Question about Hotpoint WMA11 Front Load Washer
How do i clean the filter? - Hotpoint WMA11 Front Load Washer
    Sergeant:
  • 291 Answers
If there is a panel at bottom front of machine there should be screws along the bottom lip of it. Remove the screws to remove the panel. Pump should be facing you right out front with a large screw on cap.. Let me know if yours isn't as described or further instructions. Be aware if it is as described water will come out when cap is removed even with tub empty, so prepare. A shop vac with paper filter removed works good to catch the water.
Posted on Jan 12, 2013
I have the KAWS700GQ washer with a self cleaning filter. My dark clothes are now covered in lint. How can I clean the filter?
go to
www.youtube.com/kitchenaid_washing_machine/how to clean the self cleaning filter
www.ask.com/
www.about.com/
www.wikipedia.org/
/how to clean a self cleaning filter for a KAWS700GQ
go to www.kitchenaid.com/service/how to clean the self cleaning filter.
Apr 13, 2015 | KitchenAid Washing Machines
How do I clean the filter on the Novotronic W 310 Miele washing machine
Cleaning the fluff filter and pump
Check the fluff filter initially after 3 - 4 washes to ascertain how often it is likely to require cleaning. With normal cleaning approx. 2 litres of water run out.
If the drain outlet is clogged, more water will be retained in the machine (up to 25 litres).
Caution: if laundry has been washed at a high temperature,
water draining out of the machine will still be hot!
Take the (yellow) filter flap opener from behind the detergent drawer facia panel. Open the flap.
Place a dish under the drain fixture. Turn the fluff filter lid round 2 - 3
times. Do not take it right out.
With large volumes of water when the dish is full, screw the fluff filter back into position and empty the dish before repeating the procedure.
Once the flow of water ceases, remove the fluff filter completely and
clean it.
Remove any foreign bodies (e.g. buttons, coins, etc.) and fluff.
Turn the impeller by hand to check that it is free to rotate. Any foreign objects causing an obstruction should be removed.
Clean the inside of the fluff filter housing. Remove any deposits of lime scale and detergent or foreign bodies from the thread of the filter housing and filter unit (as these objects can cause a leakage
of water). Put the fluff filter back and screw it in firmly.
Cleaning and care
To clean the water inlet filters
The washing machine has two filters to protect the inlet valves. These filters should be checked every 6 months or so, or more often if there are frequent interruptions to the water supply.
To clean the filter in the union in the open end of the inlet hose:
First turn off the stopcock.
Unscrew the threaded union connecting the free end of the inlet hose to the stopcock.
Remove the rubber seal from the recess. Using pointed pliers, take hold of the plastic filter bar, remove the filter and clean.
Put the filter and seal back in the reverse order and reconnect the
hose. Turn on the stopcock and check the connection is watertight.
Inspect the inlet hose which is subjected to high pressure while the machine is in operation. The hose should be replaced if there are small cracks in the surface, or if it has been otherwise damaged.
If replacing the inlet hose only use a hose able to withstand pressure up to 70 bar. Miele's own hoses meet this requirement.
To clean the filter in the water inlet valve:
Using pliers, carefully loosen the ribbed plastic nut on the inlet valve,
and unscrew.
Use water pump pliers to withdraw the plastic filter by the bar.
Clean, put back and secure.
The two filters must be put back in place after cleaning.
Mar 08, 2015 | Miele W310 Front Load Washer
How to clean washable filters?
To clean the washable filters you need few things like a stool, screwdriver, brush for cleaning, vacuum with attachments and running water. Cleaning the air filters regularly will keep you away from different type of allergies which are caused by fungi, molds and bacteria.
Sep 30, 2014 | Water Dispensing & Filtration
Removing the filter model fdl7051
Hello Friend, this is Z. Thank you for allowing me to assist you!
You would need to remove the bucket to locate the filter of your Frigidaire dehumidifier (FDL70S1). Then pull the filter downwards for cleaning. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions and typically the FILTER REST light will illuminate after 250 hours of operation. Hope this helps!
Aug 12, 2014 | Frigidaire Dehumidifiers
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
Mar 14, 2014 | Maytag MMV5208W Microwave Oven
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
I have cleaned the filters, and i still get the Clean Filter message. It is running fine, but the red letters Clean Filter are still there... any suggestions???
How did you clean the filters? I run mine through the dishwasher by themselves and it works pretty good. The tops and bottoms of the filters near the edges need to be wiped pretty clean.
Jan 02, 2011 | Brookstone Pure-Ion (506840) Air Purifier
How do I clean the filters
Generic problem for all Vacuums
How do I clean the
How do I clean the filters?
Comment by Avonb, posted on Apr 22, 2008 I have a Bagless twin clean, thought I was cleaning the filters but apparently not, the manual is very vague
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the Model # or Brand name, it is a good idea that you can vacuum of the filters, if you have a blower – you can blow off the dirt from the filters, some filters are washable and you can clean them by washing them and letting them dry completely before you re-install the filters. Idea? If you have an old paint brush, that is ideal to clean off HEPA filters or cartridge filters or use a blower to clean off the dirt. You need to be the best judge on how to clean the filters. You can check the company’s website for the brand name such as:
http://www.hoover.com ---- example given
Don – The Vac Man
Apr 22, 2008 | Vacuums
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Mar 12, 2008 | Hunter 33202 Humidifier
Cleaning the filter
Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
Nov 14, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Hotpoint WMA11 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
