozen or failing assemble, as in power steering, alternator, or an idler. The best way to determine is to remove the belt and check all pulleys for play and resistance.
Feb 10, 2011 | 2000 Chevrolet Venture
How do you adjust the pulleys on a 42" 20 HP craftsman tractor mower. The belt burned off and when I replaced it with a new one the new one began to shred
There is no adjustment on these pulleys. Sounds like the belt was over the blade pulley brake arms or idler pulley guide. They will shred a belt in nothing flat.
Sep 17, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
My serpintine belt on 2000 siloette keeps shredding
you most likely have a pulley out of alignment or bearing on one bad belt tensioners tend to lay at an angle when going bad this causes belt to try and ride on shoiulder of pulley and shreds belt with belt off check all pulleys and idlers for any play
Mar 22, 2010 | 2000 Oldsmobile Silhouette
2003 v6 dakota serpentine belt shreds
I'd be more inclined to check that idler pulleys and alternator bearings are okay before looking at crank pulley. Take off the belt and give them a good wiggle and spin.
Sep 11, 2009 | 1997 Dodge Dakota
MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Jun 05, 2009 | Mtd Garden
Do you have a diagram on routing the drive belt?
The diagram on the right in this link provides the exact diagram/pic. for your car. The link is to a site that explains how to convert earlier NG models (which had an extra center idler pulley) to a shorter belt, ala the newer models such as yours which had eliminated this idler. See also, this site for additional information. Another diagram is here with part numbers for the pulleys and the belt. This is about a one hour job to replace the belt and one or two pulleys. Ensure the pulleys are lined up correctly to avoid throwing the new belt when you start it up.
Mar 28, 2009 | 2000 Saab 9-3 Viggen
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
