Question about Janome Sewing Machines
I have a Janome sewing machine, #423S that I have never used. It is second hand. It sews nicely, but I cannot find the reverse lever on it
  • Janome Master
  • 5,184 Answers
The reverse lever should be below the stitch width lever. (It's a wide lever in its own recessed area. just above the level of the extension table.) See page 2 (page 4 of the PDF) available here: http://content.janome.com/documents/File/ManualFile/Inst%20book%20419S%20&%20423S1.pdf .
I hope this helps.
Posted on Jan 12, 2013
  • 46 Answers
SOURCE: Backward sewing machine
that sounds like the button is stuck. You may need to get it looked at.
Posted on Oct 24, 2008
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
  • 323 Answers
SOURCE: Janome SD-2014 sewing machine dogs fails to operate in reverse
The grease has hardened and that is what makes it not work. You need to remove the spring and clean all the old grease off it. You can put new grease on if you want but it isn't necessary. The machine should be lubricated with a good quality sewing machine oil(not 3 in 1). You need to oil any place that moves and rubs, This includes the ends of each shaft, the needle bar and the cinnecting links that drive the needle bar. Nothing is permanently lubricated.. you'll find this machine will run much smoother and quieter with fresh lubrication.As a matter of fact, if you use the machine a lot, it should be lubricated once a year and never less thanonce every 5 years.
One more thing. If it is on the main shaft that it has hardened you can spray it with a mixture of fantastic, water and some ammonia. Free it up and give it a light shot of oil.
sewman7
mohammed387
  • 1952 Answers
SOURCE: lever is stuck in reverse
If the stitch length bar, which is located on the right side of the machine, is in the up position move it down to where the numbers are. Those numbers are referring to how many stitches the machine will sew in an inch. Therefore, if you put it on 10, your machine will sew 10 stitches per inch. It being up will cause your machine to go in reverse.
Posted on Jul 26, 2009
wentlanv
  • 710 Answers
SOURCE: I have a Toyota 2700
Can you get inside to get at the lever? Spray the reverse mechanism with sewing machine oil or WD40. Be sure to clean the mechanism first.
If the feed direction is forward after you oil it, great! If not, it's off to the repair shop.
I hope this works for you. Thanks for visiting fixya.com
Handie Andie
I'd appreciate your vote. Thanks.
Posted on Apr 12, 2011
Bobbin shuttle fell out
About 8,950 results (0.69 seconds) Search Results
    Inserting the Janome Front Loading Bobbin Case - YouTube
    ? 1:46
    https://www.youtube.com/watch?v=Mz7-k4G9HFg
    May 8, 2013 - Uploaded by Janome Canada
    Learn how to insert a front loading bobbin case. It's easier than you might imagine. Janome ... Janome HD-1000, Beginnersewing machine.
    How Do I Fix My Sewing Machine: Troubleshooting Your ...
    www.craftsy.com > Blog Home > Sewing Blog
    Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ...Take the Trouble Out of Sewing Machine Troubleshooting! ... has fallen out of the take-up lever, which can happen if the machine was jammed along the way. ... of thread through the bobbin winding tension at the top of the machine.
    Bobbin Case Keeps Falling Out of a Sewing Machine ...
    www.thriftyfun.com/Bobbin-Case-Keeps-Falling-Out-of-a-Sewing-Mach...
Feb 09, 2016 | Janome Hd1000 Sewing Machine
V/74088/620
I am having the same problem. Initially it did sew forward, but now only sews in reverse. The large grey lever on the right front of the machine should make it sew in reverse only as long as it is held down, but mine sews in reverse only. Hmmmm....think there are many people with this problem.
Jan 30, 2012 | Janome 2049LX Mechanical Sewing Machine
Instruction manual for Janome 419s & 423s
You can download one from here:-
www.sicistroje.net/soubory/.../423S_Instr_book.pdf - United States
Jan 29, 2012 | Janome Sewing Machines
I need a manual for a Janome 423S sewing machine
So, I got it on this site:http://content.janome.com/documents/File/ManualFile/Inst%20book%20419S%20&%20423S.pdf
Oct 02, 2011 | Sewing Machines
Janome 423S the feed dogs wont come back up
On some of my machines, they are not Janome, when I put the feed dogs back up, they will not Pop back up, until one rotation has been made with the fly wheel.
Dec 24, 2010 | Janome Memory Craft 10000
Lever is stuck in reverse
Jul 26, 2009 | Brother LS-1217 Mechanical Sewing Machine
The icons are out of sync.
Have a sewing machine needle handy and turn the machine off.
With your left hand, press and hold /StartStop, Up/Down and reverse while switching on the machine. The screen should display little cross hairs. Using the BLUNT end of the needle NOT THE TIP, press the exact center of the cross hairs. Continue a the cross hairs will change positions on the screen. When finished, switch machine off, wait five seconds and switch back on.
Jun 27, 2009 | Janome Memory Craft 9000 Computerized...
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Jerome harmony 4035
Most likely is that the reverse mechanism is jammed with old oil and lint to form a glue.......especially if the machine has not been used recently or regularly.
If you can remove the base plates from underneath easily, then try to operate the reverse lever, you will see a metal lever trying to move a collar around the shaft......apply a small amount of WD40 or similar to both sides of the join then press the reverse rapidly for a while, move it by hand if necessary back and forth..........with regular use this is rarely an issue, it is most common when the machine is idle for long periods.
If you cannot remove base plates easily, ie if the case is split down the middle in 2 sections, take it to a Janome Dealer who has the repair manual as trying to split the case yourself without the manual is very difficult and you will probably break the retaining clips.
www.bargainbox.com.au
Oct 29, 2008 | Janome 6019QC Mechanical Sewing Machine
Sewing Machines Logo
71 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
