Question about Garden
I have a 2166 cub cadet and the pto belt keeps breaking why
    Genius:
  • 1,669 Answers
Check that belt is mounted properly according to the diagram on the tractor. Frequently people put the belt on the wrong side of the steel guide springs so that the belt is abrading the springs instead of smoothly riding on the pulleys.
Posted on Jan 12, 2013
Model 2166. Where can I get diagram showing PTO belt installation?
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/2166//1
Oct 07, 2015 | Cub Cadet Garden
Cub cadet 2166 pto not working
check fuse then check to see if power going to pto if is bad pto if not check switch then safty switches
Apr 18, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2166 dies when I engage PTO or let brake peddal all the way up
replace that safety switch there is two switches built into one
Jun 11, 2012 | Cub Cadet Garden
I have a cub cadet 2166. Blades are not kicking on when the pto switch is engaged
hello, the pto or belt is bad,for the pto repair see u tube,,
Feb 18, 2012 | John Deere Garden
Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Jul 10, 2010 | Cub Cadet Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Hi i have a cub cadet 2518 and my pto belt keeps breaking (2) belts today 4-15-10 and only one in years past ??? what could be the problem ??? ty don
siezed pully bering check to see if there is a grease fitting if not get PB BLASTER best stuf ever made to loosen up tough stuf
Apr 15, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Oct 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
144 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
