Question about Olympia Office Equipment & Supplies
When I hit the return button my Olympia locks up until I turn it off and back on again.
When I hit the return key it shifts a little then all keys are frozen until I turn off and back on then it works fine until I hit the return key again.
  • Olympia Master
  • 3,594 Answers
Try a shot of WD40 ON THE SILVER SHAFT that the carrier slides on.
SickyO
Posted on Jan 16, 2013
  • 3594 Answers
SOURCE: IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Posted on Jul 11, 2008
SOURCE: Olympia Mastertype 3 Typewriter
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
Posted on Sep 02, 2008
  • 3594 Answers
SOURCE: IBM Wheelwriter 3 typing incorrect characters
If you have another printwheel try that, if you still have the trouble try blowing out the area where it is in stalled. If that fails turn the machine off then back on, after it completes the POR mark the printwheel with some white out, repeat the POR see if the mark is in the same place, if it isin't you probably have a selection plate problem.
DickyO
Posted on Nov 16, 2008
Geno111
  • 183 Answers
SOURCE: Carriage return
check to make sure no forien objects are in machine preventing the carrier from moving, with the mach. turned OFF you should be able to move the carrier by hand from one side to the other
Posted on Nov 25, 2008
  • 3594 Answers
SOURCE: Shift key does not work
The chances are that you need a replacement keyboard it is probably coming apart. Contact Geo. Beyers Co. @ 1800-392-8085
DickyO
Posted on Jun 11, 2009
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
Hp probook keyboard
most likley a loose cable or "ghosting" go to your local pc shop for help
Mar 08, 2014 | Computers & Internet
My olympia electric typewriter is always on capital letters no matter how i unlock the keys/shift...won't go back to small letters.
You didn't give a model but there should be a key that says above or on the front of it caps or caps lock the code and that key should do it.
DickyO
Jun 24, 2011 | Olympia Office Equipment & Supplies
Computer says its locked; change users, but my mouse is locked up too.Im using my desk top to contact you.
You can use the windows key to open the start menu, then use your arrow keys to hightight turn off your computer, hit the enter key, use your arrow keys to highlight restart and hit your enter key This will restart your computer and hopefully, unlock your mouse.
Let me know if this solution works for you. If all else fails, it is acceptable to push the power button until the computer turns off, then hit it again the turn the computer back on. This is not the normally acceptable procedure for shutting windows down, but in this case, it can be done without any negative repercussions.
Brian
Jan 02, 2011 | Computers & Internet
Resetting a Key fob on 2007 Honda Pilot
to program a key fob- get in vehicle and close all doors. insert key into ignition, have all the key fobs you want to program for this vehicle in hand, programing erases all old fobs. turn the ignition switch to on(all dash lights light up, on click before starting the car). then hit the lock button on one of the fobs. turn the ignition to lock. turn the ignition back to run and press the lock button again from the same remote. repeat untill all the locks cycle. ones the locks cycle keep the ignition in run and press the lock button on each key fob(the ocks will cycle each time a button is pressed). then turn the ignition to lock after all fobs have been programed
Dec 31, 2009 | 2009 Honda Pilot
Ignition key won't turn. gear can't be shifted to neutral.
Check to insure that you have the correct key. If you do, spray a little WD-40 on the key, insert it and try it again. If it won't turn, turn the steering wheel as far back and forth as you can and try the key again, repeat until the key turns. The problem is that the ignition lock is slightly out of alignment, a common problem. Usually a little patience and a little more force and it will turn.
Sep 13, 2009 | 2006 Infiniti FX35
How do i get the keyboard to type the letters instead of the numbers
hold the fn and shift and num lock keys down - this reverts to normal keyboard
Jun 22, 2009 | Acer NSK8458AN Keyboard
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
Hi i have photo copier minolta dialta di183
Enter the admin mode (U-5) by holding down the Panel Reset key for 3 seconds (until "U- " appears in the display), entering the number 5 from the keypad, and pressing the start key. Enter the 6 digit administrator code and press the start key again. The display should show "Ad-". Enter 1 from the keypad and again press the start key. The display should read "0". Hit the clear key, enter "1" and hit the start key yet again. Hit Panel Reset several times (or turn the machine off and back on) to return to normal operation.
The default administrator code is 000000.
If you do not know the administrator code, it will be necessary to reset it using the tech rep mode. Enter the tech rep mode by pressing the Meter Count key and hitting "Stop - 0 - 0 - Stop - 0 - 1" quickly. Then hit 7 and the start key. The administrator code will flash. You can write it down and use it, or hit the clear key and enter a new code, then the start key. Exit as above.
Jul 03, 2008 | Minolta DiALTA Di183 Copier
My typing goes uppercase without hitting the caps lock
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
Oct 20, 2007 | HP Pavilion dv8000z Notebook
32 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
